[Ovmsdev] Nissan LEAF: HVAC Metrics
Jaunius K. jaunius at gmx.com
Wed Mar 4 03:06:01 HKT 2020
Hi Mark,
Thanks again for the tip, however it seems that the 0 is sent just
before the CC is turned off.
So to avoid that I guess I need to set a delay to update the metric each
n seconds to give enough time for the CC to go in to OFF state.
Is there any built in way of doing that, or do I have to add my own
function?
Currently that code part looks like this:
// setpoint gets reset on CC off, so we only update it while it can be
actually changed
if(StandardMetrics.ms_v_env_heating->AsBool()||StandardMetrics.ms_v_env_cooling->AsBool())
floatsetpoint_float =d[4]/2;
m_climate_setpoint->SetValue(setpoint_float);
Jaunius
On 2020-02-14 11:11, Mark Webb-Johnson wrote:
> The ’stale’ system simply sets a flag on the metric - it doesn’t
> modify the metric value at all.
> Auto-stale works by having a timer that is reset every time the metric
> is updated. If the timer expires then the metric is automatically
> marked as stale.
> So, to se a metric to zero value, you must have some code that
> explicitly does that. Maybe when the climate control is turned off it
> sends zero values for set point on the can bus? In the Tesla Roadster
> code, I have specific code to ignore temperature updates when aux12v
> (used to be ‘awake’) is off - as I know the updates are not real, and
> I want the metric to go stale.
> Regards, Mark
>> On 14 Feb 2020, at 7:33 AM, Jaunius Kapkan <jaunius at gmx.com
>> <mailto:jaunius at gmx.com>> wrote:
>> Hi,
>> Let me come back to this topic.
>> I have re-made the metrics somewhat accoding to your recomendations,
>> but I am having an issue with the setpoint value:
>> *OVMS#*  metrics list v.e.cab
>> v.e.cabin.fan                            6
>> v.e.cabin.fanlimit                       7
>> v.e.cabin.intake                         recirc
>> *v.e.cabin.setpoint 28°C *v.e.cabin.vent                           screen|feet
>> v.e.cabintemp                            0°C
>> v.e.cabin.fan                            0
>> v.e.cabin.intake                         unknown
>> *v.e.cabin.setpoint 0°C*
>> v.e.cabin.vent                           off
>> v.e.cabintemp                            0.5°C
>>  bascailly as soon as climate control is truned off this value goes
>> back to default. Should I use a different STALE parameter?
>> m_climate_setpoint = MyMetrics.InitFloat("v.e.cabin.setpoint",
>> SM_STALE_NONE, 0, Celcius);
>> Jaunius
>> *Sent:* Monday, November 11, 2019 at 7:51 AM
>> *From:* "Mark Webb-Johnson" <mark at webb-johnson.net
>> <mailto:mark at webb-johnson.net>>
>> *To:* "OVMS Developers" <ovmsdev at lists.openvehicles.com
>> <mailto:ovmsdev at lists.openvehicles.com>>
>> *Subject:* Re: [Ovmsdev] Nissan LEAF: HVAC Metrics
>> I will look into this, and let you know. The fan speeds, etc, can
>> normally be represented as a percentage of maximum (to make it easier
>> for Apps).
>> Can you explain what your car offers, and what the proposed settings are:
>>   * v.e.cabin.fan 0-100% (cabin fan speed)
>>   * v.e.cabin.setpoint 999C (cabin temperature set point)
>>   * v.e.cabin.intake fresh/recirc (cabin air intake mode)
>>   * v.e.cabin.vent feet | face | screen (or comma-separated list)
>> But not sure what remotecool and remoteheat are?
>> Does that match other car’s capabilities? Or suggestions for more?
>>     On 11 Nov 2019, at 5:15 AM, Jaunius Kapkan <jaunius at gmx.com
>>     Hi,
>>     While doing Leaf HVAC/Climate Control Metrics I tought it would
>>     make sense to put them under v.e. or a new climate category like
>>     v.h or v.cc <http://v.cc/> and agree on general metrics that
>>     would be used by all cars.
>>     Such as:
>>     v.e.fan.speed 6
>>     v.e.remotecool no
>>     v.e.remoteheat yes
>>     v.e.setpoint 21°C
>>     v.e.intake def/fresh/recirc
>>     v.e.vent def/def-feet/face/face-feet/feet
>>     Then later it would be much easier to make them visible in an app.
>>     Also "maxfanspeed" could be added to the config so that the GUI
>>     could take the required amount of bars for each car.
>>     Regards,
>>     Jaunius
>>     *Sent:* Monday, November 04, 2019 at 1:09 PM
>>     *From:* "Jaunius Kapkan" <jaunius at gmx.com <mailto:jaunius at gmx.com>>
>>     *Subject:* [Ovmsdev] Nissan LEAF: HVAC Metrics
>>     Hi,
>>     I have enhanced Nissan LEAF HVAC metrics as well as added
>>     additional ones under xnl.cc <http://xnl.cc/>
>>     I have built and tested the changes and so far all works as intended.
