[Ovmsdev] Time for release 3.2.016?
Wed Feb 10 01:40:24 HKT 2021
I found the reason for the false theft/flatbed alert in my case by
checking my telemetry archive: the car lost GPS on the road. Coordinates
were stale when I parked the car. The stale coordinates were taken as
the initial park coordinates, causing an alert when the GPS receiver
delivered the next valid data (the actual park position).
So the bad antenna placement actually was the cause in my case, but we
can solve that in software.
I've just pushed a fix (untested) for this, consisting of a) making the
location module aware of parking coordinate staleness and b) lowering
the staleness thresholds for the GPS metrics to 10 seconds.
Please verify.
Am 09.02.21 um 10:29 schrieb Michael Balzer:
> I had the alert once with my Mii, also shortly after parking. With the
> module being mounted with the GPS antenna placed under the hood, I
> assumed that to be the cause.
> I doubt it, but I'll check if any of our changes could have had an
> impact on the GPS movement detection.
> Regarding open changes to be included in 3.2.016: sharkcow is
> currently working on finishing the UpMiiGo TPMS feature, it's already
> been tested so we'll wait for that.
> Am 09.02.21 um 09:57 schrieb sharkcow:
>> Hi all,
>> > Twice in the last few weeks I've gotten the "possible theft/flatbed"
>> alert just as I was backing out of the garage. I have never received
>> that alert before. I hadn't posted anything yet because I was waiting to
>> drive the other car and see if has the same problem.
>> I get this too every once in a while with my e-Up. Mostly shortly after
>> parking, I think (and tragically, the one time I'd have needed it
>> because I actually _did_ get towed, I had crashed OVMS into a boot loop
>> just before :-/).
>> sharkcow
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210209/1fe2059a/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210209/1fe2059a/attachment-0001.sig>
