[Ovmsdev] Bluetooth struggle
Chris van der Meijden
chris at arachnon.de
Fri Mar 27 03:46:05 HKT 2020
Dear all
I'm struggling with the activation of the bluetooth functionality with
the recent code.
The sdkconfig.bluetooth.hw31 will not compile at all.
I found three major problems here.
1. Mongoose SSL is needed
2. Support for the 8MB RAM version is needed (not included in
sdkconfig.bluetooth.hw31!)
3. CONFIG_BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF is needed for our
special esp-idf situation
By doing a simple diff I could solve 1, but overlooked Nr. 2. And that
was lethal. It brought my OVMS in a boot loop after I installed the
fresh compiled ovms3.bin. But I got here great help from Thomas
(Thanx!), who pointed to the problem and helped me out on the sdkconfig
settings.
For Nr. 3 I made a dirty workaround by adding
config BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF
int "Should be 0, can also be 1"
default 0
depends on OVMS
help
Workaround to make bluetooth compile with our special
esp-idf situation.
to the KConfig.
But all efforts didn't bring a postive result. The image compiles and
boots now, but we can't activate bluetooth. We get the Error
bt: init controller failed: ESP_ERR_NO_MEM
So I would like to ask, if anybody has a working, recent, bluetooth
image and if so what does it need? Any help on this is highly welcome.
Here the diff of my bluetooth sdkconfig to the standard sdkconfig
without bluetooth:
137,146c137,138
< CONFIG_BT_ENABLED=y
< # Bluetooth controller
< CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY=y
< CONFIG_BTDM_CONTROLLER_MODE_BR_EDR_ONLY=
< CONFIG_BTDM_CONTROLLER_MODE_BTDM=
< CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN=3
< CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=3
> CONFIG_BT_ENABLED=
> CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=0
149,150d140
< CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_0=y
< CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_1=
152,365c142
< CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
< CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4=
< # MODEM SLEEP Options
< CONFIG_BTDM_CONTROLLER_MODEM_SLEEP=
< CONFIG_BLE_SCAN_DUPLICATE=y
< CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y
< CONFIG_SCAN_DUPLICATE_BY_ADV_DATA=
< CONFIG_SCAN_DUPLICATE_BY_ADV_DATA_AND_DEVICE_ADDR=
< CONFIG_SCAN_DUPLICATE_TYPE=0
< CONFIG_DUPLICATE_SCAN_CACHE_SIZE=20
< CONFIG_BLE_MESH_SCAN_DUPLICATE_EN=
< CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED=
< CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y
< CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100
< CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
< CONFIG_BLUEDROID_ENABLED=y
< CONFIG_BLUEDROID_PINNED_TO_CORE_0=y
