[Ovmsdev] Multi frame query
Fri Apr 2 19:15:25 HKT 2021
I don't see any issues in the standard poller. The "incoming" methods
get called per frame.
You can verify it's working correctly by doing an obdii request.
Am 02.04.21 um 12:55 schrieb didier at ernotte.com:
> Hi,
> Don't you think this fix has a bigger impact on vehicle.cpp, and all
> implementations ?
> I have started creating the Jaguar Ipace vehicle, and I see a very
> similar code (and fix) in IncomingPollReply, for the size (16 bits) of
> the "length"
> protected:
> virtualvoidPollerStateTicker();
> virtualvoidIncomingPollReply(canbus*bus, uint16_ttype, uint16_tpid,
> uint8_t*data, uint8_tlength, uint16_tmlremain);
> virtualvoidIncomingPollError(canbus*bus, uint16_ttype, uint16_tpid,
> uint16_tcode);
> and
> voidOvmsVehicleJaguarIpace::IncomingPollFrame(CAN_frame_t*frame)
> uint8_tframeType= frame->data.u8[0] >> 4;
> uint16_tframeLength= frame->data.u8[0] & 0x0f;
> uint8_t* data= &frame->data.u8[1];
> uint16_tdataLength= frameLength;
> Didier
> Le mardi 30 mars 2021 13 h 58 min 20 s UTC−4, Greg D.
> <gregd2350 at gmail.com> a écrit :
> Just to close out this loose end...
> OBD2ECU doesn't do any multi-frame PIDs other than responding to
> requests for the VIN (fixed format) and ECU Name (20 characters, user
> configurable).  The flow control frame for both of these are kludged
> with a simple (fixed) 10ms delay, i.e. it doesn't actually wait for
> the flow control frame to be received before proceeding, and ignores
> them when received.  Proper processing was seen as unnecessary
> complexity when I wrote the first prototype, and was never "corrected".
> Greg
> Michael Balzer wrote:
> Didier,
> the PID scanner normally works perfectly with multi frame responses,
> but I haven't had a response that long yet.
> For 1503 bytes, 215 consecutive frames need to be transmitted. The PID
> scanner requests these to be sent with 25 ms separation time, so they
> should need 5.375 seconds.
> Maybe some frame gets lost, or maybe the device doesn't allow a
> separation time that high for a transmission that huge.
> Your log quote wasn't from the re-pid component but from obd2ecu,
> which has nothing to do with the RE tools. You should raise the log
> level for re-pid to see more info. Another tracing option is to use
> the CAN log monitor.
> Btw, you should never need 30 seconds timeout for a PID poll, as the
> scanner checks against the last frame reception.
> Am 28.03.21 um 17:52 schrieb didier at ernotte.com
> <mailto:didier at ernotte.com>:
>> I am investigating some PID with very long data. I am using the PID
>> scanner for this.
>> When I turn on the log level debug , I can see this as the first repy
>> D (1456677) obd2ecu: Rcv 7ec: 8 (15 df 62 48 83 0 0 0)
>> From the Canbus doc, I understand that the first "1x (15)" tells me
>> that this is the first frame of a multi frame, and the length is
>> "5df" . The Pid scanner seems to return only "df", not "5df" data,
>> and I can see in the log that I have around 1500 byte returned, not
>> 220. Any explanation ? anyone see this problem as well ? The scan
>> command is (I had to hack the code to allow timeout > 10sec)
>> re obdii scan start 1 7e4 4883 4883 -r500-7ff -t22 -x30
> OvmsDev at lists.openvehicles.com  <mailto:OvmsDev at lists.openvehicles.com>
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev  <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210402/58e564d5/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210402/58e564d5/attachment-0001.sig>
