[Ovmsdev] General trip & grid log proposal
Wed Jan 13 02:49:54 HKT 2021
Everyone,
followup to my previous mail, these are the record structures for the
general trip & grid logs I would like to add.
I'm going to implement this with configurable server hold times, with 0
= no server storage at all.
As this has more potential for data privacy impact as the standard 24
hour storage of telemetry records, I wouldn't enable the logs by
default, but leave this decision to the user.
Please check & provide feedback.
History type "*-LOG-Trip"
Notification type "data", subtype "log.trip"
     OvmsMetricBool*   ms_v_pos_gpslock;
     OvmsMetricFloat*  ms_v_pos_latitude;
     OvmsMetricFloat*  ms_v_pos_longitude;
     OvmsMetricFloat*  ms_v_pos_altitude;
     OvmsMetricString* ms_v_pos_location;              // Name of
current location if defined
     OvmsMetricFloat*  ms_v_pos_odometer;
     OvmsMetricFloat*  ms_v_pos_trip;                  // Trip distance
     OvmsMetricInt*    ms_v_env_drivetime;             // Trip duration
     OvmsMetricInt*    ms_v_env_drivemode;             // Active drive
profile number [1]
     OvmsMetricFloat*  ms_v_bat_soc;                   // State of
charge [%]
     OvmsMetricFloat*  ms_v_bat_range_est;             // Estimated
range [km]
     OvmsMetricFloat*  ms_v_bat_range_ideal;           // Ideal range [km]
     OvmsMetricFloat*  ms_v_bat_range_full;            // Ideal range at
100% SOC & current conditions [km]
     OvmsMetricFloat*  ms_v_bat_energy_used;           // Main battery
energy used on trip [kWh]
     OvmsMetricFloat*  ms_v_bat_energy_recd;           // Main battery
energy recovered on trip [kWh]
     OvmsMetricFloat*  ms_v_bat_coulomb_used;
     OvmsMetricFloat*  ms_v_bat_coulomb_recd;
     OvmsMetricFloat*  ms_v_bat_soh;                   // State of
health [%]
     OvmsMetricString* ms_v_bat_health;                // General
textual description of battery health
     OvmsMetricFloat*  ms_v_bat_cac;                   // Calculated
capacity [Ah]
     OvmsMetricFloat*  ms_v_bat_energy_used_total;     // Battery energy
used total (life time) [kWh]
     OvmsMetricFloat*  ms_v_bat_energy_recd_total;     // Battery energy
recovered total (life time) [kWh]
     OvmsMetricFloat*  ms_v_bat_coulomb_used_total;    // Battery
coulomb used total (life time) [Ah]
     OvmsMetricFloat*  ms_v_bat_coulomb_recd_total;    // Battery
coulomb recovered total (life time) [Ah]
     OvmsMetricFloat*  ms_v_env_temp;                  // Ambient
temperature [°C]
     OvmsMetricFloat*  ms_v_env_cabintemp;             // Cabin
temperature [°C]
     OvmsMetricFloat*  ms_v_bat_temp;                  // Battery
temperature [°C]
     OvmsMetricFloat*  ms_v_inv_temp;                  // Inverter
temperature [°C]
     OvmsMetricFloat*  ms_v_mot_temp;                  // Motor
temperature [°C]
     OvmsMetricFloat*  ms_v_charge_12v_temp;           // Temperature of
DC/DC-converter [°C]
     OvmsMetricFloat*  MAX(ms_v_tpms_temp);            // Maximum tyre
temperature
     OvmsMetricFloat*  MIN(ms_v_tpms_pressure);        // Minimum tyre
pressure
     OvmsMetricFloat*  MIN(ms_v_tpms_health);          // Minimum tyre
health
History type "*-LOG-Grid"
Notification type "data", subtype "log.grid"
     OvmsMetricString* ms_v_pos_location;            // Name of current
location if defined
     OvmsMetricString* ms_v_charge_type;               // Grid
connection type
     OvmsMetricString* ms_v_charge_state;              // charging,
topoff, done, prepare, …
     OvmsMetricString* ms_v_charge_substate;           // scheduledstop,
scheduledstart, …
     OvmsMetricString* ms_v_charge_mode;               // standard,
range, performance, storage
     OvmsMetricFloat*  ms_v_charge_climit;             // Maximum
charger output current [A]
     OvmsMetricFloat*  ms_v_charge_limit_range;        // Sufficient
range limit for current charge [km]
     OvmsMetricFloat*  ms_v_charge_limit_soc;          // Sufficient SOC
limit for current charge [%]
     OvmsMetricString* ms_v_gen_type;                  // Grid
connection type
     OvmsMetricString* ms_v_gen_state;                 // TBD
     OvmsMetricString* ms_v_gen_substate;              // TBD
     OvmsMetricString* ms_v_gen_mode;                  // TBD
     OvmsMetricFloat*  ms_v_gen_climit;                // Maximum
battery output current [A]
     OvmsMetricFloat*  ms_v_gen_limit_range;           // Min range [km]
     OvmsMetricFloat*  ms_v_gen_limit_soc;             // Min SOC [%]
     OvmsMetricInt*    ms_v_charge_time;               // Duration of
running charge session [sec]
     OvmsMetricFloat*  ms_v_charge_kwh;                // Energy charged
into battery for running session [kWh]
     OvmsMetricFloat*  ms_v_charge_kwh_grid;           // Energy drawn
from grid during running session [kWh]
     OvmsMetricFloat*  ms_v_charge_kwh_grid_total;     // Energy drawn
from grid total (life time) [kWh]
     OvmsMetricInt*    ms_v_gen_time;                  // Duration of
running generator session [sec]
     OvmsMetricFloat*  ms_v_gen_kwh;                   // Energy taken
from battery for running session [kWh]
     OvmsMetricFloat*  ms_v_gen_kwh_grid;              // Energy sent to
     OvmsMetricFloat*  ms_v_gen_kwh_grid_total;        // Energy sent to
charge [%]
range [km]
     OvmsMetricFloat*  ms_v_bat_voltage;               // Main battery
momentary voltage [V]
temperature [°C]
     OvmsMetricFloat*  ms_v_charge_temp;               // Charger
temperature [°C]
temperature [°C]
temperature [°C]
health [%]
capacity [Ah]
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210112/4ee15f62/attachment.sig>
