[Ovmsdev] 3.2.013
Wed Jun 10 21:17:34 HKT 2020
You probably need to include —tags as an option on your git fetch.
The version is in the tag.
> On 10 Jun 2020, at 8:59 PM, Chris van der Meijden <chris at arachnon.de> wrote:
> Hi all,
> sorry for a perhaps silly question, but I don't understand the version numbering between master and fork.
> I regulary merge the changes from the ovms repository to my fork. So far so good and I am up to date at the moment. OVMS is now on release 3.2.013. When I perform a pull request on my fork and do a "make" on my local machine, I'm still on release 3.2.010. Even though the code is absolutely up to date.
> Could someone give me a hint on how to get the release numbers synced between the ovms master and my fork?
> Thanx in advance.
> Greetinx
> Chris
> Am Mittwoch, den 10.06.2020, 07:40 +0200 schrieb Michael Balzer:
>> Followed.
>> Am 10.06.20 um 03:28 schrieb Mark Webb-Johnson:
>>> No issues reported, so just released this to MAIN.
>>>> On 5 Jun 2020, at 1:15 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Followed.
>>>> Regards,
>>>> Michael
>>>> Am 05.06.20 um 07:06 schrieb Mark Webb-Johnson:
>>>>> I have release this 3.2.013 to EAP.
>>>>> Regards, Mark.
>>>>>> On 31 May 2020, at 5:34 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>>> Getting ready to release 3.2.013. I’ve tagged it, and built for api.openvehicles.com edge.
>>>>>> The main changes here are:
>>>>>> TPMS subsystem (including Tesla Roadster support with new optional K-line expansion board)
>>>>>> Change to config for server.v2
>>>>>> For #2, I moved the server password from server.v2/password to password/server.v2, and made the server.v2 config parameter read-write. That better matches how server.v3 does it. The change is done via a config migration, so should be transparent.
>>>>>> Absent any issues, I plan to move to EAP early in the coming week.
>>>>>> Regards, Mark
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200610/10de6b0a/attachment.htm>
