[Ovmsdev] Fwd: [openvehicles/Open-Vehicle-Monitoring-System-3] OVMSDEV mailing list - is it still functioning? (#467)
Tue Nov 17 21:17:47 HKT 2020
Mark,
I could not forward the mail below to you, your server responded with…
<mark at webb-johnson.net>: host mailtp5.network-box.com[175.45.17.210] said: 554
     command rejected for policy reasons (using messageid:
     1d117116-28cb-11eb-af9f-7e589b37a1b9) (in reply to end of DATA command)
…which is probably a local issue, because my server is on no block list.
Can you have a look at the(se) issue(s)?
-------- Weitergeleitete Nachricht --------
Betreff: 	Re: [openvehicles/Open-Vehicle-Monitoring-System-3] OVMSDEV
Datum: 	Tue, 17 Nov 2020 03:06:05 -0800
Von: 	elbow <notifications at github.com>
Antwort an: 	openvehicles/Open-Vehicle-Monitoring-System-3
<reply+AAUU2QPIWGN6ZRPGNWBB7LV5X6HZ3EVBNHHCYREIHM at reply.github.com>
An: 	openvehicles/Open-Vehicle-Monitoring-System-3
<Open-Vehicle-Monitoring-System-3 at noreply.github.com>
Kopie (CC): 	Michael Balzer <dexter at expeedo.de>, Mention
<mention at noreply.github.com>
Hi @dexterbg <https://github.com/dexterbg> @markwj
<https://github.com/markwj> ,
The situation with the list is unchanged. I also received bounces from
my mails to lists.openvehicles.com:
`This is the mail system at host nbkfmailscanhq5.network-box.com.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
|The mail system |
< ovmsdev-owner at lists.openvehicles.com
<mailto:ovmsdev-owner at lists.openvehicles.com>>: connect to
10.8.12.188[10.8.12.188]:25:
Connection refused
So the mx targets for lists.openvehicles.com are "network-box.com"
machines. Apparently they can't forward to mail on?
For me I just want to be added to the dev mailing list. Can it be done
by hand?
I'm making good progress reverse engineering I3 canbus pids.
You are receiving this because you were mentioned.
Reply to this email directly, view it on GitHub
<https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/467#issuecomment-728855931>,
or unsubscribe
<https://github.com/notifications/unsubscribe-auth/AAUU2QMN7LH2HBRPKWYU5ZDSQJKJ3ANCNFSM4TU5CJCQ>.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201117/93e5ad71/attachment-0001.htm>
Type: application/pgp-keys
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201117/93e5ad71/attachment-0001.bin>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201117/93e5ad71/attachment-0001.sig>
