[Ovmsdev] Queue overflows
Mon Jan 11 19:54:04 HKT 2021
This normally happens if the Wifi connection isn't fast / stable enough
for the WebSocket stream(s), or when the web server doesn't get enough
CPU share.
It also depends on the frequency and volume of changes in the metrics &
logs, which need to be transported to the web client(s).
I had taken some measures to cut down the logging for these issues, but
I think that needs to be optimized further -- especially as logs now
also are transported to the web clients. If for example you've got two
web sessions open and the first runs into the overflow, the second will
be flooded with the warning messages and probably run into overflow as
well. I'll put that on my list.
Steve, you can try raising the queue size, but I think you didn't find
the right queue. The default size is 50, the queue is created in the
WebSocketHandler constructor (m_jobqueue).
If that helps we can raise it generally or add a config for this.
Am 11.01.21 um 11:15 schrieb Chris van der Meijden:
> Hi Steve
> I know that one too.
> Happens to me always, when I get CAN Errors when I wake up the CAN 3
> Bus on the VW e-Up.
> Greetinx from Bavaria
> Chris
> Am Montag, den 11.01.2021, 11:44 +0200 schrieb Steve Davies:
>> Hi,
>> I generally debug by watching the shell via the web interface with
>> logging from my vehicle module at debug or verbose.
>> I seem to be hitting throughput limitations for the websocket pushing
>> the output to my client, though, and see many of these:
>> log.20210110-144200:2021-01-10 14:17:39 SAST W (1630612)
>> websocket: WebSocketHandler[0x3f8531a4]: job queue overflow
>> resolved, 133 drops
>> This especially happened when I went to a charger for a test and was
>> connected to the OVMS system on 192.168.4.1 on the local Wifi AP that
>> the OVMS creates.
>> Is this to be expected? Is it more efficient to "log monitor" via
>> ssh, or do I really need a serial connection over USB?
>> I do see that the websocket overflows seem to occur when any client
>> is connected whether you are looking at the shell or not. In my case
>> I'm logging quite a lot and I guess I exceed the 100 deep queue.
>> I see that I can make the queue bigger for the websocket - would it
>> be a big problem to increase the 100 to 200 by default?
>> Thanks,
>> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210111/534705f8/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210111/534705f8/attachment-0001.sig>
