[Ovmsdev] General trip & grid log proposal
Sat Jan 16 15:50:29 HKT 2021
Steve,
forgot to mention: the V3 server already supports "data" notifications.
These are published under the topic scheme
"<prefix>/notify/data/<subtype>/<id>/<timestamp>".
So you can already send compact custom records. V2 "history" records are
sent that way, see OvmsVehicleRenaultTwizy::SendTripLog() for an example.
Am 15.01.21 um 13:55 schrieb Michael Balzer:
> Steve,
> Am 15.01.21 um 10:04 schrieb Steve Davies:
>> This seems more manageable than the continuous streaming, a sensible
>> compromise.
> As I said, the streaming mode wasn't meant to stream all metrics. The
> V3 server lacks a means to control metrics update rates. Feel free to
> add one, also take into account what has been discussed on this
> before, i.e.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/344
>> But should I be working with MQTT? Right now Mark and Michael you
>> are by far the biggest contributors so I'd definitely take a steer
>> from you about this. I don't think it helps the project to have two
>> different approaches "competing" in the same code base.
> It's not a competition, it's supporting two different approaches. We
> even support a third approach in form of our WebSocket protocol, which
> can be used for direct local connections to the module.
> V2 / MP is a custom protocol and more of a legacy support. But it has
> undeniable advantages over the current MQTT implementation.
>> You say:
>> > The V3 server needs further development from actual users like
>> you. I don't use MQTT because of the protocol overhead. So go ahead,
>> refine it.
>> So the blunt question is whether this MQTT / V3 approach is dying on
>> the vine or if it is worth investing time into.
>> Looks like Mark wrote most of it 3 years ago.
>> For me I'm used to MQTT, I like it and use it in my house control
>> systems, energy monitoring, OpenEVSE etc. It's exactly designed for
>> the IOT world. NodeRed, Homeassistant and other tools support it well.
>> But OVMS is already invested in the V2 protocol and you are still
>> developing it.
>> As implemented, the V3/MQTT approach will definitely have more
>> overhead - and indeed sending every metric in a separate message will
>> use a lot more data.
>> But nothing says that we can't have a "compact" format similar to the
>> data messages that V2 sends. MQTT adds just a few bytes per
>> published message for the MQTT protocol so that would end up being
>> nearly as efficient unless I've missed something?
>> It does mean that consumers of the MQTT messages need to work harder
>> to parse them - they would need to know the order of the values. We
>> couldn't use a self-describing format like JSON since that has plenty
>> of overhead of its own.
> I think you're describing a valid approach to reduce the MQTT
> overhead, basically something like sending the V2 MP records over MQTT
> instead of single metrics.
> I just don't know if that's what people expect from MQTT. It removes
> all the simplicity from receiving metric values via MQTT. Will
> standard MQTT clients & tools be able to parse such records? And even
> if they do, it would still introduce a hurdle for users trying to get
> into telemetry processing. Part of the appeal of MQTT is being able to
> use a broad selection of generic standard clients.
>> Another approach is - instead of having the V3/MQTT "server" on OVMS,
>> to rather have a two way gateway that runs server-side that connects
>> to the V2 server and proxies back and forth from MQTT. I would see
>> this as an "app" side gateway - so metric records coming from the car
>> get published to mqtt (v2->v3) and commands are translated back the
>> other way (v3->v2). Then the extra protocol overhead for the
>> existing MQTT format doesn't matter since we aren't going to be
>> sending over an "IOT" SIM over 3G.
>> What are your thoughts?
> That would introduce the need for a second server / gateway instance
> just to attach to MP via MQTT. Possible, but then, MP isn't that hard
> to connect directly to. There are many example clients. The gateway
> would still have a benefit if MQTT clients can parse MP records though.
> How about eliminating the need for that gateway by adding optional
> standard & configurable custom topic record structures to the V3
> server? In the most simple form, a record structure is simply a list
> of metric names to join under a definable topic. A little bit of
> number formatting would be useful, e.g. using printf style format strings.
> Example: the MP "L" record structure could be described by some string
> like this:
> {v.p.latitude},{v.p.longitude},{v.p.direction},{v.p.altitude},{v.p.gpslock},{v.p.speed},{v.p.trip},{v.e.drivemode%x},{v.b.power%.3f},{v.b.energy.used%.3f},…
> JSON format could be supported by some keyword to request JSON value
> encoding. You could even introduce a way to get the value from a
> Javascript function, like Greg does for the obd2ecu system.
> Combine that with a decent metric filter & update rate configuration
> (see issue link above – btw, we already have topic pattern support
> from Mongoose…), and you get the best of both approaches, without any
> added transport complexity or points of failure.
> Standard users will be able to subscribe to single metric values, and
> power users will be able to easily create custom records.
> Just my 2 cents as a yet-to-become MQTT user.
>> Thanks,
>> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210116/d2812128/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210116/d2812128/attachment.sig>
