[Ovmsdev] Random crash if enable notifications
    Tue Jun  9 02:39:00 HKT 2020
I cannot tell if you did the correct setup for the spiram fix.
You need
- the new toolchain
- the new libs
- the spiram esp-idf branch
- the spiram ovms branch
If you've got all of this, then the crash isn't related to the SPIRAM bug.
Am 07.06.20 um 07:50 schrieb Tamás Kovács:
> I downloaded this toolchain and use it: build idf v3.3-beta3-776-g3d198cd50
> I checkout esp-idf to spiram-fix-test branch.
> I use a forked repo.
> I run the following to update to spiram-fix-test, on my local repo.
> git fetch upstream
> git pull upstream/spiram-fix-test master
> But i now get crash the last is:
> Last crash: abort() was called on core 1 Backtrace: 0x4008ace7 0x4008af7d 0x4010badf 0x40097d93 0x40083ffd 0x400845f1 0x4000bec7 0x4012c729 0x402a1815
> 0x401eb40d 0x401f7a26 0x401f8af0 0x40207065 0x40206f45 0x40207133 0x40206faf 0x402073b6 0x4020747d 0x401f4445 0x401f3344 0x401f3677 0x401f441e 0x402079d1
> 0x401f76e5 0x401f7892 0x40202ea6 0x4012db9a 0x4012dd9d
> kommykt at MacBook-Air OVMS.V3 % a2l 0x4008ace7 0x4008af7d 0x4010badf 0x40097d93 0x40083ffd 0x400845f1 0x4000bec7 0x4012c729 0x402a1815 0x401eb40d 0x401f7a26
> 0x401f8af0 0x40207065 0x40206f45 0x40207133 0x40206faf 0x402073b6 0x4020747d 0x401f4445 0x401f3344 0x401f3677 0x401f441e 0x402079d1 0x401f76e5 0x401f7892
> Using elf file: /Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
> 0x4008ace7 is in invoke_abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:156).
> 151#endif
> 152    while (1) {
> 153        if (esp_cpu_in_ocd_debug_mode()) {
> 154            __asm__ ("break 0,0");
> 155        }
> 156        *((int *) 0) = 0;
> 157    }
> 158}
> 159
> 160void abort()
> 0x4008af7d is in abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:171).
> 166    * don't overwrite that.
> 167    */
> 168    if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
> 169        esp_reset_reason_set_hint(ESP_RST_PANIC);
> 170    }
> 171    invoke_abort();
> 172}
> 173
> 174
> 175static const char *edesc[] = {
> 0x4010badf is in __assert_func (../../../.././newlib/libc/stdlib/assert.c:63).
> 0x40097d93 is in multi_heap_free (/Users/kommykt/esp/esp-idf/components/heap/multi_heap_poisoning.c:214).
> 209        return;
> 210    }
> 211    multi_heap_internal_lock(heap);
> 212
> 213    poison_head_t *head = verify_allocated_region(p, true);
> 214    assert(head != NULL);
> 215
> 216    #ifdef SLOW
> 217    /* replace everything with FREE_FILL_PATTERN, including the poison head/tail */
> 218    memset(head, FREE_FILL_PATTERN,
> 0x40083ffd is in heap_caps_free (/Users/kommykt/esp/esp-idf/components/heap/heap_caps.c:268).
> 263        ptr = (void *)dramAddrPtr[-1];
> 264    }
> 265
> 266    heap_t *heap = find_containing_heap(ptr);
> 267    assert(heap != NULL && "free() target pointer is outside heap areas");
> 268    multi_heap_free(heap->heap, ptr);
> 269}
> 270
> 271IRAM_ATTR void *heap_caps_realloc( void *ptr, size_t size, int caps)
> 272{
> 0x400845f1 is in _free_r (/Users/kommykt/esp/esp-idf/components/newlib/syscalls.c:42).
> 37    return heap_caps_malloc_default( size );
> 38}
> 39
> 40void IRAM_ATTR _free_r(struct _reent *r, void* ptr)
> 41{
> 42    heap_caps_free( ptr );
> 43}
> 44
> 45void* IRAM_ATTR _realloc_r(struct _reent *r, void* ptr, size_t size)
> 46{
> 0x4012c729 is in DukOvmsFree(void*, void*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:442).
> 437  return ExternalRamRealloc(ptr, size);
> 438  }
> 439
> 440void DukOvmsFree(void *udata, void *ptr)
> 441  {
> 442  free(ptr);
> 443  }
> 444
> 445void DukOvmsFatalHandler(void *udata, const char *msg)
> 446  {
> 0x402a1815 is in duk_heap_mem_free (duk_heap_memory.c:406).
> 0x401eb40d is in duk__refcount_refzero_hstring (duk_heap_alloc.c:103).
> 0x401f7a26 is in duk_heaphdr_refzero (duk_heap_refcount.c:630).
> 0x401f8af0 is in duk_pop_2 (duk_api_stack.c:6089).
> 0x40207065 is in duk__enc_value (duk_bi_json.c:2240).
> 0x40206f45 is in duk__enc_value (duk_bi_json.c:1951).
