[Ovmsdev] Time for release 3.2.016?
Stephen Casner
casner at acm.org
Wed Feb 10 02:25:26 HKT 2021
I am trying to investigate why the SSH connection time is long (about
10 seconds). So I added some wolfssl debugging configuration changes
and calls in my copy of the master branch where I build for my bench
v3.0 hardware unit. That configuration is drastically stripped down
in order to fit into the limited RAM available; for example, Duktape
can't fit. But then I repeated Craig's timing test and found the
delay was only 4 seconds, which I think is about the same as it was
with the original version of wolfssh code. That's why I did not
notice the increase as all of my development was done on the bench
unit. The final testing was done on the v3.1 unit in my car, but I
guess I just overlooked the delay there.
So I think this means it's not a problem of crypto computation time,
so whether or not hardware acceleration is working is not the issue.
There must be some interaction among our network activities that is
causing some action to wait for a timeout or a subsequent event. I
will try to dig into this further, but testing on the unit in my car
is much less convenient. First I need to repeat the test there with
the same configuration as on the v3.0 hardware to verify if the time
is still shorter, then I will need to pare down my operational
configuration towards the stripped down one one to find the
significant case. Maybe I can group the features to make a sort of
binary search.
I've attached my stripped-down config in case that might prompt any
ideas from any of you.
I've also attached a diff for a change I'd like to make in can.cpp. I
have no use for CAN operations on my bench unit and I observed that
the CanRx task consumed 29kB even though I had unconfigured the CAN
components. This change skips out of the MyCan object constructor. I
have implemented it by defining a static const variable so the
ugliness of the preprocessor conditional can be separate at the top of
the file instead of in the midst of the code.
On Mon, 8 Feb 2021, Michael Balzer wrote:
> Steve,
> I can confirm that effect. Didn't notice, as the connect had been slow before.
> Also, mongoose appears to be locked during the whole connect, no other network
> activity can take place.
> Am 08.02.21 um 03:32 schrieb Stephen Casner:
> > On Sun, 7 Feb 2021, Michael Balzer wrote:
> > > We've had some changes recently, but apparently no issues with these (at
> > > least
> > > none reported).
> > > I'd say it's time for 3.2.016.
> > > Objections? Anything in the works that should be included?
> > Craig observed that the ssh connect time doubled from 5 seconds to 10
> > seconds. I noticed that connecting seemed slow but since it's never
> > been fast I had not run a comparison test. Would that be considered a
> > problem for release?
> > This slowness is disappointing considering that the new code is
> > supposed to include access to ESP32 hardware acceleration. I think I
> > have the configuration set correctly to include this. I will try to
> > turn on some tracing and investigate further.
> > -- Steve
