[Ovmsdev] Coding help
Sat Apr 3 19:02:06 HKT 2021
OVMS# obd can1 request device -t1000 7e4 7ec 2102
7e4[7ec] 2102: Response:
ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c5 | ................
c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
c4 c4 c4 c4 | ....
OVMS# obd can1 request device -t1000 7e4 7ec 2103
7e4[7ec] 2103: Response:
ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c5 c5 c4 c4 c4 | ................
c4 c4 c4 c4 c4 c5 c5 c5 c4 c5 c5 c5 c4 c5 c4 c4 | ................
c5 c4 c4 c4 | ....
OVMS# obd can1 request device -t1000 7e4 7ec 2104
7e4[7ec] 2104: Response:
ff ff ff ff c4 c4 c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................
c4 c5 c4 c4 | ....
Your voltages obviously are 16 bit values, so you'll need to use
RXB_UINT16() and multiply your loop index by 2.
Am 03.04.21 um 12:04 schrieb Shane @ Kilve Engineering:
> Hi has anyone got a sample of the data for the cell voltages on the
> ioniq vfl just so I can see how the macro is handling it? Or is it
> played out the same as below?
> Regards
> Shane
>> On 29 Mar 2021, at 22:20, Michael Balzer <dexter at expeedo.de
>> Shane,
>> Am 29.03.21 um 20:17 schrieb Shane @ Kilve Engineering:
>>> can any one tell me what the "v.e.c.login" is and is it need for
>>> something to work?
>> v.e.c.config yes = ECU/controller in configuration state
>> It's not used by the framework currently.
>>> also any one with any ideas how to deal with cell voltages in a
>>> string this long? took me blumim ages to find the bms when the tx
>>> and rx are 128 address apart!!
>>> 748[7c8]:e113 10 90 10 92 10 93 10 93 10 8e 10 92 10 8f 10 90 10 92
>>> 10 6c 10 93 10 93 10 8f 10 91 10 92 10 92 10 92 10 92 10 92 10 92 10
>>> 90 10 8e 10 90 10 92 10 8d 10 90 10 91 10 8f 10 8e 10 8f 10 91 10 90
>>> 10 90 10 91 10 8e 10 91 10 8e 10 91 10 90 10 8e 10 90 10 92 10 90 10
>>> 94 10 91 10 91 10 93 10 90 10 91 10 90 10 8f 10 93 10 92 10 8e 10 90
>>> 10 91 10 8b 10 92 10 90 10 91 10 8e 10 90 10 90 10 90 10 91 10 90 10
>>> 8f 10 90 10 90 10 8e 10 92 10 8e 10 91 10 89 10 91 10 91 10 91 10 8d
>>> 10 8f 10 8d 10 86 10 8a 10 8e 10 8f 10 91 10 90 10 92 10 94 10 88 10
>>> 8f 10 94 10 91 10 91 10 91 10 93 10 91 00 00 00 00 00 00 00 00 00 00
>>> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>> Simply loop over the cells contained. Have a look at the buffer macro
>> utils, e.g.:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_hyundai_ioniqvfl/src/vehicle_hyundai_ioniqvfl.cpp#L44
>>> Shane
>>>> On 5 Mar 2021, at 20:45, Michael Balzer <dexter at expeedo.de
>>>> Shane,
>>>> OvmsVehicle::PollSetPidList(m_can1, obdii_polls);
>>>> OvmsVehicle::PollSetState(0);
>>>> needs to be done in your vehicle init, i.e. the constructor after
>>>> RegisterCanBus().
>>>> Please read the vehicle_obdii module source for a complete polling
>>>> example.
>>>> Regards,
>>>> Michael
>>>> Am 05.03.21 um 17:59 schrieb Shane @ Kilve Engineering:
>>>>> Thanks Michael,
>>>>> Had a try and ended up with this bit added but return anything
>>>>> Where am I going wrong?
