[Ovmsdev] Coding help
Mon Apr 5 14:50:25 HKT 2021
Shane,
what makes you think so?
Am 04.04.21 um 20:47 schrieb Shane @ Kilve Engineering:
> Hi Michael,
> Me again
> It look like the bus framework does the calc incorrect?
> Surly stddev should be 0.0435
> And stddev.max should be 0.0437147V
> v.b.p.voltage.avg 4.23496V
> v.b.p.voltage.grad -0.00026V
> v.b.p.voltage.max 4.24V
> v.b.p.voltage.min 4.2V
> v.b.p.voltage.stddev 0.00435V
> v.b.p.voltage.stddev.max 0.00437147V
> Regards
> Shane
>> On 4 Apr 2021, at 13:26, Michael Balzer <dexter at expeedo.de
>> Shane,
>> vector metrics in general can be set by passing a vector or by using
>> the element setters provided (see API).
>> But you don't need to set the cell max/min/stddev metrics at all, you
>> only need to feed the cell voltages (and/or temperatures). The BMS
>> framework automatically extracts all statistics values from them.
>> Btw, regarding your cell voltages:
>>> 748[7c8]:e113 10 90 10 92 10 93 10 93 10 8e 10 92 10 8f 10 90 10 92
>>> 10 6c 10 93 10 93 10 8f 10 91 10 92 10 92 10 92 10 92 10 92 10 92 10
>>> 90 10 8e 10 90 10 92 10 8d 10 90 10 91 10 8f 10 8e 10 8f 10 91 10 90
>>> 10 90 10 91 10 8e 10 91 10 8e 10 91 10 90 10 8e 10 90 10 92 10 90 10
>>> 94 10 91 10 91 10 93 10 90 10 91 10 90 10 8f 10 93 10 92 10 8e 10 90
>>> 10 91 10 8b 10 92 10 90 10 91 10 8e 10 90 10 90 10 90 10 91 10 90 10
>>> 8f 10 90 10 90 10 8e 10 92 10 8e 10 91 10 89 10 91 10 91 10 91 10 8d
>>> 10 8f 10 8d 10 86 10 8a 10 8e 10 8f 10 91 10 90 10 92 10 94 10 88 10
>>> 8f 10 94 10 91 10 91 10 91 10 93 10 91 00 00 00 00 00 00 00 00 00 00
>>> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>> This looks like 96 cells with a factor of 0.001, e.g. 0x1090 = 4240 *
>> 0.001 = 4.24V.
>> Assuming you fix your IncomingPollReply() handler to actually use the
>> rxbuf string and you copy the RXB_* macros from the Ioniq VFL code,
>> you can simply do this to process the values:
>> case 0xe113:
>> // Read battery cell voltages 1-96:
>> BmsRestartCellVoltages();
>> for (int i = 0; i < 96; i++) {
>> BmsSetCellVoltage(i, RXB_UINT16(i*2) * 0.001f);
>> break;
>> Doesn't look that hard, does it?
>> Am 04.04.21 um 12:37 schrieb Shane @ Kilve Engineering:
>>> morning peeps, sorry for the newbie question whats different about
>>> the cell vmax/vmin i see in metrics_standard.h its a vector?
>>> (OvmsMetricVector<float>* ms_v_bat_cell_vmax; // Cell maximum
>>> voltages [V])
>>> does that mean i have ot handle these different? if so how?
