[Ovmsdev] Modem won't start
Chris van der Meijden
chris at arachnon.de
Wed Sep 30 16:42:40 HKT 2020
Oh boy ...
Found this one:
http://lists.openvehicles.com/pipermail/ovmsdev/2020-February/006640.ht
ml
You indeed have to pull the fuse for a minute and not only for two
seconds ...
Very strange, but hey it works now :-)
Network Registration: RegisteredHome
Provider: o2 - de+
Signal: -97 dBm
St
ate: NetStart
Regards
Chris
Am Mittwoch, den 30.09.2020, 09:17 +0200 schrieb Chris van der Meijden:
> Hi all
> I'm suddenly having problems with the modem. It is stuck in
> PoweringOn and shows a signal of 0 dBm.
> Here the status:
> Network Registration: NotRegistered
> Provider:
> Signal: 0 dBm
> State: PoweringOn
> PPP: Not connected
> GPS: Not connected
> And here the debug log:
> I (201194) simcom: State timeout, transition to 2
> I (201194) simcom: State: Enter PoweringOn state
> I (201194) simcom: Power Cycle
> D (201194) max7317: egpio.output.0.high
> D (202194) max7317: egpio.output.0.low
> D (202204) events: Signal(system.modem.poweringon)
> D (202204) events: Signal(egpio.output.0.high)
> D (202204) simcom: tx scmd ch=0 len=4 : AT
> D (202214) events: Signal(egpio.output.0.low)
> D (203194) simcom: tx scmd ch=0 len=4 : AT
> D (204194) simcom: tx scmd ch=0 len=4 : AT
> D (205194) simcom: tx scmd ch=0 len=4 : AT
> D (206194) simcom: tx scmd ch=0 len=4 : AT
> D (207194) simcom: tx scmd ch=0 len=4 : AT
> D (208194) simcom: tx scmd ch=0 len=4 : AT
> D (209194) simcom: tx scmd ch=0 len=4 : AT
> D (210194) simcom: tx scmd ch=0 len=4 : AT
> D (211194) simcom: tx scmd ch=0 len=4 : AT
> D (212194) simcom: tx scmd ch=0 len=4 : AT
> D (213194) simcom: tx scmd ch=0 len=4 : AT
> D (214194) simcom: tx scmd ch=0 len=4 : AT
> D (215194) simcom: tx scmd ch=0 len=4 : AT
> D (216194) simcom: tx scmd ch=0 len=4 : AT
> D (217194) simcom: tx scmd ch=0 len=4 : AT
> D (218194) simcom: tx scmd ch=0 len=4 : AT
> D (219194) simcom: tx scmd ch=0 len=4 : AT
> D (220194) simcom: tx scmd ch=0 len=4 : AT
> D (221194) simcom: tx scmd ch=0 len=4 : AT
> Hard reset did not help ...
> I found this discussion https://www.openvehicles.com/node/2381 with
> recent postings.
> Could there be a general problem with the modem, or is it my hardware
> (again ...)?
> Thanx
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200930/5189c784/attachment-0002.htm>