>>>>> Shane
>>>>> #include "ovms_log.h"
>>>>> *static**const**char**TAG= "v-edeliver3";
>>>>> #include "vehicle_edeliver3.h"
>>>>> #include "metrics_standard.h"
>>>>> *namespace* {
>>>>> *const*OvmsVehicle::poll_pid_tobdii_polls[] =
>>>>> { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xf194, { 10,
>>>>> 10, 10, 10 }, 0, ISOTP_STD }, //VIN
>>>>> { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xe003, { 10,
>>>>> 10, 10, 10 }, 0, ISOTP_STD }, //SOH
>>>>> POLL_LIST_END
>>>>> OvmsVehicleEdeliver3::OvmsVehicleEdeliver3()
>>>>> ESP_LOGI(TAG, "Start eDeliver3 vehicle module");
>>>>> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>>>>> OvmsVehicleEdeliver3::~OvmsVehicleEdeliver3()
>>>>> ESP_LOGI(TAG, "Stop eDeliver3 vehicle module");
>>>>> memset(m_vin, 0, *sizeof*(m_vin));
>>>>> //testing polls
>>>>> *void*OvmsVehicleEdeliver3::IncomingPollReply(
>>>>> canbus* bus, uint16_t type, uint16_t pid, uint8_t* data,
>>>>> uint8_t length, uint16_t mlremain)
>>>>> string& rxbuf = med_obd_rxbuf;
>>>>> // init / fill rx buffer:
>>>>> *if* (m_poll_ml_frame == 0) {
>>>>> rxbuf.clear();
>>>>> rxbuf.reserve(length + mlremain);
>>>>> rxbuf.append((*char**)data, length);
>>>>> *if* (mlremain)
>>>>> *return*;
>>>>> // complete:
>>>>> *switch* (pid) {
>>>>> *case* 0xe003: {
>>>>> *unsigned* *int* soh_raw = ((*unsigned* *int*)rxbuf[0] << 8) |
>>>>> (*unsigned* *int*)rxbuf[1];
>>>>> *float* soh = soh_raw / 10;
>>>>> StdMetrics.ms_v_bat_soh->SetValue(soh);
>>>>> *break*;
>>>>> // end testing polls
>>>>>> On 5 Mar 2021, at 12:37, Michael Balzer <dexter at expeedo.de
>>>>>> Shane,
>>>>>> on OBD polling basics:
>>>>>> http://lists.openvehicles.com/pipermail/ovmsdev/2020-December/014758.html
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 04.03.21 um 19:45 schrieb Shane @ Kilve Engineering:
>>>>>>> Good evening Michael,
>>>>>>> Or any one that has the time to help,
>>>>>>> Ive now successfully retrieved as much info as I can without
>>>>>>> polling any info for the maxus, but I have have now found an ecu
>>>>>>> that responds to pid requests.
>>>>>>> For example if I use the obdii pid scanner I get the loads of
>>>>>>> data back and I’ve decoded some of it, just need a bit of
>>>>>>> guidance how to write the code to get the same info
>>>>>>> A part of a scan is as follows
>>>>>>> Scan complete (7e3 e000-e100)
>>>>>>> Scan started : 2021-03-04 18:32:36 GMT
>>>>>>> Last response: 2021-03-04 18:32:39 GMT
>>>>>>> 7e3[7eb]:e000 00
>>>>>>> 7e3[7eb]:e001 64
>>>>>>> 7e3[7eb]:e002 4b
>>>>>>> 7e3[7eb]:e003 26 bc
>>>>>>> 7e3[7eb]:e004 00 07
>>>>>>> 7e3[7eb]:e005 2f
>>>>>>> 7e3[7eb]:e006 2e
>>>>>>> 7e3[7eb]:e007 02 00
>>>>>>> 7e3[7eb]:e008 01 ff
>>>>>>> 7e3[7eb]:e009 02 00
>>>>>>> 7e3[7eb]:e010 02 00
>>>>>>> I know that e003 is SOH = 26bc = 9916 /100 = 99.16% SOH
>>>>>>> And e002 is a temp 4b = 75 / 10 = 7.5 degrees
>>>>>>> So if some one can help me with an example of how to correctly
>>>>>>> code this one I can work out the rest,
>>>>>>> Ive looked through various vehicles but everyone uses different
>>>>>>> methods and I can’t seem to get one to work for me.
>>>>>>> Any help much appreciated
>>>>>>> Shane
>>>>>>>> On 15 Feb 2021, at 08:05, Michael Balzer <dexter at expeedo.de
>>>>>>>> Shane,
>>>>>>>> I forgot to mention: if you're working on a new vehicle module,
>>>>>>>> you'll also need to start the bus somewhere in your
>>>>>>>> initialization code. Example:
>>>>>>>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 15.02.21 um 08:36 schrieb Michael Balzer:
>>>>>>>>> Shane,
>>>>>>>>> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
>>>>>>>>>> can any one help me with a bit of code to retrieve ve some
>>>>>>>>>> data from ecu can1/6f2 00 4c 00 00 01 97 bc 00 as i cant
>>>>>>>>>> poll this ecu it just broadcasts when its active, ive tried
>>>>>>>>>> polling it but does not respond, i need to choose one byte
>>>>>>>>>> and allocate it to a PID.
>>>>>>>>> I don't know what you mean by "allocating a byte to a PID",
>>>>>>>>> but if you want to process frames received directly, simply
>>>>>>>>> override IncomingFrameCan1() (or …2/3/4 depending on your bus).
>>>>>>>>> Reduced example:
>>>>>>>>> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
>>>>>>>>> uint8_t *d = p_frame->data.u8;
>>>>>>>>> switch (p_frame->MsgID)
>>>>>>>>> case 0x6f2:
>>>>>>>>> // for example, assuming the SOC is in byte 1:
>>>>>>>>> StdMetrics.ms_v_bat_soc->SetValue(d[1]);
>>>>>>>>> break;
>>>>>>>>> If you're outside a vehicle context, you can register your own
>>>>>>>>> CAN receiver by creating a queue and calling
>>>>>>>>> MyCan.RegisterListener(). See the vehicle module for an example.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>> OvmsDev mailing list
>>>>>> <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210403/32a783ba/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210403/32a783ba/attachment-0001.sig>