< CONFIG_BLUEDROID_PINNED_TO_CORE_1=
< CONFIG_BLUEDROID_PINNED_TO_CORE=0
< CONFIG_BTC_TASK_STACK_SIZE=6144
< CONFIG_BTU_TASK_STACK_SIZE=4096
< CONFIG_BLUEDROID_MEM_DEBUG=
< CONFIG_CLASSIC_BT_ENABLED=
< CONFIG_GATTS_ENABLE=y
< CONFIG_GATTS_SEND_SERVICE_CHANGE_MANUAL=
< CONFIG_GATTS_SEND_SERVICE_CHANGE_AUTO=y
< CONFIG_GATTS_SEND_SERVICE_CHANGE_MODE=0
< CONFIG_GATTC_ENABLE=
< CONFIG_BLE_SMP_ENABLE=y
< CONFIG_SMP_SLAVE_CON_PARAMS_UPD_ENABLE=
< CONFIG_BT_STACK_NO_LOG=
< # BT DEBUG LOG LEVEL
< CONFIG_HCI_TRACE_LEVEL_NONE=
< CONFIG_HCI_TRACE_LEVEL_ERROR=
< CONFIG_HCI_TRACE_LEVEL_WARNING=y
< CONFIG_HCI_TRACE_LEVEL_API=
< CONFIG_HCI_TRACE_LEVEL_EVENT=
< CONFIG_HCI_TRACE_LEVEL_DEBUG=
< CONFIG_HCI_TRACE_LEVEL_VERBOSE=
< CONFIG_HCI_INITIAL_TRACE_LEVEL=2
< CONFIG_BTM_TRACE_LEVEL_NONE=
< CONFIG_BTM_TRACE_LEVEL_ERROR=
< CONFIG_BTM_TRACE_LEVEL_WARNING=y
< CONFIG_BTM_TRACE_LEVEL_API=
< CONFIG_BTM_TRACE_LEVEL_EVENT=
< CONFIG_BTM_TRACE_LEVEL_DEBUG=
< CONFIG_BTM_TRACE_LEVEL_VERBOSE=
< CONFIG_BTM_INITIAL_TRACE_LEVEL=2
< CONFIG_L2CAP_TRACE_LEVEL_NONE=
< CONFIG_L2CAP_TRACE_LEVEL_ERROR=
< CONFIG_L2CAP_TRACE_LEVEL_WARNING=y
< CONFIG_L2CAP_TRACE_LEVEL_API=
< CONFIG_L2CAP_TRACE_LEVEL_EVENT=
< CONFIG_L2CAP_TRACE_LEVEL_DEBUG=
< CONFIG_L2CAP_TRACE_LEVEL_VERBOSE=
< CONFIG_L2CAP_INITIAL_TRACE_LEVEL=2
< CONFIG_RFCOMM_TRACE_LEVEL_NONE=
< CONFIG_RFCOMM_TRACE_LEVEL_ERROR=
< CONFIG_RFCOMM_TRACE_LEVEL_WARNING=y
< CONFIG_RFCOMM_TRACE_LEVEL_API=
< CONFIG_RFCOMM_TRACE_LEVEL_EVENT=
< CONFIG_RFCOMM_TRACE_LEVEL_DEBUG=
< CONFIG_RFCOMM_TRACE_LEVEL_VERBOSE=
< CONFIG_RFCOMM_INITIAL_TRACE_LEVEL=2
< CONFIG_SDP_TRACE_LEVEL_NONE=
< CONFIG_SDP_TRACE_LEVEL_ERROR=
< CONFIG_SDP_TRACE_LEVEL_WARNING=y
< CONFIG_SDP_TRACE_LEVEL_API=
< CONFIG_SDP_TRACE_LEVEL_EVENT=
< CONFIG_SDP_TRACE_LEVEL_DEBUG=
< CONFIG_SDP_TRACE_LEVEL_VERBOSE=
< CONFIG_SDP_INITIAL_TRACE_LEVEL=2
< CONFIG_GAP_TRACE_LEVEL_NONE=
< CONFIG_GAP_TRACE_LEVEL_ERROR=
< CONFIG_GAP_TRACE_LEVEL_WARNING=y
< CONFIG_GAP_TRACE_LEVEL_API=
< CONFIG_GAP_TRACE_LEVEL_EVENT=
< CONFIG_GAP_TRACE_LEVEL_DEBUG=
< CONFIG_GAP_TRACE_LEVEL_VERBOSE=
< CONFIG_GAP_INITIAL_TRACE_LEVEL=2
< CONFIG_BNEP_TRACE_LEVEL_NONE=
< CONFIG_BNEP_TRACE_LEVEL_ERROR=
< CONFIG_BNEP_TRACE_LEVEL_WARNING=y
< CONFIG_BNEP_TRACE_LEVEL_API=
< CONFIG_BNEP_TRACE_LEVEL_EVENT=
< CONFIG_BNEP_TRACE_LEVEL_DEBUG=
< CONFIG_BNEP_TRACE_LEVEL_VERBOSE=
< CONFIG_BNEP_INITIAL_TRACE_LEVEL=2
< CONFIG_PAN_TRACE_LEVEL_NONE=
< CONFIG_PAN_TRACE_LEVEL_ERROR=
< CONFIG_PAN_TRACE_LEVEL_WARNING=y
< CONFIG_PAN_TRACE_LEVEL_API=
< CONFIG_PAN_TRACE_LEVEL_EVENT=
< CONFIG_PAN_TRACE_LEVEL_DEBUG=
< CONFIG_PAN_TRACE_LEVEL_VERBOSE=
< CONFIG_PAN_INITIAL_TRACE_LEVEL=2
< CONFIG_A2D_TRACE_LEVEL_NONE=
< CONFIG_A2D_TRACE_LEVEL_ERROR=
< CONFIG_A2D_TRACE_LEVEL_WARNING=y
< CONFIG_A2D_TRACE_LEVEL_API=