# Automatically generated file; DO NOT EDIT.
# Espressif IoT Development Framework Configuration
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# SDK tool configuration
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_PYTHON="python"
CONFIG_MAKE_WARN_UNDEFINED_VARIABLES=y
# Application manager
CONFIG_APP_COMPILE_TIME_DATE=y
CONFIG_APP_EXCLUDE_PROJECT_VER_VAR=
CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR=
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
# Bootloader config
CONFIG_LOG_BOOTLOADER_LEVEL_NONE=
CONFIG_LOG_BOOTLOADER_LEVEL_ERROR=
CONFIG_LOG_BOOTLOADER_LEVEL_WARN=y
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=
CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG=
CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE=
CONFIG_LOG_BOOTLOADER_LEVEL=2
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_8V=
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
CONFIG_BOOTLOADER_FACTORY_RESET=
CONFIG_BOOTLOADER_APP_TEST=
CONFIG_BOOTLOADER_WDT_ENABLE=y
CONFIG_BOOTLOADER_WDT_DISABLE_IN_USER_CODE=
CONFIG_BOOTLOADER_WDT_TIME_MS=9000
CONFIG_APP_ROLLBACK_ENABLE=
# Security features
CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT=
CONFIG_SECURE_BOOT_ENABLED=
CONFIG_FLASH_ENCRYPTION_ENABLED=
# Serial flasher config
CONFIG_ESPTOOLPY_PORT="/dev/tty.SLAB_USBtoUART"
CONFIG_ESPTOOLPY_BAUD_115200B=
CONFIG_ESPTOOLPY_BAUD_230400B=
CONFIG_ESPTOOLPY_BAUD_921600B=y
CONFIG_ESPTOOLPY_BAUD_2MB=
CONFIG_ESPTOOLPY_BAUD_OTHER=
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_BAUD=921600
CONFIG_ESPTOOLPY_COMPRESSED=y
CONFIG_FLASHMODE_QIO=
CONFIG_FLASHMODE_QOUT=
CONFIG_FLASHMODE_DIO=y
CONFIG_FLASHMODE_DOUT=
CONFIG_ESPTOOLPY_FLASHMODE="dio"
CONFIG_ESPTOOLPY_FLASHFREQ_80M=
CONFIG_ESPTOOLPY_FLASHFREQ_40M=y
CONFIG_ESPTOOLPY_FLASHFREQ_26M=
CONFIG_ESPTOOLPY_FLASHFREQ_20M=
CONFIG_ESPTOOLPY_FLASHFREQ="40m"
CONFIG_ESPTOOLPY_FLASHSIZE_1MB=
CONFIG_ESPTOOLPY_FLASHSIZE_2MB=
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=
CONFIG_ESPTOOLPY_FLASHSIZE_16MB=y
CONFIG_ESPTOOLPY_FLASHSIZE="16MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
CONFIG_ESPTOOLPY_BEFORE_NORESET=
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
CONFIG_ESPTOOLPY_AFTER_NORESET=
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_MONITOR_BAUD_9600B=
CONFIG_MONITOR_BAUD_57600B=
CONFIG_MONITOR_BAUD_115200B=y
CONFIG_MONITOR_BAUD_230400B=
CONFIG_MONITOR_BAUD_921600B=
CONFIG_MONITOR_BAUD_2MB=
CONFIG_MONITOR_BAUD_OTHER=
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=
CONFIG_PARTITION_TABLE_TWO_OTA=
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# Compiler options
CONFIG_OPTIMIZATION_LEVEL_DEBUG=
CONFIG_OPTIMIZATION_LEVEL_RELEASE=y
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
CONFIG_OPTIMIZATION_ASSERTIONS_SILENT=
CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED=
CONFIG_CXX_EXCEPTIONS=
CONFIG_STACK_CHECK_NONE=y
CONFIG_STACK_CHECK_NORM=
CONFIG_STACK_CHECK_STRONG=
CONFIG_STACK_CHECK_ALL=
CONFIG_STACK_CHECK=
CONFIG_WARN_WRITE_STRINGS=
CONFIG_DISABLE_GCC8_WARNINGS=
# Component config
# Application Level Tracing
CONFIG_ESP32_APPTRACE_DEST_TRAX=
