[Ovmsdev] ESP32/3 benchmark (was: External Wifi antenna)
Mon Feb 8 21:20:44 HKT 2021
Craig,
Am 31.01.21 um 19:58 schrieb Craig Leres:
>> Please also disable the PSRAM bug workaround and maybe do some
>> performance comparison. SPIRAM operations should run much faster
>> without the workaround.
> What kind of tests should I run?
I've just added an execution time output to my SPIRAM test command,
which was meant to trigger the memory corruption, but can also serve as
a memory benchmark.
To get comparable results, run the tests after booting with "config set
auto init no" (you'll need a USB connection).
Tests with my results (ESP32/1, SPIRAM fix enabled, debug output removed):
OVMS# test string 1000 2
finished 1000 loops for mode 2 using extram in 33503 ms
OVMS# test string 5000 4
finished 5000 loops for mode 4 using extram in 30268 ms
OVMS# test string 25000 6
finished 25000 loops for mode 6 using extram in 34681 ms
Test mode 2 reads from metrics (involves locks & stream formatting),
mode 4 reads a fixed string from the config, mode 6 is mostly pure
memory copying.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210208/555fd3c3/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210208/555fd3c3/attachment.sig>
