[Ovmsdev] Modem won't start
Thu Oct 1 03:48:50 HKT 2020
Background on the PoweringOn issue for me was, that we yesterday had a
complete internet breakdown in our village. A digger cut a fibreglas
cable. 2000 people with no internet was the result ...
We still had DSL sync, but pppOE did not come through anymore.
I also have very poor (2G) connection with my OVMS sim at our house.
So I could think  of a scenario like this:
The car thinks- I am connected to wifi. Great, lets connect to the
server.- Hmmm, I can't reach the server. No DNS resolving.- Lets try
GSM- Hmmm, no connection to my provider- Lets try wifi again- Hmmm, no
resolving
And that for 14 hours, every few seconds ...
Well it is pure speculation, but perhaps of some help.
For now the system is completely broken. The system was down, I took it
out of the car and broke the USB connector again ...
I'm taking a break now. Not really having fun at the moment ...
Chris
Am Mittwoch, den 30.09.2020, 10:45 -0700 schrieb Craig Leres:
> On 2020-09-30 01:42, Chris van der Meijden wrote:
> > Oh boy ...
> > Found this one:
> > http://lists.openvehicles.com/pipermail/ovmsdev/2020-February/00664
> > 0.html
> > You indeed have to pull the fuse for a minute and not only for two
> > seconds ...
> > Very strange, but hey it works now :-)
> > Network Registration: RegisteredHome Provider: o2 - de+ Signal: -97
> > dBm
> > State: NetStart
> I have not seen this issue since Mark made the change in April
> described
> in the attached; he added a uart_flush() call to
> simcom::PowerCycle():
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/comm
> it/9de2ecd94da64da6496a57acd0286e48f93dd250
> 		Craig
> -------- Forwarded Message --------
> Subject: 	[Ovmsdev] Modem unable to power cycle successfully
> Date: 	Thu, 16 Apr 2020 10:40:20 +0800
> From: 	Mark Webb-Johnson <mark at webb-johnson.net>
> Reply-To: 	OVMS Developers <ovmsdev at lists.openvehicles.com>
> I’ve seen cases where the modem will not come up correctly, even
> following a power cycle. But, a reset of the OVMS module (ESP32)
> solves
> the problem. This really makes no sense, unless something is getting
> corrupted inside the UART / EGPIO driver itself. The modem module
> status
> is not changed during an ESP32 reset - only the software side of it
> running in the ESP32.
> Thomas Heder has reported some success with using uart_flush to
> flush
> the UART ring buffer when power cycling the modem. Flushing the
> buffer
> would not seem to affect this, as we use ‘AT’ to look for an OK
> response
> during power up check anyway; but perhaps something is corrupt in
> the
> ring buffer itself, so using uart_flush clears that problem.
> Note that uart_flush is an alias for uart_flush_input, and the
> source
> code does seem to show a complete reset of the ring buffer pointers
> with
> interrupts disabled (not just a simple emptying).
> Anyway, the approach does not seem to do any harm, so I have added it
> to
> the latest code and let’s see if it improves the situation.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issu
> es/354
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200930/61128986/attachment-0002.htm>
