[Ovmsdev] Duktape Persistent Function References
Sat Sep 12 14:26:56 HKT 2020
Steve,
std::function has constructors that accept function pointers, or NULL to
create an empty function object.
std::function of course has a little overhead over a simple pointer. But
that overhead isn't relevant for this use case. In fact, we use
std::function already in places that are more performance & memory
sensitive.
See: https://www.boost.org/doc/libs/1_45_0/doc/html/function/misc.html
Am 11.09.20 um 23:31 schrieb Stephen Casner:
> Michael,
> Like Mark, I did not think the change would be simple. I've used
> functional objects before, but was not aware of std::function. I am
> still not quite sure how a vanilla function pointer matches this
> type; I need to think about that more carefully.
> Having the typedefs is a good idea even if we weren't using
> std:function.
> -- Steve
> On Fri, 11 Sep 2020, Michael Balzer wrote:
>> Mark,
>> Am 11.09.20 um 18:11 schrieb Michael Balzer:
>>>> I agree it is not necessary; my suggestion is purely to clean it up
>>>> and enhance functionality. The problem at the moment is that
>>>> OvmsCommand execute callbacks can only be to function callbacks (not
>>>> objects). It doesn't even use the c++ bind function callback
>>>> mechanism (like notification, etc, for example). It is what it is,
>>>> and changing now is very hard.
>>> That slipped my attention, but upgrading OvmsCommand to accept any
>>> function type should be simply changing m_execute and m_validate to
>>> std::function, or do I miss something?
>> Just did this locally, works perfectly. Shall I push the change or have
>> you begun working on ovms_command?
>> If so, it's really just exchanging the function signatures for these types:
>> typedef std::function<void(int, OvmsWriter*, OvmsCommand*, int, const
>> char* const*)> OvmsCommandExecuteCallback_t;
>> typedef std::function<int(OvmsWriter*, OvmsCommand*, int, const char*
>> const*, bool)> OvmsCommandValidateCallback_t;
>> Patch attached.
