[Ovmsdev] Refactoring MODEM/SIMCOM for v3.3
Sat Oct 10 14:41:23 HKT 2020
Craig,
no wifi issues here running 3.2.015-151-g3377eed0. Did you try a clean
build?
Am 10.10.20 um 03:06 schrieb Craig Leres:
> I just tried updating my dev module from 3.2.014-103-gcf346399-dirty
> to 3.2.015-151-g3377eed0-dirty and I find the wifi stops working after
> a few minutes. Right after a boot I connect to the webserver but once
> I submit a page I start getting timeouts. I can also connect to the
> ssh port but ssh -v doesn't show any negotiation. I reverted to the
> older version and it works again.
> My only local changes are to ifdef out some simcom_7600.cpp init code
> so I can work on trying figure out the correct init sequence.
>         Craig
