[Ovmsdev] WiFi connect to non-broadcast SSID broken
Wed Sep 2 05:25:53 HKT 2020
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200901/d8c36cc5/attachment.htm>
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.09.01 13:33:39 =~=~=~=~=~=~=~=~=~=~=~=
OVMS#
wifi
wifi
wifi mode apclient OVMS Netgear_Guest2
wifi
I (65389854) ovms-server-v2: Send MP-0 S95.0,M,1,0,done,standard,159,148,24,0,0,410,7,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0
I (65389864) ovms-server-v2: Send MP-0 D78,128,5,25,24,25,7775,539363,0,65389,24,2,1,1,13.02,0,12.6,0,25,0,0
I (65389864) ovms-server-v2: Send MP-0 L38.958851,-121.111031,314,381,1,1,0,7775,0,0.398,0,0
I (65389864) ovms-server-v2: Send MP-0 F3.2.014/ota_1/eap (build idf v3.3.2-881-g22d636b Aug  4 2020 16:26:20),5YJRE1A16A1000834,22,1,TR2N,Netgear_Guest2
OVMS# wifi
wifi mode client gregnet 40:b0:76:32:ea:72
Starting WIFI as a client to gregnet (40:b0:76:32:ea:72)...
OVMS#
I (65392534) esp32wifi: Stopping WIFI station
I (65392534) netmanager: WIFI client stop
I (65392534) netmanager: Interface priority is pp3 (10.52.33.103/255.255.255.255 gateway 10.64.64.64)
I (65392534) netmanager: Set DNS#0 9.9.9.9
I (65392534) netmanager: Set DNS#1 8.8.8.8
I (65392534) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
I (65392534) wifi:state: run -> init (0)
I (65392544) wifi:pm stop, total sleep time: 627018803 us / 667166463 us
I (65392544) wifi:new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:1
I (65392544) ovms-server-v2: Status: Disconnected
W (65392554) netmanager: CleanupConnections: can't get AP station list
I (65392554) wifi:flush txq
I (65392554) wifi:stop sw txq
I (65392554) wifi:lmac stop hw txq
I (65392564) time: Network was reconfigured: restarting SNTP client
I (65392574) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65392574) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65392594) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE
I (65392624) netmanager: WIFI access point is down
I (65392624) esp32wifi: AP stopped
I (65393074) wifi:mode : sta (30:ae:a4:43:92:88)
OVMS#
I (65395254) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68
I (65395384) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
I (65396084) wifi:state: init -> auth (b0)
I (65396094) wifi:state: auth -> assoc (0)
I (65396104) wifi:state: assoc -> run (10)
OVMS#
I (65400944) housekeeping: 2020-09-01 13:33:59 PDT (RAM: 8b=82676-83308 32b=9576)
OVMS#
I (65401854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B
I (65401854) ovms-server-v2: Status: Connecting...
OVMS#
I (65402454) ovms-server-v2: Connection successful
I (65402454) ovms-server-v2: Status: Logging in...
I (65402454) ovms-server-v2: Sending server login: MP-C 0 3tU3AjUBWDjTegrKhFv8SQ rvrEFsVvIpc1WcPcnFTuAA== ROADSTER834B
OVMS#
W (65402854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65402854) esp32wifi: StartConnect: error 0xffffffff starting scan
I (65402974) ovms-server-v2: Got server response: MP-S 0 +8G+EBcHanqxI+T5lvipOU p23wI7eWAhPkK6DU97Iu7A==
I (65402974) ovms-server-v2: Server token is +8G+EBcHanqxI+T5lvipOU and digest is p23wI7eWAhPkK6DU97Iu7A==
I (65402974) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (65402974) ovms-server-v2: Shared secret key is +8G+EBcHanqxI+T5lvipOU3tU3AjUBWDjTegrKhFv8SQ (44 bytes)
I (65402974) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
I (65402984) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS#
I (65404214) wifi:state: run -> init (fc0)
I (65404214) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65404224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65404234) esp32wifi: STA disconnected with reason 15 = 4WAY_HANDSHAKE_TIMEOUT
OVMS# wifi
I (65414914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68
I (65415034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65415034) wifi:state: init -> auth (b0)