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_ENABLE=
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_AWS_IOT_SDK=
# Bluetooth
CONFIG_BT_ENABLED=
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CTRL_AUTO_LATENCY_EFF=
CONFIG_BTDM_CTRL_LEGACY_AUTH_VENDOR_EVT_EFF=
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BT_RESERVE_DRAM=0
CONFIG_BLE_MESH=
# Driver configurations
# ADC configuration
CONFIG_ADC_FORCE_XPD_FSM=
CONFIG_ADC2_DISABLE_DAC=y
# SPI configuration
CONFIG_SPI_MASTER_IN_IRAM=
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
CONFIG_SPI_SLAVE_IN_IRAM=
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
# eFuse Bit Manager
CONFIG_EFUSE_CUSTOM_TABLE=
CONFIG_EFUSE_VIRTUAL=
CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE=
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT=
CONFIG_EFUSE_MAX_BLK_LEN=192
# ESP32-specific
CONFIG_IDF_TARGET_ESP32=y
CONFIG_ESP32_REV_MIN_0=y
CONFIG_ESP32_REV_MIN_1=
CONFIG_ESP32_REV_MIN_2=
CONFIG_ESP32_REV_MIN_3=
CONFIG_ESP32_REV_MIN=0
CONFIG_ESP32_DPORT_WORKAROUND=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_80=
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_SPIRAM_SUPPORT=
CONFIG_MEMMAP_TRACEMEM=
CONFIG_MEMMAP_TRACEMEM_TWOBANKS=
CONFIG_ESP32_TRAX=
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
CONFIG_TWO_UNIVERSAL_MAC_ADDRESS=
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=4096
CONFIG_MAIN_TASK_STACK_SIZE=4096
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF=
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR=
CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF=
CONFIG_NEWLIB_STDIN_LINE_ENDING_LF=
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
CONFIG_NEWLIB_NANO_FORMAT=
CONFIG_CONSOLE_UART_DEFAULT=y
CONFIG_CONSOLE_UART_CUSTOM=
CONFIG_CONSOLE_UART_NONE=
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_ULP_COPROC_ENABLED=
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_ESP32_PANIC_PRINT_HALT=
CONFIG_ESP32_PANIC_PRINT_REBOOT=
CONFIG_ESP32_PANIC_SILENT_REBOOT=
CONFIG_ESP32_PANIC_GDBSTUB=y
CONFIG_ESP32_PANIC_CALLBACK=y
CONFIG_GDBSTUB_SUPPORT_TASKS=y
CONFIG_GDBSTUB_MAX_TASKS=32
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_ESP32_DEBUG_STUBS_ENABLE=y
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=500
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_PANIC=y
CONFIG_TASK_WDT_TIMEOUT_S=60
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
CONFIG_BROWNOUT_DET_LVL_SEL_1=
CONFIG_BROWNOUT_DET_LVL_SEL_2=
CONFIG_BROWNOUT_DET_LVL_SEL_3=
CONFIG_BROWNOUT_DET_LVL_SEL_4=
CONFIG_BROWNOUT_DET_LVL_SEL_5=
CONFIG_BROWNOUT_DET_LVL_SEL_6=
CONFIG_BROWNOUT_DET_LVL_SEL_7=
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC=
CONFIG_ESP32_TIME_SYSCALL_USE_FRC1=
CONFIG_ESP32_TIME_SYSCALL_USE_NONE=
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL=
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC=
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256=
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=0
CONFIG_ESP32_XTAL_FREQ_40=
CONFIG_ESP32_XTAL_FREQ_26=
CONFIG_ESP32_XTAL_FREQ_AUTO=y
CONFIG_ESP32_XTAL_FREQ=0
CONFIG_DISABLE_BASIC_ROM_CONSOLE=
