[Ovmsdev] Highcharts help
Sun Sep 6 21:46:21 HKT 2020
Derek,
from your code snippet you've defined "chargechart", but try to access
"chargeChart" later on.
Also $(…).chart() does not return a Highcharts object, but the jQuery
DOM object collection passed to it (for chaining).
The correct way to get a reference to the actual Highcharts object is
using/remembering "this" in the load event, that is pointing to the
Highcharts instance.
Am 06.09.20 um 12:27 schrieb Derek Caudwell:
> Hi all,
> Appreciate some help on the best way to initialise Highcharts when
> developing a web plugin -  I am wanting to extend the bms/cellmon to
> include shunt state and an extra chart showing charge rate, SOC,
> battery temp etc. I started by copying the js code from bms/cellmon
> page however I could not replicate the initialisation which calls a
> separate javascript if Highcharts is not loaded before initialisation.
> I also tried a cut down version of the Trip Power Chart (without
> history) initialising in the main script code with:
> chargechart = $('#chargechart').chart({
>     chart: {
>       type: 'line',
>       events: {
>         load: function () {$('#chgreceiver').on("msg:metrics",
> function(e, update){
>               if (update["v.b.soc"] != null) {
>                  updateChart();
>           } etc
> however in updateChart() I cannot reference chargeChart to addPoints?
> Cheers
> Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200906/3b5975a2/attachment.htm>