< CONFIG_A2D_TRACE_LEVEL_EVENT=
< CONFIG_A2D_TRACE_LEVEL_DEBUG=
< CONFIG_A2D_TRACE_LEVEL_VERBOSE=
< CONFIG_A2D_INITIAL_TRACE_LEVEL=2
< CONFIG_AVDT_TRACE_LEVEL_NONE=
< CONFIG_AVDT_TRACE_LEVEL_ERROR=
< CONFIG_AVDT_TRACE_LEVEL_WARNING=y
< CONFIG_AVDT_TRACE_LEVEL_API=
< CONFIG_AVDT_TRACE_LEVEL_EVENT=
< CONFIG_AVDT_TRACE_LEVEL_DEBUG=
< CONFIG_AVDT_TRACE_LEVEL_VERBOSE=
< CONFIG_AVDT_INITIAL_TRACE_LEVEL=2
< CONFIG_AVCT_TRACE_LEVEL_NONE=
< CONFIG_AVCT_TRACE_LEVEL_ERROR=
< CONFIG_AVCT_TRACE_LEVEL_WARNING=y
< CONFIG_AVCT_TRACE_LEVEL_API=
< CONFIG_AVCT_TRACE_LEVEL_EVENT=
< CONFIG_AVCT_TRACE_LEVEL_DEBUG=
< CONFIG_AVCT_TRACE_LEVEL_VERBOSE=
< CONFIG_AVCT_INITIAL_TRACE_LEVEL=2
< CONFIG_AVRC_TRACE_LEVEL_NONE=
< CONFIG_AVRC_TRACE_LEVEL_ERROR=
< CONFIG_AVRC_TRACE_LEVEL_WARNING=y
< CONFIG_AVRC_TRACE_LEVEL_API=
< CONFIG_AVRC_TRACE_LEVEL_EVENT=
< CONFIG_AVRC_TRACE_LEVEL_DEBUG=
< CONFIG_AVRC_TRACE_LEVEL_VERBOSE=
< CONFIG_AVRC_INITIAL_TRACE_LEVEL=2
< CONFIG_MCA_TRACE_LEVEL_NONE=
< CONFIG_MCA_TRACE_LEVEL_ERROR=
< CONFIG_MCA_TRACE_LEVEL_WARNING=y
< CONFIG_MCA_TRACE_LEVEL_API=
< CONFIG_MCA_TRACE_LEVEL_EVENT=
< CONFIG_MCA_TRACE_LEVEL_DEBUG=
< CONFIG_MCA_TRACE_LEVEL_VERBOSE=
< CONFIG_MCA_INITIAL_TRACE_LEVEL=2
< CONFIG_HID_TRACE_LEVEL_NONE=
< CONFIG_HID_TRACE_LEVEL_ERROR=
< CONFIG_HID_TRACE_LEVEL_WARNING=y
< CONFIG_HID_TRACE_LEVEL_API=
< CONFIG_HID_TRACE_LEVEL_EVENT=
< CONFIG_HID_TRACE_LEVEL_DEBUG=
< CONFIG_HID_TRACE_LEVEL_VERBOSE=
< CONFIG_HID_INITIAL_TRACE_LEVEL=2
< CONFIG_APPL_TRACE_LEVEL_NONE=
< CONFIG_APPL_TRACE_LEVEL_ERROR=
< CONFIG_APPL_TRACE_LEVEL_WARNING=y
< CONFIG_APPL_TRACE_LEVEL_API=
< CONFIG_APPL_TRACE_LEVEL_EVENT=
< CONFIG_APPL_TRACE_LEVEL_DEBUG=
< CONFIG_APPL_TRACE_LEVEL_VERBOSE=
< CONFIG_APPL_INITIAL_TRACE_LEVEL=2
< CONFIG_GATT_TRACE_LEVEL_NONE=
< CONFIG_GATT_TRACE_LEVEL_ERROR=
< CONFIG_GATT_TRACE_LEVEL_WARNING=y
< CONFIG_GATT_TRACE_LEVEL_API=
< CONFIG_GATT_TRACE_LEVEL_EVENT=
< CONFIG_GATT_TRACE_LEVEL_DEBUG=
< CONFIG_GATT_TRACE_LEVEL_VERBOSE=
< CONFIG_GATT_INITIAL_TRACE_LEVEL=2
< CONFIG_SMP_TRACE_LEVEL_NONE=
< CONFIG_SMP_TRACE_LEVEL_ERROR=
< CONFIG_SMP_TRACE_LEVEL_WARNING=y
< CONFIG_SMP_TRACE_LEVEL_API=
< CONFIG_SMP_TRACE_LEVEL_EVENT=
< CONFIG_SMP_TRACE_LEVEL_DEBUG=
< CONFIG_SMP_TRACE_LEVEL_VERBOSE=
< CONFIG_SMP_INITIAL_TRACE_LEVEL=2
< CONFIG_BTIF_TRACE_LEVEL_NONE=
< CONFIG_BTIF_TRACE_LEVEL_ERROR=
< CONFIG_BTIF_TRACE_LEVEL_WARNING=y
< CONFIG_BTIF_TRACE_LEVEL_API=
< CONFIG_BTIF_TRACE_LEVEL_EVENT=
< CONFIG_BTIF_TRACE_LEVEL_DEBUG=
< CONFIG_BTIF_TRACE_LEVEL_VERBOSE=
< CONFIG_BTIF_INITIAL_TRACE_LEVEL=2
< CONFIG_BTC_TRACE_LEVEL_NONE=
< CONFIG_BTC_TRACE_LEVEL_ERROR=
< CONFIG_BTC_TRACE_LEVEL_WARNING=y
< CONFIG_BTC_TRACE_LEVEL_API=
< CONFIG_BTC_TRACE_LEVEL_EVENT=
< CONFIG_BTC_TRACE_LEVEL_DEBUG=
< CONFIG_BTC_TRACE_LEVEL_VERBOSE=
< CONFIG_BTC_INITIAL_TRACE_LEVEL=2