> 1946in duk_bi_json.c
> 0x40207133 is in duk__enc_object (duk_bi_json.c:1885).
> 1880in duk_bi_json.c
> 0x40206faf is in duk__enc_value (duk_bi_json.c:2203).
> 2198in duk_bi_json.c
> 0x402073b6 is in duk_bi_json_stringify_helper (duk_bi_json.c:3191).
> 3186in duk_bi_json.c
> 0x4020747d is in duk_bi_duktape_object_enc (duk_bi_duktape.c:96).
> 0x401f4445 is in duk__handle_call_raw (duk_js_call.c:2276).
> 0x401f3344 is in duk__js_execute_bytecode_inner (duk_js_call.c:2422).
> 2417in duk_js_call.c
> 0x401f3677 is in duk_js_execute_bytecode (duk_js_executor.c:2956).
> 0x401f441e is in duk__handle_call_raw (duk_js_call.c:2246).
> 0x402079d1 is in duk__pcall_method_raw (duk_js_call.c:2422).
> 0x401f76e5 is in duk_handle_safe_call (duk_js_call.c:2475).
> 2470in duk_js_call.c
> 0x401f7892 is in duk_safe_call (duk_api_call.c:318).
> 0x40202ea6 is in duk_pcall_method (duk_api_call.c:242).
> 237in duk_api_call.c
> 0x4012db9a is in OvmsScripts::DukTapeTask() (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:2273).
> 2268            duk_get_global_string(m_dukctx, "PubSub");
> 2269            duk_get_prop_string(m_dukctx, -1, "publish");
> 2270            duk_dup(m_dukctx, -2);  /* this binding = process */
> 2271            duk_push_string(m_dukctx, msg.body.dt_event.name <http://msg.body.dt_event.name>);
> 2272            duk_push_string(m_dukctx, "");
> 2273            if (duk_pcall_method(m_dukctx, 2) != 0)
> 2274              {
> 2275              DukOvmsErrorHandler(m_dukctx, -1);
> 2276              }
> 2277            duk_pop_2(m_dukctx);
> 0x4012dd9d is in DukTapeLaunchTask(void*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:427).
> 422
> 423void DukTapeLaunchTask(void *pvParameters)
> 424  {
> 425  OvmsScripts* me = (OvmsScripts*)pvParameters;
> 426
> 427  me->DukTapeTask();
> 428  }
> 429
> 430void* DukOvmsAlloc(void *udata, duk_size_t size)
> 431  {
> Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2020. jún. 5., P, 21:43):
>     See previous posts on this, you also need the fixed toolchain: https://github.com/espressif/esp-idf/issues/2892#issuecomment-501106283
>     Regards,
>     Michael
>     Am 05.06.20 um 20:04 schrieb Tamás Kovács:
>>     i think i don't run spiram fix. How can i use it. I must check out branch "spiram-fix-test"  to run spiram fix?
>>     Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2020. jún. 5., P, 6:58):
>>         Tamás,
>>         that doesn't need to be related to the pushover code. Do you run the spiram fix? I had this kind of heap corruption crashes frequently on builds
>>         without the spiram fix but not once with the fix.
>>         Regards,
>>         Michael
>>         Am 05.06.20 um 05:29 schrieb Tamás Kovács:
>>>         Some day's ago i enabled Pushover notifications and i get some crash after that.
>>>         The crash backtrase is:
>>>         Backtrace: 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb 0x400f0db4 0x400f0db4
>>>         0x400f0db4 0x400f0db4 0x40156109 0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
>>>         a2l output is:
>>>         kommykt at MacBook-Air OVMS.V3 % a2l 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb
>>>         0x400f0db4 0x400f0db4 0x400f0db4 0x400f0db4 0x40156109 0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
>>>         0x4008b75f is in invoke_abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:156).
>>>         151#endif
>>>         152    while (1) {
>>>         155        }
>>>         157    }
>>>         158}
>>>         159
>>>         160void abort()
>>>         0x4008b9f9 is in abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:171).
>>>         167    */
>>>         170    }
>>>         171    invoke_abort();
>>>         172}
>>>         173
>>>         174
>>>         0x4010b253 is in __assert_func (../../../.././newlib/libc/stdlib/assert.c:63).
>>>         0x40098c5f is in multi_heap_free (/Users/kommykt/esp/esp-idf/components/heap/multi_heap_poisoning.c:214).
>>>         209        return;
>>>         210    }
>>>         212
>>>         215
>>>         216    #ifdef SLOW
>>>         0x40084361 is in heap_caps_free (/Users/kommykt/esp/esp-idf/components/heap/heap_caps.c:268).
>>>         264    }
>>>         265
>>>         269}
>>>         270
>>>         272{
>>>         0x40084945 is in _free_r (/Users/kommykt/esp/esp-idf/components/newlib/syscalls.c:42).
>>>         38}
>>>         39
>>>         41{
>>>         43}
>>>         44
>>>         46{
>>>         0x401c1181 is in operator delete(void*) (/Volumes/build/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/del_op.cc:46).