I (65415044) wifi:state: auth -> assoc (0)
I (65415044) wifi:state: assoc -> run (10)
OVMS# wifi
Power: on
Mode: Client mode
STA SSID: Netgear_Guest2 (-127.0 dBm) [fixed]
  MAC: 00:00:00:00:00:00
  IP: 0.0.0.0/0.0.0.0
  GW: 0.0.0.0
  AP: 00:00:00:00:00:00
OVMS#
W (65422854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65422854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS#
I (65423144) wifi:state: run -> init (fc0)
I (65423154) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
wifi
I (65434914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69
I (65435034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65435034) wifi:state: init -> auth (b0)
I (65435034) wifi:state: auth -> assoc (0)
I (65435044) wifi:state: assoc -> run (10)
OVMS# wifi mode client gregnet 40:b0:76:32:ea:72
OVMS#
I (65437934) wifi:state: run -> init (0)
I (65437934) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65437944) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE
OVMS#
I (65452544) event: station ip lost
I (65452554) esp32wifi: STA lost IP from SSID 'gregnet' AP 00:00:00:00:00:00
OVMS#
wifi
Power: on
Mode: Client mode
STA SSID: gregnet (-127.0 dBm) [fixed]
  IP: 0.0.0.0/0.0.0.0
  GW: 0.0.0.0
OVMS#
wifi
OVMS#
wifi
Power: on
Mode: Client mode
  IP: 0.0.0.0/0.0.0.0
  GW: 0.0.0.0
OVMS#
wifi
wifi
wifi
wifi
wifi
Starting WIFI as Access Point and Client...
OVMS#
I (65544274) esp32wifi: Stopping WIFI station
I (65544284) wifi:flush txq
I (65544284) wifi:stop sw txq
I (65544284) wifi:lmac stop hw txq
I (65544804) wifi:mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89)
I (65544804) wifi:Total power save buffer number: 8
I (65544854) netmanager: WIFI access point is up
I (65544854) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1
OVMS#
I (65547284) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68
I (65547414) wifi:ap channel adjust o:1,1 n:6,2
I (65547414) wifi:new:<6,0>, old:<1,1>, ap:<6,2>, sta:<6,0>, prof:1
OVMS#
I (65548114) wifi:state: init -> auth (b0)
I (65548144) wifi:state: auth -> assoc (0)
I (65548144) wifi:state: assoc -> run (10)
I (65548194) wifi:connected with Netgear_Guest2, aid = 1, channel 6, BW20, bssid = 40:b0:76:32:ea:72
I (65548194) wifi:security type: 3, phy: bgn, rssi: -67
I (65548194) wifi:pm start, type: 1
I (65548204) esp32wifi: STA connected with SSID: Netgear_Guest2, BSSID: 40:b0:76:32:ea:72, Channel: 6, Auth: WPA2
I (65548354) wifi:AP's beacon interval = 102400 us, DTIM period = 3
OVMS#
I (65549944) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1
I (65549964) netmanager: WIFI client got IP
I (65549964) esp32wifi: STA got IP with SSID 'Netgear_Guest2' AP 40:b0:76:32:ea:72: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1
I (65549994) netmanager: WIFI client has good signal quality (-86.7 dBm); connect
I (65549994) netmanager: Interface priority is st21 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)
I (65549994) netmanager: Set DNS#0 9.9.9.9
I (65549994) netmanager: Set DNS#1 8.8.8.8
I (65549994) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority
I (65550034) time: Network was reconfigured: restarting SNTP client
I (65550034) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65550034) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65550044) ovms-server-v2: Status: Disconnected
OVMS#
wifi
Power: on
Mode: Access-Point + Client mode
STA SSID: Netgear_Guest2 (-68.2 dBm) [fixed]
  IP: 10.30.1.105/255.255.255.0
  GW: 10.30.1.1
  AP: 40:b0:76:32:ea:72
AP SSID: OVMS
  IP: 192.168.4.1
  AP Stations: 0
OVMS#
I (65609854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B
I (65609854) ovms-server-v2: Status: Connecting...
OVMS#
I (65610484) ovms-server-v2: Connection successful
I (65610484) ovms-server-v2: Status: Logging in...
