[Ovmsdev] Coding help
Sun Apr 4 20:26:31 HKT 2021
Shane,
vector metrics in general can be set by passing a vector or by using the
element setters provided (see API).
But you don't need to set the cell max/min/stddev metrics at all, you
only need to feed the cell voltages (and/or temperatures). The BMS
framework automatically extracts all statistics values from them.
Btw, regarding your cell voltages:
> 748[7c8]:e113 10 90 10 92 10 93 10 93 10 8e 10 92 10 8f 10 90 10 92 10
> 6c 10 93 10 93 10 8f 10 91 10 92 10 92 10 92 10 92 10 92 10 92 10 90
> 10 8e 10 90 10 92 10 8d 10 90 10 91 10 8f 10 8e 10 8f 10 91 10 90 10
> 90 10 91 10 8e 10 91 10 8e 10 91 10 90 10 8e 10 90 10 92 10 90 10 94
> 10 91 10 91 10 93 10 90 10 91 10 90 10 8f 10 93 10 92 10 8e 10 90 10
> 91 10 8b 10 92 10 90 10 91 10 8e 10 90 10 90 10 90 10 91 10 90 10 8f
> 10 90 10 90 10 8e 10 92 10 8e 10 91 10 89 10 91 10 91 10 91 10 8d 10
> 8f 10 8d 10 86 10 8a 10 8e 10 8f 10 91 10 90 10 92 10 94 10 88 10 8f
> 10 94 10 91 10 91 10 91 10 93 10 91 00 00 00 00 00 00 00 00 00 00 00
> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
This looks like 96 cells with a factor of 0.001, e.g. 0x1090 = 4240 *
0.001 = 4.24V.
Assuming you fix your IncomingPollReply() handler to actually use the
rxbuf string and you copy the RXB_* macros from the Ioniq VFL code, you
can simply do this to process the values:
case 0xe113:
// Read battery cell voltages 1-96:
BmsRestartCellVoltages();
for (int i = 0; i < 96; i++) {
BmsSetCellVoltage(i, RXB_UINT16(i*2) * 0.001f);
break;
Doesn't look that hard, does it?
Am 04.04.21 um 12:37 schrieb Shane @ Kilve Engineering:
> morning peeps, sorry for the newbie question whats different about the
> cell vmax/vmin i see in metrics_standard.h its a vector?
> (OvmsMetricVector<float>* ms_v_bat_cell_vmax; // Cell maximum
> voltages [V])
> does that mean i have ot handle these different? if so how?
> as all i get is errors trying to setvalue to this metric
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:*
> In member function '*void OvmsVehicleMaxed3::IncomingBmsReply(canbus*,
> uint16_t, uint16_t, uint8_t*, uint8_t, uint16_t)*':
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:159:82:*
> *error: *no matching function for call to
> '*OvmsMetricVector<float>::SetValue(float)*'
> StandardMetrics.ms_v_bat_cell_vmax->SetValue((float)value2 / 1000);
> In file included from
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle/vehicle.h:40:0*,
> from
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.h:32*,
> from
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:32*:
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/main/ovms_metrics.h:747:18:*
> *note: *candidate: bool OvmsMetricVector<ElemType,
> Allocator>::SetValue(std::__cxx11::string) [with ElemType = float;
> Allocator = std::allocator<float>; std::__cxx11::string =
> std::__cxx11::basic_string<char>]
> virtual bool SetValue(std::string value)
> *note: * no known conversion for argument 1 from '*float*' to
> '*std::__cxx11::string {aka std::__cxx11::basic_string<char>}*'
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/main/ovms_metrics.h:763:10:*
> Allocator>::SetValue(const std::vector<_Tp, _Alloc>&, metric_unit_t)
> [with ElemType = float; Allocator = std::allocator<float>]
> bool SetValue(const std::vector<ElemType, Allocator>& value,
> metric_unit_t units = Other)
> *note: * no known conversion for argument 1 from '*float*' to '*const
> std::vector<float, std::allocator<float> >&*'
> */Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3/src/vehicle_med3.cpp:162:82:*
> StandardMetrics.ms_v_bat_cell_vmin->SetValue((float)value2 / 1000);
> from
> from
> make[1]: *** [src/vehicle_med3.o] Error 1
> make: *** [component-vehicle_maxus_edeliver3-build] Error 2
> shane at Shanes-MacBook-Pro OVMS.V3 %
> Regards
> Shane
>> On 3 Apr 2021, at 12:02, Michael Balzer <dexter at expeedo.de
>> OVMS# obd can1 request device -t1000 7e4 7ec 2102
>> 7e4[7ec] 2102: Response:
>> ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c5 | ................
>> c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
>> c4 c4 c4 c4 | ....
>> OVMS# obd can1 request device -t1000 7e4 7ec 2103
>> 7e4[7ec] 2103: Response:
>> ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c5 c5 c4 c4 c4 | ................
>> c4 c4 c4 c4 c4 c5 c5 c5 c4 c5 c5 c5 c4 c5 c4 c4 | ................
