[Ovmsdev] VW e-Up project
Wed Mar 18 15:25:49 HKT 2020
Super! Thank you very much.
This feels realy good :-)
As we have rapid changes of the code and the documentation, can you
tell me how often it is best practice to create new pull requests?
Oh, and is it possible to link the VW e-Up documentation in the
introduction page:
https://docs.openvehicles.com/en/latest/introduction.html
Thanx again
Greetinx
Chris
Am Mittwoch, den 18.03.2020, 13:44 +0800 schrieb Mark Webb-Johnson:
> It looks workable to me. I have merged in the firmware pull request,
> and will leave the Android one up to Michael.
> Congratulations! Looking forward to seeing how this develops over
> time.
> Documentation has appeared online now:
> https://docs.openvehicles.com/en/latest/components/vehicle_vweup/docs
> /index.html
> I think this should still be treated as experimental for the moment,
> until we have had time to get some experience with it.
> > On 18 Mar 2020, at 5:22 AM, Chris van der Meijden <chris at arachnon.d
> > e> wrote:
> >   Dear all,
> > after some ups and downs I think we now have now enough
> > functionality to officialy ask for commit to my pull request for
> > integration of the VW e-Up to the OVMS master :-)
> > An overview of the supported and tested (yes, with a real VW e-Up
> > :-)) features you can find here
> > https://github.com/devmarxx/Open-Vehicle-Monitoring-System-3/blob/m
> > aster/vehicle/OVMS.V3/components/vehicle_vweup/docs/index.rst
> > I also added the car to the Android app. The app is working
> > flawless with the car, so I believe that my pull request for the
> > app also can be committed.
> > We will of course continue the development of our module. One major
> > working area is still the remote climate control. This is more
> > complicated than I hoped. We are now connected to the car directly
> > through the comfort CAN bus to get easy access to some simple ID's.
> > But we probably need to think about connecting to OBD for polling
> > ID's for climate control and more battery information. This should
> > preferably be done over bluetooth to avoid laying new wires in the
> > car.
> > So therefor I would also like to ask for a brief status on
> > bluetooth in OVMS. Bluetooth does not compile for me, but I just
> > tried it once without getting into it deeper. At the moment I'm
> > more focussed on "the great moment" of getting my pull request for
> > the OMS master committed :-)
> > Looking forward to the next steps.
> > Regards
> > Chris
> > Am Sonntag, den 01.03.2020, 08:26 +0100 schrieb Chris van der
> > Meijden:
> > > Hi Michael,
> > > thanx a lot for your nice and helpfull comments. I made some
> > > corrections.
> > > Please feel free to take an other look at the code on future
> > > occasions. I really appreciate the remarks :-)
> > > Greetinx
> > > Chris
> > > Am Samstag, den 29.02.2020, 17:05 +0100 schrieb Michael Balzer:
> > > >     Chris,
> > > >     some first comments:
> > > >       Please don't use TAB indentation, only spaces, or add a
> > > >         ".editorconfig". Tabs have different width depending on
> > > > the
> > > >         editor & environment. Default indentation step for most
> > > > of
> > > >         the code is two (2) spaces, except for some submodules
> > > > (which
> > > >         have .editorconfig files as necessary, for example the
> > > > zip
> > > >         module). See https://editorconfig.org/
> > > >       ms_v_bat_12v_voltage is by default provided by the
> > > >         housekeeping from the OVMS ADC (supply voltage), there
> > > > is
> > > >         currently no defined way to override this (maybe we
> > > > should
> > > >         introduce one?). If you set the metric, you will let
> > > > the CAN
> > > >         data fight against the ADC measurement (see
> > > > housekeeping.cpp).
> > > >         The advantage of the ADC measurement is it works all
> > > > the time,
> > > >         not only while the CAN bus is online.
> > > >       Checking ms_v_env_awake staleness to detect the switch-
> > > > off
> > > >         will have a delay of 120 seconds, but I assume that's
> > > > just a
> > > >         temporary solution. I bet there is some way to read the
> > > > state
> > > >         from CAN.
> > > >     Overall, nice & clean & good remarks.
> > > >     Btw, a typical CAN value scaling would be 100/256.
> > > >     Regards,
> > > >     Michael
> > > >     Am 26.02.20 um 09:07 schrieb Chris van
> > > >       der Meijden:
> > > > >       I do have some "first code" now.
> > > > >       We found some CAN-ID's for the e-Up, so we could start
> > > > > the
> > > > >         work on some real functionality.
> > > > >       At this stage we have:
> > > > >       - SoC (hopefully)
> > > > >       - VIN
> > > > >       - Speed
> > > > >       - 12 volt battery current
> > > > >       This should be enough to bring first action within the
> > > > > app,
> > > > >         i.e. battery bar and parking notice.
> > > > >       I would like to invite you to take a look at the code
> > > > > here:
> > > > > tem-
> > > > > 3/blob/master/vehicle/OVMS.V3/components/vehicle/vehicle.cpp
> > > > >       and give me some feedback. I wrote the code "blind" and
> > > > >         everything is untested because I don't have an OVMS
> > > > > v3 yet (it
> > > > >         is on its way) and our e-Up has also not arrived yet
> > > > > (hoping for
> > > > >         week 18 ...). So any hint on how to do better is
> > > > > welcome.
> > > > >       Thanx in advance.
> > > > >       Regards
> > > > >       Chris
> > > > >       Am Mittwoch, den 05.02.2020, 12:47 +0100 schrieb Chris
> > > > > van
> > > > >         der Meijden:
> > > > > >         It will take it's time though ...