>>     I have also updated documentation.
>>     So I think it is time to merge this in to current edge build, but
>>     I just wanted to check with you if all the code style and naming
>>     conventios are according to standards.
>>     Would appreciate if someone could review and advise if something
>>     needs to be corrected.
>>     Here is the link to the repo and main file I worked on:
>>     https://github.com/mjkapkan/Open-Vehicle-Monitoring-System-3/commits/master/vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp
>>     Kindly,
>>     *Jaunius Kapkan */[Sent from cellphone]/
>>     Global Market Operations
>>     Cell: +370 650 11 752
>>         On 2019-10-17, at 15:14, Jaunius Kapkan <jaunius at gmx.com
>>         Thanks Mark,
>>         [renaming subject]
>>         In regards to config store. Where would you recommend placing
>>         the timers? I was thinking about putting them under vehicle conf:
>>         *OVMS#*  config list vehicle
>>         vehicle (readable writeable)
>>            bms.alerts.enabled: yes
>>            bms.dev.temp.alert:
>>            bms.dev.temp.warn:
>>            bms.dev.voltage.alert:
>>            bms.dev.voltage.warn:
>>            cctimer.evening: 1715-1730
>>            cctimer.morning: 0800-0815
>>            minsoc: 20
>>            name:
>>            timezone: EET-2EEST,M3.5.0/3,M10.5.0/4
>>            timezone_region: Europe/Helsinki
>>            units.distance: K
>>         Any other suggestions?
>>         Regards,
>>         Jaunius
>>         *Sent:* Monday, October 14, 2019 at 4:01 AM
>>         *Subject:* Re: [Ovmsdev] WifiConsole V1.0
>>         Probably not. The majority of power consumption is from the
>>         modems (cellular and wifi).
>>         Regards, Mark
>>         P.S. If all you need is a 10 second notification, you can
>>         pubsub subscribe to the standard event ticker.10.
>>             On 14 Oct 2019, at 7:22 AM, Jaunius Kapkan
>>             <jaunius at gmx.com <mailto:jaunius at gmx.com>> wrote:
>>             Delayed events seem to be working fine, thanks for the
>>             examples!
>>             However, do you think spamming the events API every 10
>>             seconds might substantially increase power consumption?
>>               * |[2:17:04 AM]|usr.CCtimer.heartbeat
>>               * |[2:17:04 AM]|usr.CCtimer.Night.stopped
>>               * |[2:17:14 AM]|usr.CCtimer.heartbeat
>>             Regards,
>>             Jaunius
>>             *Sent:* Sunday, October 13, 2019 at 8:54 PM
>>             *From:* "Michael Balzer" <dexter at expeedo.de
>>             <mailto:dexter at expeedo.de>>
>>             *To:* ovmsdev at lists.openvehicles.com
>>             Sending notifications is now also supported directly:
>>             https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsnotify
>>             Regards,
>>             Michael
>>             Am 13.10.19 um 16:09 schrieb Jaunius Kapkan:
>>             > Great,
>>             > Will try that out!
>>             > Regards,
>>             > Jaunius
>>             >> Sent: Sunday, October 13, 2019 at 11:20 AM
>>             >> From: "Michael Balzer" <dexter at expeedo.de
>>             >> To: ovmsdev at lists.openvehicles.com
>>             >> Subject: Re: [Ovmsdev] WifiConsole V1.0
>>             >> Jaunius,
>>             >> I've added scheduled (delayed) events & the native
>>             OvmsEvents API:
>>             https://docs.openvehicles.com/en/latest/userguide/scripting.html#internal-objects-and-functions-methods
>>             >> So you can now also implement millisecond resolution
>>             timeouts and intervals in scripts.
>>             >> Regards,
>>             >> Michael
>>             >> Am 11.10.19 um 10:36 schrieb Jaunius Kapkan:
>>             >>> Thanks Michael,
>>             >>> 1 second will do just fine as this is for climate
>>             control timer plugin I'm doing. Will try to use that
>>             event listener. Of course some standartized way would
>>             >>> be better.
>>             >>> Regards,
>>             >>> Jaunius
>>             >>> *Sent:* Friday, October 11, 2019 at 8:48 AM
>>             >>> Jaunius,
>>             >>> setTimeout() is not a standard Javascript function,
>>             it's a method of the browser window object.
>>             https://developer.mozilla.org/de/docs/Web/API/WindowTimers/setTimeout
>>             >>> As a workaround, subscribe to the "ticker.1" event as
>>             shown in the foglight example:
>>             http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html#listen-to-events
>>             >>> Resolution is limited to 1 second though. I thought
>>             about scheduled events some time ago, i.e. being able to
>>             tell the event system to trigger an event after a
>>             >>> specific delay. That would also offer a clean &
>>             simple solution for this. Another option would be a
>>             script API for the timer service.
>>             >>> I'll have a look at scheduled events.
