[Ovmsdev] General trip & grid log proposal
Fri Jan 15 01:58:11 HKT 2021
Steve,
not your fault, missing V3 documentation. These are features ported from
V2, which was configured by a fixed array of "features" & "parameters".
You can find info on these in the V2 documentation. Setting features &
parameters is still supported by the Apps, and is more convenient for
users than learning a config command. For complex features, adding an
editor to the Apps is recommended, but simple configuration values can
be integrated easily this way.
V3 has a mapper for these, you can extend for custom vehicle features:
class OvmsVehicle …
virtual bool SetFeature(int key, const char* value);
virtual const std::string GetFeature(int key);
We only support a few V2 standard features by default in V3, the
streaming mode is one of them.
V2 only uses the streaming mode for the location message, and
additionally requires the vehicle to be on and some client to be
connected. It also supports not only enabling the streaming mode, but
also configuring the interval (seconds) by the feature / config.
The V3 / MQTT server is still experimental, the implementation may
change and be changed by you. It currently apparently only supports
enabling/disabling the streaming mode and, you're right, if enabled
applies this to all metrics without any interval. I suppose that was an
initial, very simple implementation of streaming mode. I think it isn't
very useful, as you may have metrics that change a hundred times per
second, and the V3 server will try to transmit every single change with
streaming enabled. It looks like the interval support is prepared in the
Ticker1() method though, the same way as in the V2 server.
The V3 server needs further development from actual users like you. I
don't use MQTT because of the protocol overhead. So go ahead, refine it.
The way MQTT works is outlined in the list archive and by an example script:
- Topic structure:
http://lists.openvehicles.com/pipermail/ovmsdev/2018-July/005354.html
- Command shell example:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/client/ovms_v3shell.pl
…and all this really needs documentation…
Am 14.01.21 um 16:53 schrieb Steve Davies:
> On Thu, 14 Jan 2021 at 09:23, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
> Both are historical records, i.e. kept on the server until
> deletion or expiry. If you're looking for a GPS log, we've already
> got that in form of the "L" messages. These are kept for 24 hours,
> and the log frequency adapts to user choice and App connection
> state ("streaming mode", feature #8 / config vehicle stream).
> Thanks!
> Is there documentation that I failed to find? IE "feature #8" - seems
> like from a list somewhere?
> I'm working at the moment with the MQTT server.
> In the mqtt server code I found "m_streaming" and it looks like I need
> "config set vehicle stream 1"
> If I understand correctly this will result in metrics being published
> to mqtt as soon as they change.
> Looking at the code I'm also trying to understand what exactly a
> "client" is. Here's how it looks to me: a client sends a message
> with topic <prefix>/client/<clientid>/active with the payload being
> non-0 to "connect" and 0 or empty to disconnect. Must send that at
> least once every 120 seconds to stay connected.
> With a client "connected" the MQTT server will send metrics at
> the updatetime.connected rate rather than the idle rate
> (nowithstanding that with "stream 1" they are sent immediately).
> Clients can also send commands too: <prefix>/client/<clientid>/command
> Am I on the right track?
> Thanks,
> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210114/c48c1a42/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210114/c48c1a42/attachment.sig>