> > > > > >         At the moment I'm waiting for our e-Up to be
> > > > > > delivered.
> > > > > >           Hopefully in April and that is where the real fun
> > > > > > starts.
> > > > > >         I forgot to mention my website with my experiences
> > > > > > with
> > > > > >           OVMS for the Leaf and load of other stuff around
> > > > > > e-mobility:
> > > > > >         http://www.arachnon.de/wb/pages/en/nissan-leaf/ovms
> > > > > > .php
> > > > > >         Just to complete my introduction :-)
> > > > > >         Chris
> > > > > >         Am Mittwoch, den 05.02.2020, 12:20 +0100 schrieb
> > > > > > Michael
> > > > > >           Balzer:
> > > > > > >           A quick addition:
> > > > > > >             Chris' work will be covering at least three
> > > > > > > new vehicles.
> > > > > > >             The same vehicle drive train & electronics is
> > > > > > > used on…
> > > > > > >               VW e-Up
> > > > > > >               SEAT Mii electric
> > > > > > >               ŠKODA CITIGOe iV
> > > > > > >             …also called "the new trio". These are very
> > > > > > > attractive
> > > > > > >             vehicles with a good balancing of price and
> > > > > > > capabilities,
> > > > > > >             and very good efficiency.
> > > > > > >             It's quite possible the code can also
> > > > > > > partially be used on
> > > > > > >             other VW vehicles (e-Golf, ID.3?), as VW
> > > > > > > tends to reuse
> > > > > > >             components & protocols.
> > > > > > >             Regards,
> > > > > > >             Michael
> > > > > > >             Am 05.02.20 um 10:44 schrieb Chris van der
> > > > > > > Meijden:
> > > > > > > >             Dear OVMS-devs,
> > > > > > > >             my name is Chris van der
> > > > > > > >               Meijden (devmarxx) and I just started a
> > > > > > > > new project on
> > > > > > > >               integrating the VW e-Up into OVMS.
> > > > > > > >             I mailed with Michael and
> > > > > > > >               he provided me with usefull procedure
> > > > > > > > hints. I forked OVMS
> > > > > > > >               V3 and the Android code into my github
> > > > > > > > account https://github.com/devmarxx?tab=repositories an
> > > > > > > > d
> > > > > > > >               commited my changes to the code there. I
> > > > > > > > also started a
> > > > > > > >               pull request, but there is no hurry,
> > > > > > > > because my vehicle
> > > > > > > >               code is just a template at the moment
> > > > > > > > (like the Fiat 500 e
> > > > > > > >               code). The Android code is complete, but
> > > > > > > > Michael is quite
> > > > > > > >               right that it would confuse the users to
> > > > > > > > suddenly see the
> > > > > > > >               VW e-Up when there is still no
> > > > > > > > functionality, so no hurry
> > > > > > > >               there too.
> > > > > > > >             My experience on OVMS so
> > > > > > > >               far is, that have been playing with the
> > > > > > > > code for about 4
> > > > > > > >               years. It started all because at that
> > > > > > > > time I could not use
> > > > > > > >               the Android app on my Cyanogenmod phone
> > > > > > > > due to the "google
> > > > > > > >               services" popup. I checked out the source
> > > > > > > > code, removed
> > > > > > > >               the google check line and voila I could
> > > > > > > > use the app with
> > > > > > > >               my Twizy and with my server :-)
> > > > > > > >             Later we bought a Nissan
> > > > > > > >               Leaf and I came in contact with Tom
> > > > > > > > Parker. I had already
> > > > > > > >               set up the OVMS V2 toolchain, so it was
> > > > > > > > very nice that I
> > > > > > > >               could use Tom's code to get the climate
> > > > > > > > control of the
> > > > > > > >               Leaf to work. Always nice mail contact
> > > > > > > > with Tom. Amazing
> > > > > > > >               the we can work together in New Zealand
> > > > > > > > and Germany
> > > > > > > >               without ever have met. That where good
> > > > > > > > times :-)
> > > > > > > >             So now we bought a VW
> > > > > > > >               e-Up, that will be delivered hopefully in
> > > > > > > > April. So I
> > > > > > > >               thought now is a good time to get started
> > > > > > > > with OVMS for
> > > > > > > >               the VW e-Up. I decided to connect to the
> > > > > > > > vehicle not over
> > > > > > > >               the OBD connector, but through the OCU
> > > > > > > > plug of the VW
> > > > > > > >               e-Up. By doing so I hope to bypass the
> > > > > > > > complicated VW CAN
> > > > > > > >               TP2.0 protocoll and I will have direct
> > > > > > > > access to the the
> > > > > > > >               VW comfort CAN. Time will tell if that is
> > > > > > > > the right
> > > > > > > >               decission.
> > > > > > > >             I started a thread at the
> > > > > > > >               german goingelectric forum. Here I'll
> > > > > > > > post my "adventures"
> > > > > > > >               (in German) and I hope to find some co-
> > > > > > > > coders there too https://www.goingelectric.de/forum/vie
> > > > > > > > wtopic.php?f=50&t=54620
> > > > > > > >             Well .. So far my little
> > > > > > > >               introduction.
> > > > > > > >             Looking forward to do some
> > > > > > > >               happy coding together.
> > > > > > > >             Greetinx
> > > > > > > >             Chris
> > > > > > > >             ___________________________________________
> > > > > > > > ____
> > > > > > > > OvmsDev mailing list
> > > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > >           _______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200318/45dcc3db/attachment.htm>