>> c5 c4 c4 c4 | ....
>> OVMS# obd can1 request device -t1000 7e4 7ec 2104
>> 7e4[7ec] 2104: Response:
>> ff ff ff ff c4 c4 c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
>> c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
>> c4 c5 c4 c4 | ....
>> Your voltages obviously are 16 bit values, so you'll need to use
>> RXB_UINT16() and multiply your loop index by 2.
>> Am 03.04.21 um 12:04 schrieb Shane @ Kilve Engineering:
>>> Hi has anyone got a sample of the data for the cell voltages on the
>>> ioniq vfl just so I can see how the macro is handling it? Or is it
>>> played out the same as below?
>>> Regards
>>> Shane
>>>> On 29 Mar 2021, at 22:20, Michael Balzer <dexter at expeedo.de
>>>> Shane,
>>>> Am 29.03.21 um 20:17 schrieb Shane @ Kilve Engineering:
>>>>> can any one tell me what the "v.e.c.login" is and is it need for
>>>>> something to work?
>>>> v.e.c.config yes = ECU/controller in configuration state
>>>> It's not used by the framework currently.
>>>>> also any one with any ideas how to deal with cell voltages in a
>>>>> string this long? took me blumim ages to find the bms when the tx
>>>>> and rx are 128 address apart!!
>>>>> 92 10 6c 10 93 10 93 10 8f 10 91 10 92 10 92 10 92 10 92 10 92 10
>>>>> 92 10 90 10 8e 10 90 10 92 10 8d 10 90 10 91 10 8f 10 8e 10 8f 10
>>>>> 91 10 90 10 90 10 91 10 8e 10 91 10 8e 10 91 10 90 10 8e 10 90 10
>>>>> 92 10 90 10 94 10 91 10 91 10 93 10 90 10 91 10 90 10 8f 10 93 10
>>>>> 92 10 8e 10 90 10 91 10 8b 10 92 10 90 10 91 10 8e 10 90 10 90 10
>>>>> 90 10 91 10 90 10 8f 10 90 10 90 10 8e 10 92 10 8e 10 91 10 89 10
>>>>> 91 10 91 10 91 10 8d 10 8f 10 8d 10 86 10 8a 10 8e 10 8f 10 91 10
>>>>> 90 10 92 10 94 10 88 10 8f 10 94 10 91 10 91 10 91 10 93 10 91 00
>>>>> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>>>> Simply loop over the cells contained. Have a look at the buffer
>>>> macro utils, e.g.:
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_hyundai_ioniqvfl/src/vehicle_hyundai_ioniqvfl.cpp#L44
>>>> Regards,
>>>> Michael
>>>>> Shane
>>>>>> On 5 Mar 2021, at 20:45, Michael Balzer <dexter at expeedo.de
>>>>>> Shane,
>>>>>> OvmsVehicle::PollSetPidList(m_can1, obdii_polls);
>>>>>> OvmsVehicle::PollSetState(0);
>>>>>> needs to be done in your vehicle init, i.e. the constructor after
>>>>>> RegisterCanBus().
>>>>>> Please read the vehicle_obdii module source for a complete
>>>>>> polling example.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 05.03.21 um 17:59 schrieb Shane @ Kilve Engineering:
>>>>>>> Thanks Michael,
>>>>>>> Had a try and ended up with this bit added but return anything
>>>>>>> Where am I going wrong?
>>>>>>> Shane
>>>>>>> #include "ovms_log.h"
>>>>>>> *static**const**char**TAG= "v-edeliver3";
>>>>>>> #include "vehicle_edeliver3.h"
>>>>>>> #include "metrics_standard.h"
>>>>>>> *namespace* {
>>>>>>> *const*OvmsVehicle::poll_pid_tobdii_polls[] =
>>>>>>> { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xf194, {
>>>>>>> 10, 10, 10, 10 }, 0, ISOTP_STD }, //VIN
>>>>>>> { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xe003, {
>>>>>>> 10, 10, 10, 10 }, 0, ISOTP_STD }, //SOH
>>>>>>> POLL_LIST_END
>>>>>>> OvmsVehicleEdeliver3::OvmsVehicleEdeliver3()
>>>>>>> ESP_LOGI(TAG, "Start eDeliver3 vehicle module");
>>>>>>> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>>>>>>> OvmsVehicleEdeliver3::~OvmsVehicleEdeliver3()
>>>>>>> ESP_LOGI(TAG, "Stop eDeliver3 vehicle module");
>>>>>>> memset(m_vin, 0, *sizeof*(m_vin));
>>>>>>> //testing polls
>>>>>>> *void*OvmsVehicleEdeliver3::IncomingPollReply(
>>>>>>> canbus* bus, uint16_t type, uint16_t pid, uint8_t* data, uint8_t
>>>>>>> length, uint16_t mlremain)
>>>>>>> string& rxbuf = med_obd_rxbuf;
>>>>>>> // init / fill rx buffer:
>>>>>>> *if* (m_poll_ml_frame == 0) {
>>>>>>> rxbuf.clear();
>>>>>>> rxbuf.reserve(length + mlremain);
>>>>>>> rxbuf.append((*char**)data, length);
>>>>>>> *if* (mlremain)
>>>>>>> *return*;
>>>>>>> // complete:
>>>>>>> *switch* (pid) {
>>>>>>> *case* 0xe003: {
>>>>>>> *unsigned* *int* soh_raw = ((*unsigned* *int*)rxbuf[0] << 8) |
>>>>>>> (*unsigned* *int*)rxbuf[1];
>>>>>>> *float* soh = soh_raw / 10;
>>>>>>> StdMetrics.ms_v_bat_soh->SetValue(soh);
>>>>>>> *break*;
>>>>>>> // end testing polls
>>>>>>>> On 5 Mar 2021, at 12:37, Michael Balzer <dexter at expeedo.de
>>>>>>>> Shane,
>>>>>>>> on OBD polling basics:
>>>>>>>> http://lists.openvehicles.com/pipermail/ovmsdev/2020-December/014758.html
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 04.03.21 um 19:45 schrieb Shane @ Kilve Engineering:
>>>>>>>>> Good evening Michael,
>>>>>>>>> Or any one that has the time to help,
>>>>>>>>> Ive now successfully retrieved as much info as I can without
>>>>>>>>> polling any info for the maxus, but I have have now found an
>>>>>>>>> ecu that responds to pid requests.
