[Ovmsdev] VW e-Up project
Chris van der Meijden
chris at arachnon.de
Wed Mar 18 05:22:55 HKT 2020
Dear all,
after some ups and downs I think we now have now enough functionality
to officialy ask for commit to my pull request for integration of the
VW e-Up to the OVMS master :-)
An overview of the supported and tested (yes, with a real VW e-Up :-))
features you can find here
https://github.com/devmarxx/Open-Vehicle-Monitoring-System-3/blob/maste
r/vehicle/OVMS.V3/components/vehicle_vweup/docs/index.rst
I also added the car to the Android app. The app is working flawless
with the car, so I believe that my pull request for the app also can be
committed.
We will of course continue the development of our module. One major
working area is still the remote climate control. This is more
complicated than I hoped. We are now connected to the car directly
through the comfort CAN bus to get easy access to some simple ID's. But
we probably need to think about connecting to OBD for polling ID's for
climate control and more battery information. This should preferably be
done over bluetooth to avoid laying new wires in the car.
So therefor I would also like to ask for a brief status on bluetooth in
OVMS. Bluetooth does not compile for me, but I just tried it once
without getting into it deeper. At the moment I'm more focussed on "the
great moment" of getting my pull request for the OMS master committed
Looking forward to the next steps.
Regards
Chris
Am Sonntag, den 01.03.2020, 08:26 +0100 schrieb Chris van der Meijden:
> Hi Michael,
> thanx a lot for your nice and helpfull comments. I made some
> corrections.
> Please feel free to take an other look at the code on future
> occasions. I really appreciate the remarks :-)
> Greetinx
> Chris
> Am Samstag, den 29.02.2020, 17:05 +0100 schrieb Michael Balzer:
> > Chris,
> > some first comments:
> > Please don't use TAB indentation, only spaces, or add a
> > ".editorconfig". Tabs have different width depending on the
> > editor & environment. Default indentation step for most of
> > the code is two (2) spaces, except for some submodules
> > (which
> > have .editorconfig files as necessary, for example the zip
> > module). See https://editorconfig.org/
> > ms_v_bat_12v_voltage is by default provided by the
> > housekeeping from the OVMS ADC (supply voltage), there is
> > currently no defined way to override this (maybe we should
> > introduce one?). If you set the metric, you will let the
> > CAN
> > data fight against the ADC measurement (see
> > housekeeping.cpp).
> > The advantage of the ADC measurement is it works all the
> > time,
> > not only while the CAN bus is online.
> > Checking ms_v_env_awake staleness to detect the switch-off
> > will have a delay of 120 seconds, but I assume that's just
> > a
> > temporary solution. I bet there is some way to read the
> > state
> > from CAN.
> > Overall, nice & clean & good remarks.
> > Btw, a typical CAN value scaling would be 100/256.
> > Regards,
> > Michael
> > Am 26.02.20 um 09:07 schrieb Chris van
> > der Meijden:
> > > I do have some "first code" now.
> > > We found some CAN-ID's for the e-Up, so we could start the
> > > work on some real functionality.
> > > At this stage we have:
> > > - SoC (hopefully)
> > > - VIN
> > > - Speed
> > > - 12 volt battery current
> > > This should be enough to bring first action within the app,
> > > i.e. battery bar and parking notice.
> > > I would like to invite you to take a look at the code here:
> > > 3/blob/master/vehicle/OVMS.V3/components/vehicle/vehicle.cpp
> > > and give me some feedback. I wrote the code "blind" and
> > > everything is untested because I don't have an OVMS v3
> > > yet (it
> > > is on its way) and our e-Up has also not arrived yet
> > > (hoping for
> > > week 18 ...). So any hint on how to do better is welcome.
> > > Thanx in advance.
> > > Regards
> > > Chris
> > > Am Mittwoch, den 05.02.2020, 12:47 +0100 schrieb Chris van
> > > der Meijden:
> > > > It will take it's time though ...
> > > > At the moment I'm waiting for our e-Up to be delivered.
> > > > Hopefully in April and that is where the real fun
> > > > starts.