>>> as all i get is errors trying to setvalue to this metric
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:*
>>> In member function '*void
>>> OvmsVehicleMaxed3::IncomingBmsReply(canbus*, uint16_t, uint16_t,
>>> uint8_t*, uint8_t, uint16_t)*':
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:159:82:*
>>> *error: *no matching function for call to
>>> '*OvmsMetricVector<float>::SetValue(float)*'
>>> StandardMetrics.ms_v_bat_cell_vmax->SetValue((float)value2 / 1000);
>>> In file included from
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle/vehicle.h:40:0*,
>>> from
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.h:32*,
>>> from
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:32*:
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/main/ovms_metrics.h:747:18:*
>>> *note: *candidate: bool OvmsMetricVector<ElemType,
>>> Allocator>::SetValue(std::__cxx11::string) [with ElemType = float;
>>> Allocator = std::allocator<float>; std::__cxx11::string =
>>> std::__cxx11::basic_string<char>]
>>> virtual bool SetValue(std::string value)
>>> *note: * no known conversion for argument 1 from '*float*' to
>>> '*std::__cxx11::string {aka std::__cxx11::basic_string<char>}*'
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/main/ovms_metrics.h:763:10:*
>>> Allocator>::SetValue(const std::vector<_Tp, _Alloc>&, metric_unit_t)
>>> [with ElemType = float; Allocator = std::allocator<float>]
>>> bool SetValue(const std::vector<ElemType, Allocator>& value,
>>> metric_unit_t units = Other)
>>> '*const std::vector<float, std::allocator<float> >&*'
>>> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:162:82:*
>>> StandardMetrics.ms_v_bat_cell_vmin->SetValue((float)value2 / 1000);
>>> from
>>> from
>>> make[1]: *** [src/vehicle_med3.o] Error 1
>>> make: *** [component-vehicle_maxus_edeliver3-build] Error 2
>>> shane at Shanes-MacBook-Pro OVMS.V3 %
>>> Regards
>>> Shane
>>>> On 3 Apr 2021, at 12:02, Michael Balzer <dexter at expeedo.de
>>>> OVMS# obd can1 request device -t1000 7e4 7ec 2102
>>>> 7e4[7ec] 2102: Response:
>>>> ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c5 | ................
>>>> c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
>>>> c4 c4 c4 c4 | ....
>>>> OVMS# obd can1 request device -t1000 7e4 7ec 2103
>>>> 7e4[7ec] 2103: Response:
>>>> ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c5 c5 c4 c4 c4 | ................
>>>> c4 c4 c4 c4 c4 c5 c5 c5 c4 c5 c5 c5 c4 c5 c4 c4 | ................
>>>> c5 c4 c4 c4 | ....
>>>> OVMS# obd can1 request device -t1000 7e4 7ec 2104
>>>> 7e4[7ec] 2104: Response:
>>>> ff ff ff ff c4 c4 c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
>>>> c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
>>>> c4 c5 c4 c4 | ....
>>>> Your voltages obviously are 16 bit values, so you'll need to use
>>>> RXB_UINT16() and multiply your loop index by 2.
>>>> Regards,
>>>> Michael
>>>> Am 03.04.21 um 12:04 schrieb Shane @ Kilve Engineering:
>>>>> Hi has anyone got a sample of the data for the cell voltages on
>>>>> the ioniq vfl just so I can see how the macro is handling it? Or
>>>>> is it played out the same as below?
>>>>> Regards
>>>>> Shane
>>>>>> On 29 Mar 2021, at 22:20, Michael Balzer <dexter at expeedo.de
>>>>>> Shane,
>>>>>> Am 29.03.21 um 20:17 schrieb Shane @ Kilve Engineering:
>>>>>>> can any one tell me what the "v.e.c.login" is and is it need for
>>>>>>> something to work?
>>>>>> v.e.c.config yes = ECU/controller in configuration state
>>>>>> It's not used by the framework currently.
>>>>>>> also any one with any ideas how to deal with cell voltages in a
>>>>>>> string this long? took me blumim ages to find the bms when the
>>>>>>> tx and rx are 128 address apart!!
>>>>>>> 92 10 6c 10 93 10 93 10 8f 10 91 10 92 10 92 10 92 10 92 10 92
>>>>>>> 10 92 10 90 10 8e 10 90 10 92 10 8d 10 90 10 91 10 8f 10 8e 10
>>>>>>> 8f 10 91 10 90 10 90 10 91 10 8e 10 91 10 8e 10 91 10 90 10 8e
>>>>>>> 10 90 10 92 10 90 10 94 10 91 10 91 10 93 10 90 10 91 10 90 10
>>>>>>> 8f 10 93 10 92 10 8e 10 90 10 91 10 8b 10 92 10 90 10 91 10 8e
>>>>>>> 10 90 10 90 10 90 10 91 10 90 10 8f 10 90 10 90 10 8e 10 92 10
>>>>>>> 8e 10 91 10 89 10 91 10 91 10 91 10 8d 10 8f 10 8d 10 86 10 8a
>>>>>>> 10 8e 10 8f 10 91 10 90 10 92 10 94 10 88 10 8f 10 94 10 91 10
>>>>>>> 91 10 91 10 93 10 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>>>>>> Simply loop over the cells contained. Have a look at the buffer
>>>>>> macro utils, e.g.:
>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_hyundai_ioniqvfl/src/vehicle_hyundai_ioniqvfl.cpp#L44
>>>>>> Regards,
>>>>>> Michael
>>>>>>> Shane
>>>>>>>> On 5 Mar 2021, at 20:45, Michael Balzer <dexter at expeedo.de
>>>>>>>> Shane,
>>>>>>>> OvmsVehicle::PollSetPidList(m_can1, obdii_polls);
>>>>>>>> OvmsVehicle::PollSetState(0);
>>>>>>>> needs to be done in your vehicle init, i.e. the constructor
>>>>>>>> after RegisterCanBus().