I (65610484) ovms-server-v2: Sending server login: MP-C 0 ETTIk8+djSnT2pvZkaoXqP noJBBLMTQuDoIULvoK4vaA== ROADSTER834B
OVMS#
I (65610794) ovms-server-v2: Got server response: MP-S 0 ICVwbgzYKsBHB76n8Dhvh0 cDdLQRD5nBdzLGNKZtymRA==
I (65610794) ovms-server-v2: Server token is ICVwbgzYKsBHB76n8Dhvh0 and digest is cDdLQRD5nBdzLGNKZtymRA==
I (65610804) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (65610804) ovms-server-v2: Shared secret key is ICVwbgzYKsBHB76n8Dhvh0ETTIk8+djSnT2pvZkaoXqP (44 bytes)
I (65610804) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
I (65610824) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS#
wifi
wifi
OVMS#
I (65626034) esp32wifi: Stopping WIFI station
I (65626034) netmanager: WIFI client stop
I (65626034) netmanager: Interface priority is pp3 (10.52.33.103/255.255.255.255 gateway 10.64.64.64)
I (65626034) netmanager: Set DNS#0 9.9.9.9
I (65626034) netmanager: Set DNS#1 8.8.8.8
I (65626034) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
I (65626044) wifi:state: run -> init (0)
I (65626044) wifi:pm stop, total sleep time: 71417171 us / 77847939 us
I (65626044) wifi:new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:1
I (65626054) ovms-server-v2: Status: Disconnected
W (65626064) netmanager: CleanupConnections: can't get AP station list
I (65626064) wifi:flush txq
I (65626064) wifi:stop sw txq
I (65626064) wifi:lmac stop hw txq
I (65626074) time: Network was reconfigured: restarting SNTP client
I (65626074) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65626074) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65626094) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE
I (65626124) netmanager: WIFI access point is down
I (65626124) esp32wifi: AP stopped
I (65626574) wifi:mode : sta (30:ae:a4:43:92:88)
OVMS#
I (65628764) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68
I (65628884) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
I (65629594) wifi:state: init -> auth (b0)
I (65629604) wifi:state: auth -> assoc (0)
I (65629614) wifi:state: assoc -> run (10)
OVMS#
W (65635854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65635854) esp32wifi: StartConnect: error 0xffffffff starting scan
I (65635854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B
I (65635854) ovms-server-v2: Status: Connecting...
OVMS#
I (65636384) ovms-server-v2: Connection successful
I (65636384) ovms-server-v2: Status: Logging in...
I (65636384) ovms-server-v2: Sending server login: MP-C 0 fP1CbH+MJWKj2XaEcw8rDr d4NYQ2/bqw445o92cdIQGQ== ROADSTER834B
OVMS#
I (65636904) ovms-server-v2: Got server response: MP-S 0 yEAMezBVOYp1Im8YoKC6lP L5PXJRAw90Ue1YaTrisN0A==
I (65636904) ovms-server-v2: Server token is yEAMezBVOYp1Im8YoKC6lP and digest is L5PXJRAw90Ue1YaTrisN0A==
I (65636904) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (65636904) ovms-server-v2: Shared secret key is yEAMezBVOYp1Im8YoKC6lPfP1CbH+MJWKj2XaEcw8rDr (44 bytes)
I (65636904) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
I (65636914) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS#
I (65637674) wifi:state: run -> init (fc0)
I (65637684) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65637694) esp32wifi: STA disconnected with reason 15 = 4WAY_HANDSHAKE_TIMEOUT
OVMS#
I (65647914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68
I (65648034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65648034) wifi:state: init -> auth (b0)
I (65648054) wifi:state: auth -> assoc (0)
I (65648074) wifi:state: assoc -> run (10)
OVMS#
W (65655854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65655854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS#
I (65656434) wifi:state: run -> init (fc0)
I (65656434) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
I (65667914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-67
I (65668034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65668034) wifi:state: init -> auth (b0)
I (65668044) wifi:state: auth -> assoc (0)
I (65668054) wifi:state: assoc -> run (10)
OVMS#
W (65675854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65675854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS#
I (65676074) wifi:state: run -> init (fc0)
I (65676074) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
I (65686054) event: station ip lost
I (65686064) esp32wifi: STA lost IP from SSID 'Netgear_Guest2' AP 00:00:00:00:00:00
OVMS#
I (65687914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69
I (65688034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65688034) wifi:state: init -> auth (b0)
I (65688044) wifi:state: auth -> assoc (0)
I (65688054) wifi:state: assoc -> run (10)
OVMS# wi
