[Ovmsdev] OVMS not booting normally (CPU0=12 and CPU1=12)
sharkcow
sharkcow at gmx.de
Sat Sep 5 16:43:11 HKT 2020
OK it's running again now, sorry for the confusion.
In the meantime I saw a very early error message about corrupt boot
data, so I bit the bullet and did a full reflash, which didn't help either.
Tried my previously working ota and now it's running again (I guess I
got mixed up with the versions earlier).
So my only remaining question is why doesn't flashing a factory image
help in this case? The way I see it, it was just a bad build?
sharkcow
Am 05.09.20 um 10:16 schrieb sharkcow:
> Hi all,
> I hope this is the right place to ask...
> Since flashing a new build yesterday, my OVMS doesn't boot normally
> anymore. What I see in the USB console are 5 early crashes (reason 12
> for both CPUs), then the module falls back to running without auto init.
> What I have tried: switching to previously working ota, flashing &
> booting factory images 3.2.15 and 3.2.14 from dexter. Removed SD card
> since reason 12 may point to a vfs problem.
> What else can I try? In my understanding it doesn't make sense to do a
> full reflash incl. boot loader, since booting as such works... or am I
> mistaken?
> Is any other information necessary to tell what's wrong?
> Thank you!
> sharkcow
> dump from 3.2.14:
> I (121) boot: Initialising BOOT (1100)
> I (125) boot: Boot #4 reasons for CPU0=12 and CPU1=12
> I (131) boot: Reset reason Exception/panic (4)
> E (136) boot: Early crash #4 detected
> I (141) events: Initialising EVENTS (1200)
> I (3250) housekeeping: Auto init vehicle (free: 133748 bytes)
> Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was
> unhandled.
> Core 1 register dump:
> PC : 0x401642d9 PS : 0x00060530 A0 : 0x801643a7 A1
> : 0x3ffc3050
> A2 : 0x3ffb8190 A3 : 0x3ffc30e0 A4 : 0x00000001 A5
> : 0x3ffc30a8
> A6 : 0x3ffc3090 A7 : 0x3ffb732c A8 : 0x801642d3 A9
> : 0x3ffc3020
> A10 : 0x00000000 A11 : 0x3ffc30e0 A12 : 0x3ffc3050 A13
> : 0x0000ff00
> A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000008
> EXCCAUSE: 0x0000001d
> EXCVADDR: 0x0000000e LBEG : 0x4008be55 LEND : 0x4008be65 LCOUNT
> : 0xfffffffb
> ELF file SHA256: 01e6f0fccd1fb186
> Backtrace: 0x401642d9:0x3ffc3050 0x401643a4:0x3ffc3090
> 0x400f7e83:0x3ffc3110 0x400f7a92:0x3ffc3180 0x400f8eb6:0x3ffc31c0
> 0x400f9051:0x3ffc31f0 0x400f9138:0x3ffc3240 0x400f9199:0x3ffc3270
