[Ovmsdev] Addition to OVMS Developer Guide
Mon Jan 4 16:24:26 HKT 2021
Steve,
Am 04.01.21 um 08:32 schrieb Stephen Casner:
>> technically may send "*" as an event, it isn't meant to be used that way, just
>> gets added to the map because of the "any event" listeners.
> I see.  If raising event "*" should be avoided, though, the
> event_raise() function should check for that.
That's an option for later, but not actually necessary, as it does no
harm. But if users see "*" in the suggestions (!) of the command, they
will interpret that as a defined feature.
> For someone writing new code who wants to listen for an event but does
> not know exactly how the event is written, the answer is not easy to
> find.  I added "event list" to help with that, but based on what you
> say here that's not really valid or complete, either.
"event list" has been more of an internal system/debug utility for me,
and it does exactly what it's description says, so that's totally valid
for me. Events should stay light weight, as in Javascript. Adding a
registry for all possible event names would add a lot of complexity
without much benefit. For example, the location framework would need to
take care to deregister events for deleted or renamed locations etc.
For someone new to the event system, this is the place to start and the
reference for defined standard framework events:
  * https://docs.openvehicles.com/en/latest/userguide/events.html
Framework events added by vehicles shall be documented on the respective
vehicle page, e.g.:
  * https://docs.openvehicles.com/en/latest/components/vehicle_renaulttwizy/docs/events.html
And custom events added by plugins shall be documented on the respective
plugin page, e.g.:
  * https://docs.openvehicles.com/en/latest/plugin/edimax/README.html#events
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210104/7cb54fbe/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210104/7cb54fbe/attachment.sig>