CONFIG_NO_BLOBS=
CONFIG_ESP_TIMER_PROFILING=
CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS=
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
# Wi-Fi
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=4
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_CSI_ENABLED=y
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1=
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
CONFIG_ESP32_WIFI_DEBUG_LOG_ENABLE=
CONFIG_ESP32_WIFI_IRAM_OPT=y
CONFIG_ESP32_WIFI_RX_IRAM_OPT=y
# PHY
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION=
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# Power Management
CONFIG_PM_ENABLE=
CONFIG_ESPCAN=y
CONFIG_ESP_CAN_RXD_PIN_NUM=26
CONFIG_ESP_CAN_TXD_PIN_NUM=25
CONFIG_CAN_SPEED_100KBPS=y
CONFIG_CAN_SPEED_125KBPS=
CONFIG_CAN_SPEED_250KBPS=
CONFIG_CAN_SPEED_500KBPS=
CONFIG_CAN_SPEED_800KBPS=
CONFIG_CAN_SPEED_1000KBPS=
CONFIG_CAN_SPEED_USER_KBPS=
# ADC-Calibration
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# Event Loop Library
CONFIG_EVENT_LOOP_PROFILING=
# ESP HTTP client
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH=
# HTTP Server
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
CONFIG_HTTPD_LOG_PURGE_DATA=
# ESP HTTPS OTA
CONFIG_OTA_ALLOW_HTTP=
# Core dump
CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH=
CONFIG_ESP32_ENABLE_COREDUMP_TO_UART=
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_ESP32_ENABLE_COREDUMP=
# Ethernet
CONFIG_DMA_RX_BUF_NUM=10
CONFIG_DMA_TX_BUF_NUM=10
CONFIG_EMAC_L2_TO_L3_RX_BUF_MODE=
CONFIG_EMAC_CHECK_LINK_PERIOD_MS=2000
CONFIG_EMAC_TASK_PRIORITY=20
CONFIG_EMAC_TASK_STACK_SIZE=3072
# FAT Filesystem support
CONFIG_FATFS_CODEPAGE_DYNAMIC=
CONFIG_FATFS_CODEPAGE_437=
CONFIG_FATFS_CODEPAGE_720=
CONFIG_FATFS_CODEPAGE_737=
CONFIG_FATFS_CODEPAGE_771=
CONFIG_FATFS_CODEPAGE_775=
CONFIG_FATFS_CODEPAGE_850=y
CONFIG_FATFS_CODEPAGE_852=
CONFIG_FATFS_CODEPAGE_855=
CONFIG_FATFS_CODEPAGE_857=
CONFIG_FATFS_CODEPAGE_860=
CONFIG_FATFS_CODEPAGE_861=
CONFIG_FATFS_CODEPAGE_862=
CONFIG_FATFS_CODEPAGE_863=
CONFIG_FATFS_CODEPAGE_864=
CONFIG_FATFS_CODEPAGE_865=
CONFIG_FATFS_CODEPAGE_866=
CONFIG_FATFS_CODEPAGE_869=
CONFIG_FATFS_CODEPAGE_932=
CONFIG_FATFS_CODEPAGE_936=
CONFIG_FATFS_CODEPAGE_949=
CONFIG_FATFS_CODEPAGE_950=
CONFIG_FATFS_CODEPAGE=850
CONFIG_FATFS_LFN_NONE=
CONFIG_FATFS_LFN_HEAP=y
CONFIG_FATFS_LFN_STACK=
CONFIG_FATFS_MAX_LFN=128
CONFIG_FATFS_API_ENCODING_ANSI_OEM=y
CONFIG_FATFS_API_ENCODING_UTF_16=
CONFIG_FATFS_API_ENCODING_UTF_8=
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=
# Modbus configuration
CONFIG_MB_QUEUE_LENGTH=20
CONFIG_MB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_MB_SERIAL_BUF_SIZE=256
CONFIG_MB_SERIAL_TASK_PRIO=10
CONFIG_MB_CONTROLLER_SLAVE_ID_SUPPORT=
CONFIG_MB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_MB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_MB_CONTROLLER_STACK_SIZE=4096
CONFIG_MB_EVENT_QUEUE_TIMEOUT=20
CONFIG_MB_TIMER_PORT_ENABLED=y
CONFIG_MB_TIMER_GROUP=0
CONFIG_MB_TIMER_INDEX=0
# FreeRTOS
CONFIG_FREERTOS_UNICORE=
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_CORETIMER_0=y
CONFIG_FREERTOS_CORETIMER_1=
