[Ovmsdev] Reset Standard Metrics on vehicle change
Soko ovms at soko.cc
Thu Sep 10 20:10:07 HKT 2020
Heya,
In this particular case:
The user changes between VWUP.T26 and VWUP.OBD and was wondering about
the weird range metrics...
The issue is that OBD doesn't set the range... or T26 doesn't set the
voltage. So he is left with values in the metrics although those are not
set by the current/active vehicle.
Soko
On 10.09.2020 14:06, Michael Balzer wrote:
> Soko,
> what do you mean by vehicle change?
> Am 10.09.20 um 13:33 schrieb Soko:
>> Hi again,
>> Another issue reported is about (persistent) metrics who keep there
>> value after vehicle change. First I thought the vehicles need to
>> address this. But wouldn't it be better that all standard metrics get
>> a reset on every vehicle change?
>> Soko
