[Ovmsdev] WiFi connect to non-broadcast SSID broken
Tue Sep 1 11:23:29 HKT 2020
Looks like AP+Client mode is broken too.  Only Client mode to a
non-hidden AP seems to be working, and that only after a
manually-initiated scan.  I haven't (can't) test the automatic switching
between Cellular and WiFi, as the car is currently being worked on
(infamous PEM Fan connector).
I'm on the 3.2.014 EAP build from 4-August 2020.
Greg
Greg D. wrote:
> Hi folks,
> Looks like one of the updates broke the ability of OVMS to connect to a
> WiFi AP that isn't broadcasting its SSID.  Was this a known side effect
> of the WiFi refactoring?  Is there a parameter that I need to set on the
> module to allow the connection?
> Working around the issue by broadcasting my home SSID is NOT what I want
> to do.
> Greg
