[Ovmsdev] Default sub-command for location?
Tue Sep 1 08:22:22 HKT 2020
Yes, this should be the standard (for any command that implements ’status’).
I implemented this in the for-v3.3 branch. The following are affected:
canopen
egpio
location
ota
server v2
server v3
tls
tpms
re
sd
vehicle
bms
log
notify
event
I notice that there are a few subsystems that don’t have a ’status’ command at all. Perhaps that should be standardised as well?
> On 1 Sep 2020, at 2:03 AM, Craig Leres <leres at xse.com> wrote:
> Given that "simcom" defaults to "simcom status" (and you must use "simcom ?" to see all sub-commands) would it be reasonable for "location" to default to "location status"?
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200901/922d86b5/attachment.html>
