[Ovmsdev] OBD/UDS Poller receiver rework
Sun Sep 6 14:50:54 HKT 2020
Thomas found a bug in the new poll response identification. Fix is
pushed, please update.
Am 05.09.20 um 21:36 schrieb Soko:
> Thanks Michael, will give this a try and report back.
> On 05.09.2020 16:31, Michael Balzer wrote:
>> Everyone,
>> the multi bus polling extension is now merged, and I have just added
>> support for more service types, and requests w/o PIDs and/or with
>> additional non-PID parameters.
>> This is meant to support e.g. read & clear DTC operations (UDS
>> service types 0x19 & 0x14). I have added some more UDS service types
>> I think might be useful.
>> Please test & report issues if any.
>> To add parameter data to a poll entry, use the template shown in
>> vehicle.c:
>> // const OvmsVehicle::poll_pid_t twizy_poll_default[] = {
>> // { TXID, RXID, VEHICLE_POLL_TYPE_READDTC, {.args={ PID, DATALEN,
>> DATA1, … }}, { 0, 10, 60, 0 }, 0 },
>> @Soko: this UDS service could be especially useful for you, if the
>> e-Up supports this:
>> #define VEHICLE_POLL_TYPE_READSCALING 0x24 // UDS:
>> ReadScalingDataByIdentifier (16 bit PID)
>> If you can get the scaling info for the "weird" Ah & kWh counters,
>> that may give you an exact info on how to interpret these. On
>> decoding the response see the ISO 14229 PDF, section 10.4 and annex C.
>> Example for a DTC read:
>> OVMS# xrt obd request bms 19020f
>> Response:
>> 4f 3b 2d 00 48 3a 2d 00 48 53 2d 60 48 54 2d 60 | O;-.H:-.HS-`HT-`
>> 48 02 00 00 48 | H...H
>> This is a standard DTC response, but the codes are mostly
>> non-standard Renault or LG codes:
>> 4f = StatusAvailabilityMask
>> 3b 2d 00 = DTC #1: P3B2D = unknown: ISO/SAE reserved code
>> … 48 = DTC Status: s.b. -- confirmedDTC +
>> testNotCompletedThisOperationCycle
>> 3a 2d 00 = DTC #2: P3A2D = unknown: ISO/SAE reserved code
>> 53 2d 60 = DTC #3: C132D-60 = custom
>> 54 2d 60 = DTC #4: C142D-60 = custom
>> 02 00 00 = DTC #5: P0200 = "Injector Circuit/Open" (?)
>> DTC High Byte:
>> bit 7+6: 00 = 'P' (powertrain), 01 = 'C' (chassis), 10 = B (body),
>> 11 = U (network/user)
>> bit 5+4: digit 1: 01 = manufacturer controlled, 00/10/11 = ISO/SAE
>> controlled
>> bit 3-0: digit 2
>> DTC Status Byte:
>> bit # hex state description
>> 0 0x01 testFailed DTC failed at the time of the request
>> 1 0x02 testFailedThisOperationCycle DTC failed on the
>> current operation cycle
>> 2 0x04 pendingDTC DTC failed on the current or previous
>> operation cycle
>> 3 0x08 confirmedDTC DTC is confirmed at the time of the
>> request
>> 4 0x10 testNotCompletedSinceLastClear DTC test not
>> completed since the last code clear
>> 5 0x20 testFailedSinceLastClear DTC test failed at least
>> once since last code clear
>> 6 0x40 testNotCompletedThisOperationCycle DTC test not
>> completed this operation cycle
>> 7 0x80 warningIndicatorRequested Server is requesting
>> warningIndicator to be active
>> Am 30.08.20 um 09:05 schrieb Michael Balzer:
>>> Merged into the master.
>>> Derek's multi bus polling extension is still in the works and not
>>> included in the merge.
>>> Am 28.08.20 um 21:15 schrieb Michael Balzer:
>>>> Thanks to Soko (UpMiiGo tests) and Thomas (Smart rewrite & tests).
>>>> The Smart code makes extensive use of polling, so we're probably
>>>> good to go.
>>>> If other vehicle maintainers would like to test before merging into
>>>> the master, please let me know.
>>>> Regards,
>>>> Michael
>>>> Am 28.08.20 um 15:28 schrieb Soko:
>>>>> Hi Michael,
>>>>> I can give you a :thumbup: from the UpMiiGo department. First test
>>>>> of the changes (including a short drive) showed no issues. Neither
>>>>> with the fast-polling nor with the multi-frame-processing with
>>>>> OBDIIEXTENDED.