>>>>>>>> Please read the vehicle_obdii module source for a complete
>>>>>>>> polling example.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 05.03.21 um 17:59 schrieb Shane @ Kilve Engineering:
>>>>>>>>> Thanks Michael,
>>>>>>>>> Had a try and ended up with this bit added but return anything
>>>>>>>>> Where am I going wrong?
>>>>>>>>> Shane
>>>>>>>>> #include "ovms_log.h"
>>>>>>>>> *static**const**char**TAG= "v-edeliver3";
>>>>>>>>> #include "vehicle_edeliver3.h"
>>>>>>>>> #include "metrics_standard.h"
>>>>>>>>> *namespace* {
>>>>>>>>> *const*OvmsVehicle::poll_pid_tobdii_polls[] =
>>>>>>>>> { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xf194, {
>>>>>>>>> 10, 10, 10, 10 }, 0, ISOTP_STD }, //VIN
>>>>>>>>> { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xe003, {
>>>>>>>>> 10, 10, 10, 10 }, 0, ISOTP_STD }, //SOH
>>>>>>>>> POLL_LIST_END
>>>>>>>>> OvmsVehicleEdeliver3::OvmsVehicleEdeliver3()
>>>>>>>>> ESP_LOGI(TAG, "Start eDeliver3 vehicle module");
>>>>>>>>> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>>>>>>>>> OvmsVehicleEdeliver3::~OvmsVehicleEdeliver3()
>>>>>>>>> ESP_LOGI(TAG, "Stop eDeliver3 vehicle module");
>>>>>>>>> memset(m_vin, 0, *sizeof*(m_vin));
>>>>>>>>> //testing polls
>>>>>>>>> *void*OvmsVehicleEdeliver3::IncomingPollReply(
>>>>>>>>> canbus* bus, uint16_t type, uint16_t pid, uint8_t* data,
>>>>>>>>> uint8_t length, uint16_t mlremain)
>>>>>>>>> string& rxbuf = med_obd_rxbuf;
>>>>>>>>> // init / fill rx buffer:
>>>>>>>>> *if* (m_poll_ml_frame == 0) {
>>>>>>>>> rxbuf.clear();
>>>>>>>>> rxbuf.reserve(length + mlremain);
>>>>>>>>> rxbuf.append((*char**)data, length);
>>>>>>>>> *if* (mlremain)
>>>>>>>>> *return*;
>>>>>>>>> // complete:
>>>>>>>>> *switch* (pid) {
>>>>>>>>> *case* 0xe003: {
>>>>>>>>> *unsigned* *int* soh_raw = ((*unsigned* *int*)rxbuf[0] << 8) |
>>>>>>>>> (*unsigned* *int*)rxbuf[1];
>>>>>>>>> *float* soh = soh_raw / 10;
>>>>>>>>> StdMetrics.ms_v_bat_soh->SetValue(soh);
>>>>>>>>> *break*;
>>>>>>>>> // end testing polls
>>>>>>>>>> On 5 Mar 2021, at 12:37, Michael Balzer <dexter at expeedo.de
>>>>>>>>>> Shane,
>>>>>>>>>> on OBD polling basics:
>>>>>>>>>> http://lists.openvehicles.com/pipermail/ovmsdev/2020-December/014758.html
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 04.03.21 um 19:45 schrieb Shane @ Kilve Engineering:
>>>>>>>>>>> Good evening Michael,
>>>>>>>>>>> Or any one that has the time to help,
>>>>>>>>>>> Ive now successfully retrieved as much info as I can without
>>>>>>>>>>> polling any info for the maxus, but I have have now found an
>>>>>>>>>>> ecu that responds to pid requests.