>>>>>>>>> For example if I use the obdii pid scanner I get the loads of
>>>>>>>>> data back and I’ve decoded some of it, just need a bit of
>>>>>>>>> guidance how to write the code to get the same info
>>>>>>>>> A part of a scan is as follows
>>>>>>>>> Scan complete (7e3 e000-e100)
>>>>>>>>> Scan started : 2021-03-04 18:32:36 GMT
>>>>>>>>> Last response: 2021-03-04 18:32:39 GMT
>>>>>>>>> 7e3[7eb]:e000 00
>>>>>>>>> 7e3[7eb]:e001 64
>>>>>>>>> 7e3[7eb]:e002 4b
>>>>>>>>> 7e3[7eb]:e003 26 bc
>>>>>>>>> 7e3[7eb]:e004 00 07
>>>>>>>>> 7e3[7eb]:e005 2f
>>>>>>>>> 7e3[7eb]:e006 2e
>>>>>>>>> 7e3[7eb]:e007 02 00
>>>>>>>>> 7e3[7eb]:e008 01 ff
>>>>>>>>> 7e3[7eb]:e009 02 00
>>>>>>>>> 7e3[7eb]:e010 02 00
>>>>>>>>> I know that e003 is SOH = 26bc = 9916 /100 = 99.16% SOH
>>>>>>>>> And e002 is a temp 4b = 75 / 10 = 7.5 degrees
>>>>>>>>> So if some one can help me with an example of how to correctly
>>>>>>>>> code this one I can work out the rest,
>>>>>>>>> Ive looked through various vehicles but everyone uses
>>>>>>>>> different methods and I can’t seem to get one to work for me.
>>>>>>>>> Any help much appreciated
>>>>>>>>> Shane
>>>>>>>>>> On 15 Feb 2021, at 08:05, Michael Balzer <dexter at expeedo.de
>>>>>>>>>> Shane,
>>>>>>>>>> I forgot to mention: if you're working on a new vehicle
>>>>>>>>>> module, you'll also need to start the bus somewhere in your
>>>>>>>>>> initialization code. Example:
>>>>>>>>>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 15.02.21 um 08:36 schrieb Michael Balzer:
>>>>>>>>>>> Shane,
>>>>>>>>>>> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
>>>>>>>>>>>> can any one help me with a bit of code to retrieve ve some
>>>>>>>>>>>> data from ecu can1/6f2 00 4c 00 00 01 97 bc 00 as i cant
>>>>>>>>>>>> poll this ecu it just broadcasts when its active, ive tried
>>>>>>>>>>>> polling it but does not respond, i need to choose one byte
>>>>>>>>>>>> and allocate it to a PID.
>>>>>>>>>>> I don't know what you mean by "allocating a byte to a PID",
>>>>>>>>>>> but if you want to process frames received directly, simply
>>>>>>>>>>> override IncomingFrameCan1() (or …2/3/4 depending on your bus).
>>>>>>>>>>> Reduced example:
>>>>>>>>>>> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
>>>>>>>>>>> uint8_t *d = p_frame->data.u8;
>>>>>>>>>>> switch (p_frame->MsgID)
>>>>>>>>>>> case 0x6f2:
>>>>>>>>>>> // for example, assuming the SOC is in byte 1:
>>>>>>>>>>> StdMetrics.ms_v_bat_soc->SetValue(d[1]);
>>>>>>>>>>> break;
>>>>>>>>>>> If you're outside a vehicle context, you can register your
>>>>>>>>>>> own CAN receiver by creating a queue and calling
>>>>>>>>>>> MyCan.RegisterListener(). See the vehicle module for an example.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210404/b3b11081/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210404/b3b11081/attachment-0001.sig>