> > > > I forgot to mention my website with my experiences with
> > > > OVMS for the Leaf and load of other stuff around e-
> > > > mobility:
> > > > http://www.arachnon.de/wb/pages/en/nissan-leaf/ovms.php
> > > > Just to complete my introduction :-)
> > > > Chris
> > > > Am Mittwoch, den 05.02.2020, 12:20 +0100 schrieb
> > > > Michael
> > > > Balzer:
> > > > > A quick addition:
> > > > > Chris' work will be covering at least three new
> > > > > vehicles.
> > > > > The same vehicle drive train & electronics is
> > > > > used on…
> > > > > VW e-Up
> > > > > SEAT Mii electric
> > > > > ŠKODA CITIGOe iV
> > > > > …also called "the new trio". These are very
> > > > > attractive
> > > > > vehicles with a good balancing of price and
> > > > > capabilities,
> > > > > and very good efficiency.
> > > > > It's quite possible the code can also partially
> > > > > be used on
> > > > > other VW vehicles (e-Golf, ID.3?), as VW tends to
> > > > > reuse
> > > > > components & protocols.
> > > > > Regards,
> > > > > Michael
> > > > > Am 05.02.20 um 10:44 schrieb Chris van der
> > > > > Meijden:
> > > > > > Dear OVMS-devs,
> > > > > > my name is Chris van der
> > > > > > Meijden (devmarxx) and I just started a new
> > > > > > project on
> > > > > > integrating the VW e-Up into OVMS.
> > > > > > I mailed with Michael and
> > > > > > he provided me with usefull procedure hints.
> > > > > > I forked OVMS
> > > > > > V3 and the Android code into my github
> > > > > > account https://github.com/devmarxx?tab=repositories and
> > > > > > commited my changes to the code there. I also
> > > > > > started a
> > > > > > pull request, but there is no hurry, because
> > > > > > my vehicle
> > > > > > code is just a template at the moment (like
> > > > > > the Fiat 500 e
> > > > > > code). The Android code is complete, but
> > > > > > Michael is quite
> > > > > > right that it would confuse the users to
> > > > > > suddenly see the
> > > > > > VW e-Up when there is still no functionality,
> > > > > > so no hurry
> > > > > > there too.
> > > > > > My experience on OVMS so
> > > > > > far is, that have been playing with the code
> > > > > > for about 4
> > > > > > years. It started all because at that time I
> > > > > > could not use
> > > > > > the Android app on my Cyanogenmod phone due
> > > > > > to the "google
> > > > > > services" popup. I checked out the source
> > > > > > code, removed
> > > > > > the google check line and voila I could use
> > > > > > the app with
> > > > > > my Twizy and with my server :-)
> > > > > > Later we bought a Nissan
> > > > > > Leaf and I came in contact with Tom Parker. I
> > > > > > had already
> > > > > > set up the OVMS V2 toolchain, so it was very
> > > > > > nice that I
> > > > > > could use Tom's code to get the climate
> > > > > > control of the
> > > > > > Leaf to work. Always nice mail contact with
> > > > > > Tom. Amazing
> > > > > > the we can work together in New Zealand and
> > > > > > Germany
> > > > > > without ever have met. That where good times
> > > > > > So now we bought a VW
> > > > > > e-Up, that will be delivered hopefully in
> > > > > > April. So I
> > > > > > thought now is a good time to get started
> > > > > > with OVMS for
> > > > > > the VW e-Up. I decided to connect to the
> > > > > > vehicle not over
> > > > > > the OBD connector, but through the OCU plug
> > > > > > of the VW
> > > > > > e-Up. By doing so I hope to bypass the
> > > > > > complicated VW CAN
> > > > > > TP2.0 protocoll and I will have direct access
> > > > > > to the the
> > > > > > VW comfort CAN. Time will tell if that is the
> > > > > > right
> > > > > > decission.
> > > > > > I started a thread at the
> > > > > > german goingelectric forum. Here I'll post my
> > > > > > "adventures"
> > > > > > (in German) and I hope to find some co-coders
> > > > > > there too https://www.goingelectric.de/forum/viewtopic.php?
> > > > > > f=50&t=54620
> > > > > > Well .. So far my little
> > > > > > introduction.
> > > > > > Looking forward to do some
> > > > > > happy coding together.
> > > > > > Greetinx
> > > > > > Chris
> > > > > > _______________________________________________
> > > > > > OvmsDev mailing list
> > > > > > OvmsDev at lists.openvehicles.com
> > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200317/4420d435/attachment-0001.html>