>>>>>>>>>>> For example if I use the obdii pid scanner I get the loads
>>>>>>>>>>> of data back and I’ve decoded some of it, just need a bit of
>>>>>>>>>>> guidance how to write the code to get the same info
>>>>>>>>>>> A part of a scan is as follows
>>>>>>>>>>> Scan complete (7e3 e000-e100)
>>>>>>>>>>> Scan started : 2021-03-04 18:32:36 GMT
>>>>>>>>>>> Last response: 2021-03-04 18:32:39 GMT
>>>>>>>>>>> 7e3[7eb]:e000 00
>>>>>>>>>>> 7e3[7eb]:e001 64
>>>>>>>>>>> 7e3[7eb]:e002 4b
>>>>>>>>>>> 7e3[7eb]:e003 26 bc
>>>>>>>>>>> 7e3[7eb]:e004 00 07
>>>>>>>>>>> 7e3[7eb]:e005 2f
>>>>>>>>>>> 7e3[7eb]:e006 2e
>>>>>>>>>>> 7e3[7eb]:e007 02 00
>>>>>>>>>>> 7e3[7eb]:e008 01 ff
>>>>>>>>>>> 7e3[7eb]:e009 02 00
>>>>>>>>>>> 7e3[7eb]:e010 02 00
>>>>>>>>>>> I know that e003 is SOH = 26bc = 9916 /100 = 99.16% SOH
>>>>>>>>>>> And e002 is a temp 4b = 75 / 10 = 7.5 degrees
>>>>>>>>>>> So if some one can help me with an example of how to
>>>>>>>>>>> correctly code this one I can work out the rest,
>>>>>>>>>>> Ive looked through various vehicles but everyone uses
>>>>>>>>>>> different methods and I can’t seem to get one to work for me.
>>>>>>>>>>> Any help much appreciated
>>>>>>>>>>> Shane
>>>>>>>>>>>> On 15 Feb 2021, at 08:05, Michael Balzer <dexter at expeedo.de
>>>>>>>>>>>> Shane,
>>>>>>>>>>>> I forgot to mention: if you're working on a new vehicle
>>>>>>>>>>>> module, you'll also need to start the bus somewhere in your
>>>>>>>>>>>> initialization code. Example:
>>>>>>>>>>>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>>> Am 15.02.21 um 08:36 schrieb Michael Balzer:
>>>>>>>>>>>>> Shane,
>>>>>>>>>>>>> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
>>>>>>>>>>>>>> can any one help me with a bit of code to retrieve ve
>>>>>>>>>>>>>> some data from ecu can1/6f2 00 4c 00 00 01 97 bc 00 as i
>>>>>>>>>>>>>> cant poll this ecu it just broadcasts when its active,
>>>>>>>>>>>>>> ive tried polling it but does not respond, i need to
>>>>>>>>>>>>>> choose one byte and allocate it to a PID.
>>>>>>>>>>>>> I don't know what you mean by "allocating a byte to a
>>>>>>>>>>>>> PID", but if you want to process frames received directly,
>>>>>>>>>>>>> simply override IncomingFrameCan1() (or …2/3/4 depending
>>>>>>>>>>>>> on your bus).
>>>>>>>>>>>>> Reduced example:
>>>>>>>>>>>>> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
>>>>>>>>>>>>> uint8_t *d = p_frame->data.u8;
>>>>>>>>>>>>> switch (p_frame->MsgID)
>>>>>>>>>>>>> case 0x6f2:
>>>>>>>>>>>>> // for example, assuming the SOC is in byte 1:
>>>>>>>>>>>>> StdMetrics.ms_v_bat_soc->SetValue(d[1]);
>>>>>>>>>>>>> break;
>>>>>>>>>>>>> If you're outside a vehicle context, you can register your
>>>>>>>>>>>>> own CAN receiver by creating a queue and calling
>>>>>>>>>>>>> MyCan.RegisterListener(). See the vehicle module for an
>>>>>>>>>>>>> example.
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Michael
>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>> <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210405/016b7d8e/attachment-0001.htm>
Name: Screenshot 2021-04-04 at 19.45.35.png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210405/016b7d8e/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210405/016b7d8e/attachment-0001.sig>