< CONFIG_OSI_TRACE_LEVEL_NONE=
< CONFIG_OSI_TRACE_LEVEL_ERROR=
< CONFIG_OSI_TRACE_LEVEL_WARNING=y
< CONFIG_OSI_TRACE_LEVEL_API=
< CONFIG_OSI_TRACE_LEVEL_EVENT=
< CONFIG_OSI_TRACE_LEVEL_DEBUG=
< CONFIG_OSI_TRACE_LEVEL_VERBOSE=
< CONFIG_OSI_INITIAL_TRACE_LEVEL=2
< CONFIG_BLUFI_TRACE_LEVEL_NONE=
< CONFIG_BLUFI_TRACE_LEVEL_ERROR=
< CONFIG_BLUFI_TRACE_LEVEL_WARNING=y
< CONFIG_BLUFI_TRACE_LEVEL_API=
< CONFIG_BLUFI_TRACE_LEVEL_EVENT=
< CONFIG_BLUFI_TRACE_LEVEL_DEBUG=
< CONFIG_BLUFI_TRACE_LEVEL_VERBOSE=
< CONFIG_BLUFI_INITIAL_TRACE_LEVEL=2
< CONFIG_BT_ACL_CONNECTIONS=2
< CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=y
< CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY=y
< CONFIG_BLE_HOST_QUEUE_CONGESTION_CHECK=
< CONFIG_SMP_ENABLE=y
< CONFIG_BLE_ACTIVE_SCAN_REPORT_ADV_SCAN_RSP_INDIVIDUALLY=
< CONFIG_BLE_ESTABLISH_LINK_CONNECTION_TIMEOUT=30
< CONFIG_BT_RESERVE_DRAM=0xdb5c
506a284
> CONFIG_NO_BLOBS=
514d291
< CONFIG_SW_COEXIST_ENABLE=
642c419
< CONFIG_FATFS_ALLOC_PREFER_EXTRAM=y
673c450
< CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
683c460
< CONFIG_TIMER_TASK_PRIORITY=1
> CONFIG_TIMER_TASK_PRIORITY=20
688,689c465,469
< CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=
< CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=
> CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=y
> CONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID=
> CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y
> CONFIG_FREERTOS_RUN_TIME_STATS_USING_ESP_TIMER=y
> CONFIG_FREERTOS_RUN_TIME_STATS_USING_CPU_CLK=
775c555
< CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
777,778c557,558
< CONFIG_TCPIP_TASK_AFFINITY_CPU1=
< CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
> CONFIG_TCPIP_TASK_AFFINITY_CPU1=y
> CONFIG_TCPIP_TASK_AFFINITY=0x1
810c590
< CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=30
> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
859,860c639,640
< CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144
< CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=40
> CONFIG_OVMS_VEHICLE_RXTASK_STACK=8192
> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
865d644
< CONFIG_OVMS_COMP_BLUETOOTH=y
900d678
< CONFIG_BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF=0
905,906c683,684
< CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
< CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC=
> CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC=y
909c687
< CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096
> CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
929c707
< CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=
> CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=y
1104a883
Thanx in advance for your help.
Regards
Chris