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK=
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE=
CONFIG_FREERTOS_ASSERT_DISABLE=
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1024
CONFIG_FREERTOS_ISR_STACKSIZE=1536
CONFIG_FREERTOS_LEGACY_HOOKS=
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_SUPPORT_STATIC_ALLOCATION=
CONFIG_TIMER_TASK_PRIORITY=20
CONFIG_TIMER_TASK_STACK_DEPTH=3072
CONFIG_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
CONFIG_FREERTOS_USE_TRACE_FACILITY=y
CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=y
CONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID=
CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y
CONFIG_FREERTOS_RUN_TIME_STATS_USING_ESP_TIMER=y
CONFIG_FREERTOS_RUN_TIME_STATS_USING_CPU_CLK=
CONFIG_FREERTOS_DEBUG_INTERNALS=
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE=
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=
CONFIG_HEAP_POISONING_LIGHT=y
CONFIG_HEAP_POISONING_COMPREHENSIVE=
CONFIG_HEAP_TRACING=
CONFIG_HEAP_TASK_TRACKING=y
# libsodium
CONFIG_LIBSODIUM_USE_MBEDTLS_SHA=y
# Log output
CONFIG_LOG_DEFAULT_LEVEL_NONE=
CONFIG_LOG_DEFAULT_LEVEL_ERROR=
CONFIG_LOG_DEFAULT_LEVEL_WARN=
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
CONFIG_LOG_DEFAULT_LEVEL_DEBUG=
CONFIG_LOG_DEFAULT_LEVEL_VERBOSE=
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
# LWIP
CONFIG_L2_TO_L3_COPY=
CONFIG_ETHARP_SUPPORT_VLAN=
CONFIG_LWIP_IRAM_OPTIMIZATION=
CONFIG_LWIP_MAX_SOCKETS=10
CONFIG_LWIP_RANDOMIZE_INITIAL_LOCAL_PORTS=y
CONFIG_USE_ONLY_LWIP_SELECT=
CONFIG_LWIP_SO_LINGER=
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=
CONFIG_LWIP_IP4_FRAG=y
CONFIG_LWIP_IP6_FRAG=y
CONFIG_LWIP_IP4_REASSEMBLY=
CONFIG_LWIP_IP6_REASSEMBLY=
CONFIG_LWIP_STATS=
CONFIG_LWIP_ETHARP_TRUST_IP_MAC=y
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=
CONFIG_LWIP_DHCP_RESTORE_LAST_IP=
# DHCP server
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
CONFIG_LWIP_AUTOIP=
CONFIG_LWIP_IPV6_AUTOCONFIG=
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_TCP_ISN_HOOK=y
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=8
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1436
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES=
CONFIG_TCP_OVERSIZE_MSS=y
CONFIG_TCP_OVERSIZE_QUARTER_MSS=
CONFIG_TCP_OVERSIZE_DISABLE=
CONFIG_LWIP_TCP_RTO_TIME=3000
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=2560
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=
CONFIG_TCPIP_TASK_AFFINITY_CPU0=
CONFIG_TCPIP_TASK_AFFINITY_CPU1=y
CONFIG_TCPIP_TASK_AFFINITY=0x1
CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE=3
CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS=5
CONFIG_PPP_SUPPORT=y
CONFIG_PPP_NOTIFY_PHASE_SUPPORT=
CONFIG_PPP_PAP_SUPPORT=y
CONFIG_PPP_CHAP_SUPPORT=y
CONFIG_PPP_MSCHAP_SUPPORT=
CONFIG_PPP_MPPE_SUPPORT=
CONFIG_PPP_DEBUG_ON=
# ICMP
CONFIG_LWIP_MULTICAST_PING=
CONFIG_LWIP_BROADCAST_PING=
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# SNTP
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
CONFIG_LWIP_ESP_LWIP_ASSERT=y
CONFIG_OVMS=y
CONFIG_OVMS_VERSION_TAG="main"