>>>>> thanks
>>>>> Soko
>>>>> On 27.08.2020 22:00, Michael Balzer wrote:
>>>>>> Everyone,
>>>>>> I've just pushed the poller receiver changes I announced into the
>>>>>> new "poller-rework" branch:
>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/0b306ad4f5e7a1eb63a471a11ec7f1a6d69d8647
>>>>>> OBD/UDS Poller Receiver Rework:
>>>>>> - Fix race condition between CAN RX and PollerReceive
>>>>>> - Separation of ISO-TP & OBD/UDS layer meta data analysis
>>>>>> - Fix incomplete meta data validation
>>>>>> - Allow single/multi frame responses on all service types
>>>>>> - Validate multi frame response sequences
>>>>>> - Fix single frame payload lengths
>>>>>> - Fix type 0x22 first frame payload offset & overall length
>>>>>> - Add negative response code handling → IncomingPollError()
>>>>>> - Add response frame timing control → PollSetResponseSeparationTime()
>>>>>> This rework has been on my list for some time before, as the
>>>>>> previous solution had some general shortcomings, especially by
>>>>>> it's hard coded coupling of the expected response transport form
>>>>>> with the request type, which fails already on some type 0x01
>>>>>> requests.
>>>>>> The major bug in the receiver that now triggered the rework was
>>>>>> in the overall payload length calculation and the first frame
>>>>>> payload passing of the type 0x22
>>>>>> (VEHICLE_POLL_TYPE_OBDIIEXTENDED) multi frame response handling.
>>>>>> That up to now basically only turned up as a visible issue for
>>>>>> the Smart ED, as all other vehicles either don't get multi frame
>>>>>> responses on 0x22 queries or (like the Kia) generally discard the
>>>>>> first frame and don't use the overall length at all.
>>>>>> On the Smart ED, all handlers have been deliberately written
>>>>>> assuming the bug was a feature -- all payload addressing is
>>>>>> shifted by one byte. This needs to be rewritten now.
>>>>>> All other vehicles should not see any difference and should not
>>>>>> need to change any code. Except maybe in the UpMiiGo development,
>>>>>> which isn't yet part of the master.
>>>>>> Other bugs like the missing frame sequence validation and late
>>>>>> response detection may have been the causes for some spurious and
>>>>>> hard to track crashes and data errors. We should try to get this
>>>>>> change tested short term on "edge", so we can see if this
>>>>>> actually improves stability as I hope.
>>>>>> As this is a major rework (mainly of the PollerReceive() method),
>>>>>> audits and tests are very welcome. I can only test on the Twizy,
>>>>>> which doesn't make much use of the poller yet.
>>>>>> You can see what the new poller does by raising the log level for
>>>>>> "vehicle" to debug. Example of some Twizy regular polling:
>>>>>> D (136323) vehicle: PollerSend(1): send [type=10, pid=C0],
>>>>>> expecting 743/763-763
>>>>>> D (136343) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 10(C0) frm=0 len=0 off=0 rem=0
>>>>>> V (136343) v-twizy: OBD2: ignored reply [10 c0]
>>>>>> D (137323) vehicle: PollerSend(1): send [type=21, pid=81],
>>>>>> D (137343) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(81) frm=0 len=4 off=0 rem=15
>>>>>> D (137373) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(81) frm=1 len=7 off=4 rem=8
>>>>>> D (137403) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(81) frm=2 len=7 off=11 rem=1
>>>>>> D (137423) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(81) frm=3 len=1 off=18 rem=0
>>>>>> D (137433) v-twizy: OBD2: got VIN='XXXXXXXXXXXXXXXXX'
>>>>>> D (138323) vehicle: PollerSend(1): send [type=21, pid=13],
>>>>>> D (138343) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=0 len=4 off=0 rem=106
>>>>>> D (138373) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=1 len=7 off=4 rem=99
>>>>>> D (138403) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=2 len=7 off=11 rem=92
>>>>>> D (138423) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=3 len=7 off=18 rem=85
>>>>>> D (138453) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=4 len=7 off=25 rem=78
>>>>>> D (138483) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=5 len=7 off=32 rem=71
