[Ovmsdev] OVMS not booting normally (CPU0=12 and CPU1=12)
sharkcow
sharkcow at gmx.de
Sat Sep 5 23:57:41 HKT 2020
Thanks for the hint, but I double checked and I definitely booted from
the factory partition...
Anyway, all is good now. It seems like there was a problem with marxx'
repository, maybe that was the culprit.
sharkcow
Am 05.09.20 um 16:36 schrieb Michael Balzer:
> sharkcow,
> if you flashed via USB, you probably flashed the factory partition. If
> you want to run that, you also need to set that as the boot partition if
> you're currently booting an OTA partition.
> See:
> https://docs.openvehicles.com/en/latest/userguide/factory.html#module-factory-firmware
> Am 05.09.20 um 10:43 schrieb sharkcow:
>> OK it's running again now, sorry for the confusion.
>> In the meantime I saw a very early error message about corrupt boot
>> data, so I bit the bullet and did a full reflash, which didn't help
>> either.
>> Tried my previously working ota and now it's running again (I guess I
>> got mixed up with the versions earlier).
>> So my only remaining question is why doesn't flashing a factory image
>> help in this case? The way I see it, it was just a bad build?
>> sharkcow
>> Am 05.09.20 um 10:16 schrieb sharkcow:
>>> Hi all,
>>> I hope this is the right place to ask...
>>> Since flashing a new build yesterday, my OVMS doesn't boot normally
>>> anymore. What I see in the USB console are 5 early crashes (reason 12
>>> for both CPUs), then the module falls back to running without auto init.
>>> What I have tried: switching to previously working ota, flashing &
>>> booting factory images 3.2.15 and 3.2.14 from dexter. Removed SD card
>>> since reason 12 may point to a vfs problem.
>>> What else can I try? In my understanding it doesn't make sense to do a
>>> full reflash incl. boot loader, since booting as such works... or am I
>>> mistaken?
>>> Is any other information necessary to tell what's wrong?
>>> Thank you!
>>> sharkcow
>>> dump from 3.2.14:
>>> I (121) boot: Initialising BOOT (1100)
>>> I (125) boot: Boot #4 reasons for CPU0=12 and CPU1=12
>>> I (131) boot: Reset reason Exception/panic (4)
>>> E (136) boot: Early crash #4 detected
>>> I (141) events: Initialising EVENTS (1200)
>>> I (3250) housekeeping: Auto init vehicle (free: 133748 bytes)
>>> Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was
>>> unhandled.
>>> Core 1 register dump:
>>> PC : 0x401642d9 PS : 0x00060530 A0 : 0x801643a7 A1
>>> : 0x3ffc3050
>>> A2 : 0x3ffb8190 A3 : 0x3ffc30e0 A4 : 0x00000001 A5
>>> : 0x3ffc30a8
>>> A6 : 0x3ffc3090 A7 : 0x3ffb732c A8 : 0x801642d3 A9
>>> : 0x3ffc3020
>>> A10 : 0x00000000 A11 : 0x3ffc30e0 A12 : 0x3ffc3050 A13
>>> : 0x0000ff00
>>> A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000008
>>> EXCCAUSE: 0x0000001d
>>> EXCVADDR: 0x0000000e LBEG : 0x4008be55 LEND : 0x4008be65 LCOUNT
>>> : 0xfffffffb
>>> ELF file SHA256: 01e6f0fccd1fb186
>>> Backtrace: 0x401642d9:0x3ffc3050 0x401643a4:0x3ffc3090
>>> 0x400f7e83:0x3ffc3110 0x400f7a92:0x3ffc3180 0x400f8eb6:0x3ffc31c0
>>> 0x400f9051:0x3ffc31f0 0x400f9138:0x3ffc3240 0x400f9199:0x3ffc3270