# Hardware Support
CONFIG_OVMS_HW_BASE_3_0=y
CONFIG_OVMS_HW_BASE_3_1=
CONFIG_OVMS_HW_CONSOLE_QUEUE_SIZE=100
CONFIG_OVMS_HW_ASYNC_QUEUE_SIZE=100
CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=20
CONFIG_OVMS_HW_NETMANAGER_QUEUE_SIZE=10
CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=2
CONFIG_OVMS_HW_CAN_TX_QUEUE_SIZE=2
# System Options
CONFIG_OVMS_SYS_COMMAND_STACK_SIZE=6144
CONFIG_OVMS_LOGFILE_QUEUE_SIZE=100
CONFIG_OVMS_LOGFILE_TASK_PRIORITY=2
# Library Support
CONFIG_OVMS_SC_JAVASCRIPT_NONE=y
CONFIG_OVMS_SC_JAVASCRIPT_DUKTAPE=
CONFIG_OVMS_SC_GPL_MONGOOSE=y
CONFIG_MG_ENABLE_FILESYSTEM=y
CONFIG_MG_ENABLE_DIRECTORY_LISTING=y
CONFIG_MG_ENABLE_SSL=y
CONFIG_MG_ENABLE_DEBUG=
CONFIG_OVMS_SC_GPL_WOLF=y
CONFIG_OVMS_SC_ZIP=y
# Vehicle Support
CONFIG_OVMS_VEHICLE_NONE=y
CONFIG_OVMS_VEHICLE_OBDII=
CONFIG_OVMS_VEHICLE_TRACK=y
CONFIG_OVMS_VEHICLE_DEMO=y
CONFIG_OVMS_VEHICLE_TESLAROADSTER=y
CONFIG_OVMS_VEHICLE_TESLAMODELS=
CONFIG_OVMS_VEHICLE_TESLAMODEL3=
CONFIG_OVMS_VEHICLE_NISSANLEAF=
CONFIG_OVMS_VEHICLE_KIASOULEV=
CONFIG_OVMS_VEHICLE_VOLTAMPERA=
CONFIG_OVMS_VEHICLE_THINKCITY=
CONFIG_OVMS_VEHICLE_SMARTED=
CONFIG_OVMS_VEHICLE_SMARTEQ=
CONFIG_OVMS_VEHICLE_MITSUBISHI=
CONFIG_OVMS_VEHICLE_ZEVA=
CONFIG_OVMS_VEHICLE_FIAT500=
CONFIG_OVMS_VEHICLE_VWEUP=
CONFIG_OVMS_VEHICLE_MERCEDESB250E=
CONFIG_OVMS_VEHICLE_CADILLAC_C2_CTS=
CONFIG_OVMS_VEHICLE_CHEVROLET_C6_CORVETTE=
CONFIG_OVMS_VEHICLE_MG_EV=
CONFIG_OVMS_VEHICLE_BMWI3=
CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144
CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=2
# Component Options
CONFIG_OVMS_COMP_WIFI=y
CONFIG_OVMS_COMP_MAX7317=y
CONFIG_OVMS_COMP_MAX7317_MONITOR_INTERVAL=50
CONFIG_OVMS_COMP_ESP32CAN=
CONFIG_OVMS_COMP_MCP2515=
CONFIG_OVMS_COMP_EXTERNAL_SWCAN=
CONFIG_OVMS_COMP_ADC=
CONFIG_OVMS_COMP_EXT12V=
CONFIG_OVMS_COMP_SERVER=y
CONFIG_OVMS_COMP_SERVER_V2=y
CONFIG_OVMS_COMP_SERVER_V3=
CONFIG_OVMS_COMP_OTA=y
CONFIG_OVMS_COMP_LOCATION=y
CONFIG_OVMS_COMP_WEBSERVER=y
CONFIG_OVMS_COMP_MDNS=y
CONFIG_OVMS_COMP_TELNET=y
CONFIG_OVMS_COMP_SSH=y
CONFIG_OVMS_COMP_PUSHOVER=
CONFIG_OVMS_COMP_TPMS=y
CONFIG_OVMS_COMP_MODEM_SIMCOM=y
CONFIG_OVMS_COMP_SDCARD=y
CONFIG_OVMS_COMP_OBD2ECU=
CONFIG_OVMS_COMP_RE_TOOLS=
CONFIG_OVMS_COMP_RE_TOOLS_PID=
CONFIG_OVMS_COMP_RE_TOOLS_TESTERPRESENT=
CONFIG_OVMS_COMP_EDITOR=y
CONFIG_OVMS_COMP_CANOPEN=
# Developer Options
CONFIG_OVMS_DEV_SECUREASYNC=y
CONFIG_OVMS_DEV_CONFIGVFS=y
CONFIG_OVMS_DEV_SDCARDSCRIPTS=
CONFIG_OVMS_DEV_DEBUGEVENTS=
CONFIG_OVMS_DEV_DEBUGNOTIFICATIONS=
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC=
CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC=
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=4096
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
CONFIG_MBEDTLS_DEBUG=
CONFIG_MBEDTLS_ECP_RESTARTABLE=
CONFIG_MBEDTLS_CMAC_C=
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=
CONFIG_MBEDTLS_HARDWARE_SHA=
CONFIG_MBEDTLS_HAVE_TIME=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
CONFIG_MBEDTLS_TLS_SERVER_ONLY=
CONFIG_MBEDTLS_TLS_CLIENT_ONLY=
CONFIG_MBEDTLS_TLS_DISABLED=
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
CONFIG_MBEDTLS_PSK_MODES=y
