[Ovmsdev] Issues since latest update (3.2.0.14)
Tue Sep 1 01:28:52 HKT 2020
FYI: I also had a crash report from a guy with a 2018 Nissan eNV-200
40KW using the Leaf adaption.
He wrote the last working OVMS version was 3.2.013-223-g7c41d3a6, all
versions after that crash as soon as he starts the car.
I pointed him to the Leaf developers, but it seems he didn't manage to
file an issue.
Am 31.08.20 um 14:48 schrieb Sébastien Darveau:
> Hi Mark,
> I did change the DNS but it didn’t fix the problem so I reverted to
> previous version. It looks like it is Leaf 2015 specific as reported
> here by someone else:
> https://www.openvehicles.com/node/2587
> I suspect the new wifi feature because it seems to happen when leaving
> the wifi range.
> Thanks,
> Sebastien
>> On Aug 19, 2020, at 10:50 AM, Mark Webb-Johnson
>> <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> Please try with 8.8.8.8, to rule out a dns issue.
>> The reason I suggest this is because I have seen that ‘parse error’
>> before resulting from failed dns lookups.
>> Regards, ?Mark
>>> On 19 Aug 2020, at 9:08 PM, Sébastien Darveau
>>> <sebastien.darveau at synnoetic.com
>>> <mailto:sebastien.darveau at synnoetic.com>> wrote:
>>>  Strangely, it is connected on my home wifi. DNS are 212.9.0.135
>>> and 212.9.0.136 and I can resolve openvehicles.com
>>> <http://openvehicles.com/> correctly with nslookup on my laptop.
>>> Since everything works perfectly after a reboot, it is not a dns
>>> issue but a degradation while the box is running. It seems to worsen
>>> when going out of wifi range and back but I’m still not sure about this.
>>> A new error appeared this morning but probably unrelated:
>>> E (140391333) can: can1: intr=14187292 rxpkt=14151479 txpkt=3057
>>> errflags=0x8040d9 rxerr=0 txerr=131 rxovr=23 txovr=0 txdelay=0
>>> wdgreset=0 errreset=0
>>> Thanks,
>>> Sebastien
>>>> On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson
>>>> What are your DNS servers set to?
>>>> Can you try with 8.8.8.8, if you aren’t already, and don’t use
>>>> ISP/cellular DNS servers.
>>>> Regards, Mark.
>>>>> On 19 Aug 2020, at 2:02 AM, Sébastien Darveau
>>>>> Hello,
>>>>> Anyone else is having connection issues since latest update? I’m
>>>>> constantly loosing contact with the device and haven’t been able
>>>>> to open a console with USB but this time, I can still access it
>>>>> with the Web interface and noticed it can’t connect to server.
>>>>> E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867
>>>>> <http://api.openvehicles.com:6867/>) failed: cannot parse address
>>>>> E (72178423) ovms-server-v2: Status: Error: Connection failed
>>>>> W (72180093) simcom: UART hw fifo overflow
>>>>> W (72192873) gsm-mux: Frame overflow (2048 bytes)
>>>>> E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867
>>>>> E (72238423) ovms-server-v2: Status: Error: Connection failed
>>>>> E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870
>>>>> <http://api.openvehicles.com:6870/>) failed: cannot parse address
>>>>> E (72298463) ovms-server-v2: Status: Error: Connection failed
>>>>> Address looks good though.
>>>>> Sebastien Darveau
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200831/ccb5a88a/attachment.html>
