[Ovmsdev] Investigating crashes. And, OVMS stopped collecting data
Fri Jan 1 18:53:21 HKT 2021
Steve,
decode your backtraces using the "a2l" script (see support folder) and
the .elf file of the build the crash occured with. The script by default
uses the latest .elf file.
You can find the crash backtraces of previous crashes on the server in
table "*-OVM-DebugCrash" (kept for 30 days).
Known crash issues:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues?q=is%3Aissue+is%3Aopen+crash
Any help with finding crash reasons is appreciated. I still am under the
impression the PSRAM bug isn't solved for all edge cases, but also am
certain we can find fatal bugs in our code as well.
Am 01.01.21 um 08:47 schrieb Steve Davies:
> Hi Ethan,
> Thanks for the info.  Naively doesn't seem like a javascript program
> should be able to crash the whole system.
> I did think about rather posting to ABRP from the server side - IE as
> data is sent to the server then code on the server sends the update to
> ABRP.
> But maybe I buried the lead, which really was to find out how I can
> get a lower level view of what crashed the board, and how to turn
> those memory addresses into a better idea as to where in the code the
> crash occurred.
> Do you know, or Michael can you help?
> Thanks,
> Steve
> On Fri, 1 Jan 2021 at 03:11, Ethan Rose <ethan at ethanrose.co.nz
> <mailto:ethan at ethanrose.co.nz>> wrote:
>     I too have crashes often when running the ABRP plugin on my NL
>     ‘13. I’ve resorted to using the LeafSpy/BT option instead on long
>     drives as it’s very unreliable.
>     Regards,
>     Ethan Rose
>>     On 1/01/2021, at 08:52, Steve Davies <steve at telviva.co.za
>>     <mailto:steve at telviva.co.za>> wrote:
>>     Well something had obviously gone off the rails since eventually
>>     the OVMS seemed to crash - couldn't ping it - and didn't come back.
>>     I power-cycled it and it came back and got a GPS lock.
>>     Was there ever discussion of a watchdog to reset things if it
>>     goes wonky?
>>     Steve
>>     On Thu, 31 Dec 2020 at 19:37, Steve Davies <steve at telviva.co.za
>>         Hi,
>>         I went for a scenic drive partly to test my OVMS I3 stuff and
>>         feeding data to ABRP.
>>         When I got home I found that ABRP had my drive ending say
>>         15km from home.  And when I checked OVMS it also thought I
>>         was in the same spot.
>>         [6315S] v.p.altitude                           65.4m
>>         [6315S] v.p.direction    97.5°
>>         [6315S] v.p.gpshdop    1
>>         [9999S] v.p.gpslock    yes
>>         [6315S] v.p.gpsmode    AN
>>         [6315S] v.p.gpsspeed   18.7052km/h
>>         [6315S] v.p.latitude   -34.0808
>>         [-----] v.p.location
>>         [6315S] v.p.longitude    18.4327
>>         [5282S] v.p.odometer   14901km
>>         [6315S] v.p.satcount   9
>>         [5195S] v.p.speed    0km/h
>>         [5195S] v.p.trip   85km
>>         You can see that the metrics are very old (I show more digits
>>         in my version).
>>         I then looked further and no metrics seemed to be updating -
>>         for instance the m.time.utc wasn't updating.
>>         I was starting to look at it when my OVMS rebooted (which
>>         seems to happen sometimes.  I've also had the logging stop -
>>         I noticed one less task so I presume that's related).
>>         Last boot was 127 second(s) ago
>>         Time at boot: 2020-12-31 19:10:09 SAST
>>         This is reset #8 since last power cycle
>>         Detected boot reason: Crash (12/12)
>>         Reset reason: Exception/panic (4)
>>         Crash counters: 1 total, 0 early
>>         Last crash: LoadProhibited exception on core 1
>>         Registers:
>>         PC : 0x400f0161 PS : 0x00060a30 A0 : 0x800f023a A1 : 0x3ffe5920
>>         A2 : 0x3ffb5738 A3 : 0x00000000 A4 : 0x3f8566a8 A5 : 0x00000001
>>         A6 : 0x3ffe5990 A7 : 0x3f8567d0 A8 : 0x800f015c A9 : 0x3ffe5910
>>         A10 : 0x00000000 A11 : 0x3f414cb1 A12 : 0x00000002 A13 :
>>         0x00000001
>>         A14 : 0x000000fe A15 : 0x3ffd4f90 SAR : 0x00000004 EXCCAUSE:
>>         0x0000001c
>>         EXCVADDR: 0x00000000 LBEG : 0x4008bcf1 LEND : 0x4008bd01
>>         LCOUNT : 0xfffffffd
>>         Backtrace:
>>         0x400f0161 0x400f0237 0x400fe87f 0x40103d4b 0x40103f02
>>         0x400fe8af 0x4013a432
>>         Version: 3.2.015-267-g39dba375-dirty/ota_1/main (build idf
>>         v3.3.4-845-gd59ed8bba-dirty Dec 26 2020 15:37:52)
>>         After this crash and restart m.time.utc was empty. I rebooted
>>         and its still missing - does it only appear once NTP syncs or
>>         something?
>>         Also I have no GPS position, gpsmode or anything like that
>>         (but I have a 3G session with the hologram sim and roaming on
>>         one of the local cellular operators).
>>         I've made sure the GPS puck is out in the open and I guess
>>         I'll wait - does the time come from the GPS?  And any ideas
>>         why I'm not getting a GPS lock suddenly?
>>         Apart from that - how do I debug crashes?  I went looking for
>>         some sort of loader memory map in the build directory to try
>>         turn the PC and backtrace addresses into something more
>>         useful but didn't pick up anything.
>>         Thanks
>>         Steve
>>     _______________________________________________
>>     OvmsDev mailing list
>>     OvmsDev at lists.openvehicles.com
>>     <mailto:OvmsDev at lists.openvehicles.com>
>>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>     <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>     OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210101/1c952222/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210101/1c952222/attachment-0001.sig>