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
CONFIG_MBEDTLS_SSL_PROTO_SSL3=
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
CONFIG_MBEDTLS_SSL_PROTO_DTLS=
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
CONFIG_MBEDTLS_CAMELLIA_C=
CONFIG_MBEDTLS_DES_C=
CONFIG_MBEDTLS_RC4_DISABLED=y
CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT=
CONFIG_MBEDTLS_RC4_ENABLED=
CONFIG_MBEDTLS_BLOWFISH_C=
CONFIG_MBEDTLS_XTEA_C=
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_RIPEMD160_C=
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# mDNS
CONFIG_MDNS_MAX_SERVICES=10
# ESP-MQTT Configurations
CONFIG_MQTT_PROTOCOL_311=
CONFIG_MQTT_TRANSPORT_SSL=
CONFIG_MQTT_TRANSPORT_WEBSOCKET=
CONFIG_MQTT_USE_CUSTOM_CONFIG=
CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED=
CONFIG_MQTT_CUSTOM_OUTBOX=
# NVS
# OpenSSL
CONFIG_OPENSSL_DEBUG=
CONFIG_OPENSSL_ASSERT_DO_NOTHING=y
CONFIG_OPENSSL_ASSERT_EXIT=
# PThreads
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0=
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1=
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
# SPI Flash driver
CONFIG_SPI_FLASH_VERIFY_WRITE=y
CONFIG_SPI_FLASH_LOG_FAILED_WRITE=
CONFIG_SPI_FLASH_WARN_SETTING_ZERO_TO_ONE=
CONFIG_SPI_FLASH_ENABLE_COUNTERS=
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS=
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED=
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=3
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
CONFIG_SPIFFS_CACHE_STATS=
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
CONFIG_SPIFFS_GC_STATS=
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
CONFIG_SPIFFS_DBG=
CONFIG_SPIFFS_API_DBG=
CONFIG_SPIFFS_GC_DBG=
CONFIG_SPIFFS_CACHE_DBG=
CONFIG_SPIFFS_CHECK_DBG=
CONFIG_SPIFFS_TEST_VISUALISATION=
# TCP/IP Adapter
CONFIG_IP_LOST_TIMER_INTERVAL=60
CONFIG_TCPIP_LWIP=y
# Unity unit testing library
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
CONFIG_UNITY_ENABLE_COLOR=
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
CONFIG_UNITY_ENABLE_FIXTURE=
# Virtual file system
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
# Wear Levelling
CONFIG_WL_SECTOR_SIZE_512=
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
# Wi-Fi Provisioning Manager
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
# Supplicant
CONFIG_WPA_WPS_WARS=
diff --git a/vehicle/OVMS.V3/components/can/src/can.cpp b/vehicle/OVMS.V3/components/can/src/can.cpp
index faf0f306..65c3ed5c 100644
--- a/vehicle/OVMS.V3/components/can/src/can.cpp
+++ b/vehicle/OVMS.V3/components/can/src/can.cpp
@@ -49,6 +49,14 @@ static const char *TAG = "can";
#include "ovms_command.h"
#include "metrics_standard.h"
+#if defined(CONFIG_OVMS_COMP_ESP32CAN) || \
+ defined(CONFIG_OVMS_COMP_MCP2515) || \
+ defined(CONFIG_OVMS_COMP_EXTERNAL_SWCAN)
+static const bool includeCAN = true;
+#else
+static const bool includeCAN = false;
+#endif
can MyCan __attribute__ ((init_priority (4510)));
@@ -788,6 +796,8 @@ void can::CAN_rxtask(void *pvParameters)
can::can()
+ if (!includeCAN) return;
ESP_LOGI(TAG, "Initialising CAN (4510)");
m_logger_id = 1;