>>             >>> Regards,
>>             >>> Michael
>>             >>> Am 11.10.19 um 08:29 schrieb Jaunius Kapkan:
>>             >>> Thanks Mark,
>>             >>> One other thing I stumbled upon is that
>>             standard setTimeout() does not seem to work. Is there any
>>             workaround for this? Sample Code:
>>             >>> |function intervalFunc() { print('Next try in 1.5s')
>>             } setInterval(intervalFunc, 1500)|
>>             >>> Basically I need the script to check certain
>>             conditions each n seconds.
>>             >>> Regards,
>>             >>> Jaunius
>>             >>> *Sent:* Thursday, October 10, 2019 at 3:35 AM
>>             >>> I think in v2 that could have been the case (as we
>>             didn’t have any standardised functions for things like
>>             climate control). But in the v3 architecture we
>>             >>> now have these and the vehicle modules should support
>>             the standard functions to the best of their abilities.
>>             >>> If we still need mappings like Homelink 1 -> Climate
>>             On, then that should be done either by scripts or by some
>>             centralised mapping framework.
>>             >>> Regards, Mark.
>>             >>> > On 9 Oct 2019, at 2:19 PM, Jaunius Kapkan
>>             >>> > I am making a couple of plugins (initially for
>>             leaf) and the JS functions are great for that. However I
>>             assume the functions are not unifed accross
>>             >>> different vehicles. For example for leaf to turn on
>>             pre-heat you need to issue Homelink 1 instead of
>>             ClimateControl. What would be the best way to change
>>             >>> this? Or is this something that need to be changed on
>>             the lower level?
>>             >>> > Greetings,
>>             >>> > Jaunius
>>             >>> >> Sent: Tuesday, October 08, 2019 at 9:05 AM
>>             >>> >> Mark,
>>             >>> >> yes, the OLEDs are perfect for these things,
>>             bright enough for daylight use with very little energy usage.
>>             >>> >> Thanks for the link to that combined ESP32 module,
>>             that's a real beauty, even includes a LiPo supply /
>>             charger. I need to check that one out.
>>             >>> >> Regarding our Javascript support, I already had
>>             stunned some users with the foglight plugin, they thought
>>             stuff like this would need builtin
>>             >>> >> support. That brought me back to my point about
>>             how little users know about our capabilities, so I added
>>             an explanation to our docs:
>>             >>> >> But we really need something like an OVMS cheat
>>             sheet as an overview of what is possible.
>>             >>> >> Regards,
>>             >>> >> Michael
>>             >>> >> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
>>             >>> >>> Michael,
>>             >>> >>> I really like those little OLED SSD1306 based
>>             displays. I use them on my esphome+hassio projects like
>>             this little water tank level (using an
>>             >>> >>> ESP32, a BME280 pressure/humidity/temperature
>>             sensor, waterproof ultrasonic distance sensor, and
>>             SSID1306 OLED yellow/blue display):
>>             >>> >>> Adding a display to a project makes it so much
>>             more useful and easy to diagnose problems.
>>             >>> >>> AliExpress has them very cheap:
>>             >>> >>> * https://www.aliexpress.com/item/32844104782.html
>>             >>> >>> US$2 for the 0.96” yellow/blue 128x32
>>             >>> >>> US$3 for the 1.3” white 128x64
>>             >>> >>> There is also a 4MB ESP32 with a 0.96” OLED
>>             display on-board:
>>             >>> >>> * https://www.aliexpress.com/item/32822105291.html
>>             >>> >>> US$9 plus shipping
>>             >>> >>> Glad that you are finding a use for our
>>             JavaScript support. I really think that has so many
>>             possibilities.
>>             >>> >>> Regards, Mark
>>             >>> >>>> On 6 Oct 2019, at 10:43 PM, Michael Balzer
>>             <dexter at expeedo.de <mailto:dexter at expeedo.de>
>>             <mailto:dexter at expeedo.de>> wrote:
>>             >>> >>>> FYI: I've just implemented an OVMS v3 style
>>             replacement for the SimpleConsole:
>>             >>> >>>> https://github.com/dexterbg/WifiConsole
>>             >>> >>>> V3 makes it pretty easy now to add stuff like
>>             this. It's using a script plugin to provide custom
>>             functions via the web API.
>>             >>> >>>> Regards,
>>             >>> >>>> Michael
>>             >>> >> Michael Balzer * Helkenberger Weg 9 * D-58256
>>             Ennepetal
>>             >>> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>             >>> >> _______________________________________________
>>             >>> >> OvmsDev mailing list
>>             >>> >> OvmsDev at lists.openvehicles.com
>>             <mailto:OvmsDev at lists.openvehicles.com>
>>             >>> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>             >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>             OvmsDev mailing list OvmsDev at lists.openvehicles.com
>>         _______________________________________________ OvmsDev
>>     _______________________________________________ OvmsDev mailing
>> _______________________________________________ OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200303/a83effc7/attachment-0001.html>
