[Ovmsdev] Duplicate timer callbacks (was: Branch for-v3.3 network issues)
    Fri Dec 31 02:25:52 HKT 2021
Followup to…
Am 26.09.21 um 19:28 schrieb Michael Balzer:
> If so, my conclusions so far would be:
> a) we've got a real heap corruption issue that sometimes gets
> triggered by the test. I've had it twice around the same place, i.e.
> within the scheduled event processing. I'll check my code.
> Am 26.09.21 um 18:46 schrieb Craig Leres:
>> Second crash on the production module, CORRUPT HEAP after ~350 minutes.
>> OVMS# CORRUPT HEAP: Bad head at 0x3f8adc78. Expected 0xabba1234 got
>> 0x3f8adcc0
>> abort() was called at PC 0x400844c3 on core 0
I've found the heap corruption source and a new bug class:
The corruption was caused by a duplicate free() (here via delete), which
was basically impossible: it was the free() call for the event message
for a delayed event delivery. There is exactly one producer
(OvmsEvents::ScheduleEvent) and exactly one consumer
(OvmsEvents::SignalScheduledEvent), which is called exactly once -- when
the single shot timer expires.
In theory. _In reality, the timer callback occasionally gets executed
twice_. To exclude every possible race condition, I enclosed both
producer & consumer into a semaphore lock. I then changed the code in
order to clear the timer payload as soon as it's read, and added a test
for a NULL payload -- and voila, the timer callback now gets
occasionally called with a NULL payload, which is also impossible as the
allocation result is checked in the producer.
I've had no luck reproducing this in a reduced test project, even with
multiple auto reload timers and distribution over both cores, but I
still see no other explanation than a bug in the FreeRTOS timer service
(or the Espressif FreeRTOS multi core adaption). Ah, and yes, this
occurs on the ESP32/r3 as well.
You should be able to reproduce the effect using the same event test
loop as for the Duktape TypeError issue:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/474#issuecomment-1002687055
My workaround prevents crashes and outputs a log entry when the NULL
payload is detected.
Example log excerpt:
script eval 'testcnt=0; PubSub.subscribe("usr.testev", function(ev) {
var ms=Number(ev.substr(11))||10; if (++testcnt % (3*1000/ms) == 0)
print(ev + ": " + testcnt); OvmsEvents.Raise("usr.testev."+ms, ms); })'
script eval 'testcnt=0; OvmsEvents.Raise("usr.testev.10")'
I (13493019) events: ScheduleEvent: creating new timer
*W (13495919) events: SignalScheduledEvent: duplicate callback
invocation detected*
I (13497029) ovms-duk-util: [eval:1:] usr.testev.10: 300
I (13501109) housekeeping: 2021-12-30 18:12:35 CET (RAM: 8b=64448-67004
32b=6472)
I (13521779) ovms-duk-util: [eval:1:] usr.testev.10: 2100
I (13525809) ovms-duk-util: [eval:1:] usr.testev.10: 2400
*W (13527579) events: SignalScheduledEvent: duplicate callback
invocation detected**
**W (13527629) events: SignalScheduledEvent: duplicate callback
I (13529839) ovms-duk-util: [eval:1:] usr.testev.10: 2700
I (13533329) ovms-server-v2: Incoming Msg: MP-0 AFA
I (13579149) ovms-duk-util: [eval:1:] usr.testev.10: 6300
I (13583319) ovms-duk-util: [eval:1:] usr.testev.10: 6600
*W (13584679) events: SignalScheduledEvent: duplicate callback
I (13587439) ovms-duk-util: [eval:1:] usr.testev.10: 6900
I (13591589) ovms-duk-util: [eval:1:] usr.testev.10: 7200
I (13714299) ovms-duk-util: [eval:1:] usr.testev.10: 16200
I (13718339) ovms-duk-util: [eval:1:] usr.testev.10: 16500
*W (13718719) events: SignalScheduledEvent: duplicate callback
I (13722459) ovms-duk-util: [eval:1:] usr.testev.10: 16800
I (13726509) ovms-duk-util: [eval:1:] usr.testev.10: 17100
I (13743149) ovms-duk-util: [eval:1:] usr.testev.10: 18300
I (13747129) ovms-duk-util: [eval:1:] usr.testev.10: 18600
*W (13748979) events: SignalScheduledEvent: duplicate callback
I (13751299) ovms-duk-util: [eval:1:] usr.testev.10: 18900
I (13755349) ovms-duk-util: [eval:1:] usr.testev.10: 19200
I (13784029) ovms-duk-util: [eval:1:] usr.testev.10: 21300
I (13788059) ovms-duk-util: [eval:1:] usr.testev.10: 21600
*W (13791409) events: SignalScheduledEvent: duplicate callback
I (13792179) ovms-duk-util: [eval:1:] usr.testev.10: 21900
I (13796239) ovms-duk-util: [eval:1:] usr.testev.10: 22200
The bug frequency differs from boot to boot, but as you can see can be
very high. I've had runs with ~ 1 occurrence every 300.000 callbacks,
and runs like the above with ~ 1 every 3.000 callbacks.
If this is a common effect with timer callbacks, that may cause some of
the remaining issues. It's possible this only happens with single shot
timers, haven't checked our periodic timers yet.
Any additional input on this is welcome.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211230/d0dc429d/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211230/d0dc429d/attachment.sig>