>>>         0x400f01e1 is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>>>         std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char,
>>>         std::char_traits<char>, std::allocator<char> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>,
>>>         std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >,
>>>         std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >,
>>>         std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char,
>>>         std::char_traits<char>, std::allocator<char> > > > >::_M_drop_node(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char,
>>>         std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*)
>>>         (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h:110).
>>>         105      }
>>>         106
>>>         107      // __p is not permitted to be a null pointer.
>>>         108      void
>>>         109      deallocate(pointer __p, size_type)
>>>         110      { ::operator delete(__p); }
>>>         111
>>>         112      size_type
>>>         113      max_size() const _GLIBCXX_USE_NOEXCEPT
>>>         114      { return size_t(-1) / sizeof(_Tp); }
>>>         0x400f0dbb is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>>>         std::char_traits<char>, std::allocator<char> > > > >::_M_erase(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>,
>>>         (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1614).
>>>         1609      // Erase without rebalancing.
>>>         1610      while (__x != 0)
>>>         1611{
>>>         1612  _M_erase(_S_right(__x));
>>>         1613  _Link_type __y = _S_left(__x);
>>>         1614  _M_drop_node(__x);
>>>         1615  __x = __y;
>>>         1616}
>>>         1617    }
>>>         1618
>>>         0x400f0db4 is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>>>         (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1612).
>>>         1607    _M_erase(_Link_type __x)
>>>         1608    {
>>>         1611{
>>>         1615  __x = __y;
>>>         1616}
>>>         1608    {
>>>         1611{
>>>         1615  __x = __y;
>>>         1616}
>>>         1608    {
>>>         1611{
>>>         1615  __x = __y;
>>>         1616}
>>>         1608    {
>>>         1611{
>>>         1615  __x = __y;
>>>         1616}
>>>         0x40156109 is in Pushover::EventListener(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)
>>>         (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:858).
>>>         853
>>>         854      _Rb_tree(_Rb_tree&& __x, _Node_allocator&& __a);
>>>         855#endif
>>>         856
>>>         857      ~_Rb_tree() _GLIBCXX_NOEXCEPT
>>>         858      { _M_erase(_M_begin()); }
>>>         859
>>>         860      _Rb_tree&
>>>         861      operator=(const _Rb_tree& __x);
>>>         862
>>>         0x401550da is in std::_Function_handler<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*),
>>>         std::_Bind<std::_Mem_fn<void (Pushover::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (Pushover*,
>>>         std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string<char, std::char_traits<char>,
>>>         std::allocator<char> >&&, void*&&) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
>>>         595      template<typename... _Args, typename _Req
>>>         596              = _Require<typename _Traits::__lvalue,
>>>         597                          _CheckArgs<_Pack<_Args...>>>>
>>>         598result_type
>>>         599operator()(_Class* __object, _Args&&... __args) const
>>>         600{ return (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
>>>         601
>>>         602      // Handle smart pointers, references and pointers to derived
>>>         603      template<typename _Tp, typename... _Args, typename _Req
>>>         604              = _Require<_NotSame<_Class, _Tp>, _NotSame<_Class*, _Tp>,
>>>         0x400f3545 is in std::function<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>>>         void*)>::operator()(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) const
>>>         (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
>>>         2266    function<_Res(_ArgTypes...)>::
>>>         2267    operator()(_ArgTypes... __args) const
>>>         2268    {
>>>         2269      if (_M_empty())
>>>         2270__throw_bad_function_call();
>>>         2271      return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
>>>         2272    }
>>>         2273
>>>         2274#if __cpp_rtti
>>>         2275  template<typename _Res, typename... _ArgTypes>
>>>         0x400f375e is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
>>>         (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:234).
>>>         229      {
>>>         230      for (EventCallbackList::iterator itc=el->begin(); itc!=el->end(); ++itc)
>>>         231        {
>>>         232        m_current_started = monotonictime;
>>>         233        m_current_callback = *itc;
>>>         234        m_current_callback->m_callback(m_current_event, msg->body.signal.data);
>>>         235        m_current_callback = NULL;
>>>         236        }
>>>         237      }
>>>         238    }
>>>         0x400f37d5 is in OvmsEvents::EventTask() (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:185).
>>>         180      switch(msg.type)
>>>         181        {
>>>         182        case EVENT_none:
>>>         183          break;
>>>         184        case EVENT_signal:
>>>         185          HandleQueueSignalEvent(&msg);
>>>         186          break;
>>>         187        default:
>>>         188          break;
>>>         189        }
>>>         0x400f37e5 is in EventLaunchTask(void*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:56).
>>>         51
>>>         52void EventLaunchTask(void *pvParameters)
>>>         53  {
>>>         54  OvmsEvents* me = (OvmsEvents*)pvParameters;
>>>         55
>>>         56  me->EventTask();
>>>         57  }
>>>         58
>>>         59void event_trace(int verbosity, OvmsWriter* writer, OvmsCommand* cmd, int argc, const char* const* argv)
>>>         60  {
>>>         Üdvözlettel:
>>>         Kovács Tamás
>>>         _______________________________________________
>>>         OvmsDev mailing list
>>>         OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>         Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>         Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>     Üdvözlettel:
>>     Kovács Tamás
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200608/0e49258e/attachment.htm>
