[Ovmsdev] PSRAM bugfix: next round
Soko ovms at soko.cc
Mon Nov 9 20:02:21 HKT 2020
PS: Forget it. I've did another git pull&update on esp-idf and it
downloaded something (again). now all works...
On 08.11.2020 12:22, Michael Balzer wrote:
> Everyone,
> the announced bug fix for the regression in toolchain
> 1.22.0-96-g2852398 has been released for esp-idf v3.3.
> I've merged the latest updates to esp-idf release 3.3.4 into our fork
> and added the new options to our default build configuration. This
> includes some additional PSRAM related fixes.
> The toolchain download links in the docs have not yet been updated.
> Use these links to download the new toolchain:
>   * Linux 64 bit:
>     https://dl.espressif.com/dl/xtensa-esp32-elf-linux64-1.22.0-97-gc752ad5-5.2.0.tar.gz
>   * MacOS:
>     https://dl.espressif.com/dl/xtensa-esp32-elf-macos-1.22.0-97-gc752ad5-5.2.0.tar.gz
>   * Windows 64 bit:
>     https://dl.espressif.com/dl/xtensa-esp32-elf-win32-1.22.0-97-gc752ad5-5.2.0.zip
> See
> https://github.com/espressif/esp-idf/commit/81da2bae2aa3e15a1793d40bb9648620f8cd2555
> for other architectures.
> Simply replace your existing toolchain installation by unpacking the
> archive. Test your toolchain installation by checking
> xtensa-esp32-elf-gcc --version.
> To update your esp-idf clone:
>   * cd $IDF_PATH
>   * git pull
>   * git submodule update --recursive
> Replace your sdkconfig by the default one or set all new config
> options to their defaults. I recommend doing a full rebuild of the
> OVMS firmware (i.e. make clean ; make). You should then get firmware
> version 3.2.015-150-gf6121ddd/factory/edge (build idf
> v3.3.4-845-gd59ed8bba Nov  8 2020 11:50:31) or higher.
> Am 31.07.20 um 22:10 schrieb Michael Balzer:
>> But according to the latest comment to the PSRAM issue
>> (https://github.com/espressif/esp-idf/issues/2892#issuecomment-667099130)
>> the fix in the official release had a regression. In some cases, the bug
>> will occur again. The report issue #5423 had the effect of this freezing
>> the LwIP task, which would create the WDT / event issue for us as well.
>> I'd rather apply the coming toolchain fix release first.
>> I'll keep you informed about the toolchain progress.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201109/72640c26/attachment-0002.htm>