W (65695854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65695854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS# wi
I (65696154) wifi:state: run -> init (fc0)
I (65696164) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# wi
Power: on
Mode: Client mode
  IP: 0.0.0.0/0.0.0.0
  GW: 0.0.0.0
OVMS#
I (65700934) housekeeping: 2020-09-01 13:38:59 PDT (RAM: 8b=82204-83048 32b=9576)
OVMS#
I (65707914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69
I (65708034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65708034) wifi:state: init -> auth (b0)
I (65708034) wifi:state: auth -> assoc (0)
I (65708044) wifi:state: assoc -> run (10)
OVMS#
W (65715854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65715854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS#
I (65716224) wifi:state: run -> init (fc0)
I (65716224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
wi
Power: on
Mode: Client mode
  IP: 0.0.0.0/0.0.0.0
  GW: 0.0.0.0
OVMS#
I (65727914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69
I (65728034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65728034) wifi:state: init -> auth (b0)
I (65728034) wifi:state: auth -> assoc (0)
I (65728054) wifi:state: assoc -> run (10)
OVMS#
W (65735854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65735854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS#
I (65736084) wifi:state: run -> init (fc0)
I (65736094) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
I (65747914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68
I (65748034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65748034) wifi:state: init -> auth (b0)
I (65748034) wifi:state: auth -> assoc (0)
I (65748054) wifi:state: assoc -> run (10)
OVMS#
W (65755854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65755854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS#
I (65756134) wifi:state: run -> init (fc0)
I (65756134) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
wi
Power: on
Mode: Client mode
  IP: 0.0.0.0/0.0.0.0
  GW: 0.0.0.0
OVMS#
wi
wi
wi
I (65767914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69
I (65768034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65768034) wifi:state: init -> auth (b0)
I (65768064) wifi:state: auth -> assoc (0)
I (65768074) wifi:state: assoc -> run (10)
wifi
W (65775854) wifi:sta_scan: STA is connecting, scan are not allowed!
E (65775854) esp32wifi: StartConnect: error 0xffffffff starting scan
OVMS# wifi mode apclient OVMS Netgear_Guest2
I (65776184) wifi:state: run -> init (fc0)
I (65776184) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
I (65783094) esp32wifi: Stopping WIFI station
I (65783104) wifi:flush txq
I (65783104) wifi:stop sw txq
I (65783104) wifi:lmac stop hw txq
I (65783624) wifi:mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89)
I (65783634) wifi:Total power save buffer number: 8
I (65783674) netmanager: WIFI access point is up
I (65783674) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1
OVMS#
I (65786114) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-67
I (65786234) wifi:ap channel adjust o:1,1 n:6,2
I (65786234) wifi:new:<6,0>, old:<1,1>, ap:<6,2>, sta:<6,0>, prof:1
OVMS#
I (65786944) wifi:state: init -> auth (b0)
I (65786954) wifi:state: auth -> assoc (0)
I (65786964) wifi:state: assoc -> run (10)
I (65787004) wifi:connected with Netgear_Guest2, aid = 1, channel 6, BW20, bssid = 40:b0:76:32:ea:72
I (65787004) wifi:security type: 3, phy: bgn, rssi: -67
I (65787004) wifi:pm start, type: 1
I (65787014) wifi:AP's beacon interval = 102400 us, DTIM period = 3
I (65787024) esp32wifi: STA connected with SSID: Netgear_Guest2, BSSID: 40:b0:76:32:ea:72, Channel: 6, Auth: WPA2
I (65787044) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1
I (65787064) netmanager: WIFI client got IP
I (65787064) esp32wifi: STA got IP with SSID 'Netgear_Guest2' AP 40:b0:76:32:ea:72: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1
OVMS#
I (65788854) netmanager: WIFI client has good signal quality (-86.3 dBm); connect
I (65788864) netmanager: Interface priority is st24 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)
I (65788864) netmanager: Set DNS#0 9.9.9.9
I (65788864) netmanager: Set DNS#1 8.8.8.8
I (65788864) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority
I (65788904) time: Network was reconfigured: restarting SNTP client
I (65788904) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65788904) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
I (65789034) ovms-server-v2: Status: Disconnected
OVMS#
wi
Power: on
STA SSID: Netgear_Guest2 (-68.1 dBm) [fixed]
  GW: 10.30.1.1
AP SSID: OVMS
  IP: 192.168.4.1
  AP Stations: 0
OVMS#
