[Ovmsdev] Issues since latest update (3.2.0.14)
Tue Sep 8 13:50:46 HKT 2020
Mark,
shall we proceed to "main"?
Am 02.09.20 um 09:23 schrieb Mark Webb-Johnson:
> Michael,
> Thanks.
> The impacting issue I am seeing is that new users are coming onboard
> our platform, and the first thing they do is upgrade to the latest
> (3.2.014) during the install process. They then get continuous
> crashes. The CAN bus errors shown in the car are also very scary. I
> think it best to replace 3.2.014 asap. My only concern is if there is
> anything newly broken in 3.2.015.
>> On 2 Sep 2020, at 2:55 PM, Michael Balzer <dexter at expeedo.de
>> OK, followed on my server.
>> It would have been an option to first let the users with issues test
>> the edge version. But I think the release should be OK, crash
>> statistics of the current version look much better so far.
>> Am 02.09.20 um 02:27 schrieb Mark Webb-Johnson:
>>> I’ve tagged, built, and released to EAP, 3.2.015 - based on head of
>>> edge.
>>> Not sure if this is generally releasable at this point (perhaps too
>>> rushed), but that should make it easier to access.
>>>> On 2 Sep 2020, at 2:38 AM, Derek Caudwell <d.caudwell at gmail.com
>>>> <mailto:d.caudwell at gmail.com>> wrote:
>>>> Hi,
>>>> Looking at the differences between 3.2.0.14 and earlier it looks
>>>> like the use of EV Can rather than CAR Can to enable battery
>>>> monitoring on the Leaf was the main trigger for frequent event
>>>> crashes (fixed 31/8 in commit
>>>> |07f25e3).|The polling being turned on (when vehicle ON was
>>>> set) being more noticeable than at other times as both
>>>> buses have a lot of traffic - but still not guaranteed to
>>>> cause a crash as reported by GlynHudson in issue #409.
>>>> Based on my own experience this issue could still occur
>>>> randomly but less frequently when the vehicle was off/not
>>>> polling.
>>>> The issue would still occur even if enable canwrites were set to
>>>> off as reported by GlynHudson in #409, as canwrite logic was not
>>>> implemented in the Leaf code until 19/8 in commit 41ac2f1.
>>>> A temporary workaround was also implemented in the Leaf code to
>>>> switch buses prior to polling on 16/8 in commit
>>>> |32db785.|
>>>> The subsequent poller rework has enabled the Leaf to direct polls
>>>> to the correct bus, allowing the PID polls originally defined (but
>>>> not working depending on the car state) to function when the
>>>> vehicle is on or off and charging. Also the IncomingPollReply code
>>>> was tidied up and aligned with that used for the Twizy. The vehicle
>>>> poller extra frame request delay was also originally fixed at 25ms
>>>> uneccessarily slowing down large replies such as the battery cell
>>>> voltage responses, now set to 0. These changes mean the polling for
>>>> the Leaf is now working as it should.
>>>> The current edge version appears to be stable and allows PID
>>>> polling reliably to both buses without causing crashes. I have been
>>>> running it for 24h with 6 start/stop events without issue.
>>>> If others agree could 3.2.0.15 be staged for EAP release to move
>>>> Leaf users off 3.2.0.14? A note could be to 3.2.0.14 stating there
>>>> is a known stability issue on the Leaf and to use 3.2.0.15 or similar.
>>>> GlynHudson and others on other Leaf models can test to ensure we
>>>> are back to a stable release with the required polling
>>>> functionality working.
>>>> Kind regards
>>>> Derek
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200908/6ea25bd1/attachment.html>
