[Ovmsdev] Firmware release handling
Soko
ovms at soko.cc
Tue Sep 8 17:15:25 HKT 2020
Thanks Mark, got it!
Just to be complete: The user docs are a live view of the master branch,
correct?
Soko
On 08.09.2020 09:58, Mark Webb-Johnson wrote:
> Soko,
> From the original announcement on this:
> To try to avoid a repeat of the 3.1.007 issue with OTA updates,
> I’ve set things up as below:
> * edge: Bleeding edge developer, built automatically each night
> with 3.1.XXX-N-HHHHHH style versioning
> * eap: Early Access Program pre-releases, usually with 3.1.XXX
> style versioning
> * main: Stable releases that have completed testing in EAP, with
> 3.1.XXX style versioning.
> Before moving things edge -> eap, I’ll have a checklist of
> regression tests to run (including ota update). Other functional
> problems should have been picked up by developer cars while in
> ‘edge’ release. I suggest to leave a particular build in ‘edge’
> for a week, to make sure no problems reported to those early
> real-world testers, before moving to ‘main’.
> I have an automated nightly build script that runs at 4pm UTC
> (midnight HKT). That pulls the latest masters for esp-idf and ovms
> firmware, then builds as appropriate. If there is something to
> build (something in git changed), it does it automatically and
> produces an email summary like this:
> Subject: OVMS Nightly Firmware Build 3.1.008-13-g272697e
> 3.1.008-13-g272697e
> Thu Jun 28 00:57:19 UTC 2018 Automated build (markhk8)
> Total sizes:
> DRAM .data size: 17116 bytes
> DRAM .bss size: 33536 bytes
> Used static DRAM: 50652 bytes ( 130084 available, 28.0% used)
> Used static IRAM: 102096 bytes ( 28976 available, 77.9% used)
> Flash code: 1279002 bytes
> Flash rodata: 598168 bytes
> Total image size:~1996382 bytes (.bin may be padded larger)
> * 272697e (HEAD, origin/master, origin/HEAD, master) Twizy: no
> sufficient level info on charge done
> * 8497d9f Web dashboard: range display min/max exchanged
> * 5d8f96d Webserver: fix u64 alignment
> * 5363ab8 TeslaRoadster: Vehicle cooldown command and
> implementation
> * bf3b0d5 TeslaRoadster: Digital Speedo implementation
> * d0221bf TeslaRoadster: Refuse to lock a car that is ON
> * 7179600 Update project status files
> * b3bef78 TeslaRoadster: Digital Speedo implementation
> * cfbd297 TeslaRoadster: Vehicle cooldown command and
> implementation
> * ec4bc37 Add VehicleModeKey helper function
> At the moment, that summary comes to me. Is there any use sending
> it to the ovmsdev mailing list?
> With developer cars set to ‘edge’, and automatically updating each
> night, hopefully with this three stage process we can pickup on
> problems before they hit the main stable trunk.
> This is all from ‘master’ and unrelated to braches (which are
> experimental and usually hand-built).
>> https://www.openvehicles.com/node/2592 shows v3.2.015 since a couple
>> of minutes. Is this the "main” channel
> Usually, unless we explicitly say ’to early access program’.
>> changes.txt shows v3.2.015 for 2nd of Sep. Website says 8th…
> The v3.2.015 code was fixed and tagged on 2nd Sep, then release to EAP.
> It went to MAIN on 8th Sep (after EAP testing).
> Regards, Mark
>> On 8 Sep 2020, at 3:47 PM, Soko <ovms at soko.cc <mailto:ovms at soko.cc>>
>> wrote:
>> Hey guys,
>> I'm wondering a while now how the firmware release process is working
>> in OVMS.
>> I have found in the OVMS settings that I can choose "main", "eap" or
>> "edge" as the update channel...
>> How does this relate to the github branches?
>> of minutes. Is this the "main" channel? VWUP.OBD is not listed
>> there... but in the user docs it is already:
>> https://docs.openvehicles.com/en/latest/components/vehicle_vweup_obd/docs/index.html
>> changes.txt shows v3.2.015 for 2nd of Sep. Website says 8th...
>> Not that all the details here need to be perfectly matching. Was just
>> wondering about a coarse grained info about the process...
>> thanks
>> Soko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200908/4235795f/attachment.html>