>>>>>> D (138513) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=6 len=7 off=39 rem=64
>>>>>> D (138543) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=7 len=7 off=46 rem=57
>>>>>> D (138563) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=8 len=7 off=53 rem=50
>>>>>> D (138593) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=9 len=7 off=60 rem=43
>>>>>> D (138623) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=10 len=7 off=67 rem=36
>>>>>> D (138653) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=11 len=7 off=74 rem=29
>>>>>> D (138683) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=12 len=7 off=81 rem=22
>>>>>> D (138703) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=13 len=7 off=88 rem=15
>>>>>> D (138733) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=14 len=7 off=95 rem=8
>>>>>> D (138763) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=15 len=7 off=102 rem=1
>>>>>> D (138793) vehicle: PollerReceive[763]: process OBD/UDS response
>>>>>> 21(13) frm=16 len=1 off=109 rem=0
>>>>>> W (141323) v-twizy: OBD2 Cluster DTC NEW #01: 4/21 rev0 G1 INT
>>>>>> MEM Ef| @ 57871km 11kph SOC=60% BV=14V TC=0 IC=255
>>>>>> W (141333) v-twizy: OBD2 Cluster DTC NEW #02: 4/1 rev0 G1 MEM|
>>>>>> @ 57892km -1kph SOC=86% BV=14V TC=0 IC=255
>>>>>> W (141343) v-twizy: OBD2 Cluster DTC NEW #03: 1/37 rev0 G1 INT
>>>>>> MEM Ef| @ 57892km -1kph SOC=86% BV=14V TC=0 IC=255
>>>>>> W (141353) v-twizy: OBD2 Cluster DTC NEW #04: 3/59 rev0 G2 INT
>>>>>> MEM| @ 57926km 34kph SOC=78% BV=14V TC=0 IC=255
>>>>>> W (141363) v-twizy: OBD2 Cluster DTC NEW #05: 4/40 rev0 G2 MEM
>>>>>> Ef| @ 57926km 35kph SOC=78% BV=14V TC=0 IC=255
>>>>>> W (141373) v-twizy: OBD2 Cluster DTC NEW #06: 3/58 rev0 G2 INT
>>>>>> MEM| @ 58711km 41kph SOC=46% BV=14V TC=0 IC=255
>>>>>> A manual multi frame poll:
>>>>>> I (147723) webcommand: HttpCommandStream[0x3f8540f4]: 3801804
>>>>>> bytes free, executing: x o r bm 2104
>>>>>> D (148323) vehicle: PollerSend(1): send [type=21, pid=4],
>>>>>> expecting 79b/7bb-7bb
>>>>>> D (148343) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=0 len=4 off=0 rem=70
>>>>>> D (148353) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=1 len=7 off=4 rem=63
>>>>>> D (148393) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=2 len=7 off=11 rem=56
>>>>>> D (148433) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=3 len=7 off=18 rem=49
>>>>>> D (148473) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=4 len=7 off=25 rem=42
>>>>>> D (148513) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=5 len=7 off=32 rem=35
>>>>>> D (148553) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=6 len=7 off=39 rem=28
>>>>>> D (148593) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=7 len=7 off=46 rem=21
>>>>>> D (148633) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=8 len=7 off=53 rem=14
>>>>>> D (148673) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=9 len=7 off=60 rem=7
>>>>>> D (148713) vehicle: PollerReceive[7BB]: process OBD/UDS response
>>>>>> 21(4) frm=10 len=7 off=67 rem=0
>>>>>> OVMS# x o r bm 2104
>>>>>> Response:
>>>>>> 08 cc 3c 08 d4 3c 08 cb 3c 08 d6 3c 08 ce 3c 08 | ..<..<..<..<..<.
>>>>>> d1 3c 08 d2 3c ff ff ff ff ff ff ff ff ff ff ff | .<..<...........
>>>>>> ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff | ................
>>>>>> ff ff ff ff ff ff ff ff 3c 3c | ........<<
>>>>>> An example of the new error response handling:
>>>>>> I (165023) webcommand: HttpCommandStream[0x3f8479f4]: 3791052
>>>>>> bytes free, executing: x o r bm 221405
>>>>>> D (165323) vehicle: PollerSend(1): send [type=22, pid=1405],
>>>>>> D (165343) vehicle: PollerReceive[7BB]: process OBD/UDS error
>>>>>> 22(1405) code=11
>>>>>> OVMS# x o r bm 221405
>>>>>> ERROR: request failed with response error code 11
>>>>>> Code 11 = "serviceNotSupported" (see ISO 14229 Annex A.1 for more
>>>>>> codes)
>>>>>> Feedback is welcome.
>>>>>> Regards,
>>>>>> Michael
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200906/f2fcb6f3/attachment-0001.html>
