[Ovmsdev] 3.2.013
Chris van der Meijden
chris at arachnon.de
Wed Jun 10 21:44:06 HKT 2020
Crosspost :-)
Thanx!
Am Mittwoch, den 10.06.2020, 21:43 +0800 schrieb Mark Webb-Johnson:
> Also —tags on the push.
> Regards, Mark
> > On 10 Jun 2020, at 9:40 PM, Chris van der Meijden <chris at arachnon.d
> > e> wrote:
> > Thanx for your quick response.
> > --tags did the trick for the local version when compiling.
> > Nevertheless the tags are not pushed back with "git push origin
> > master" into my fork on github. There the "releases" and "tags" are
> > still on 3.2.010 ...
> > I will google that ...
> > Am Mittwoch, den 10.06.2020, 21:17 +0800 schrieb Mark Webb-Johnson:
> > > You probably need to include —tags as an option on your git
> > > fetch.
> > > The version is in the tag.
> > > Regards, Mark
> > > > On 10 Jun 2020, at 8:59 PM, Chris van der Meijden <chris at arachn
> > > > on.de> wrote:
> > > > Hi all,
> > > > sorry for a perhaps silly question, but I don't understand the
> > > > version numbering between master and fork.
> > > > I regulary merge the changes from the ovms repository to my
> > > > fork. So far so good and I am up to date at the moment. OVMS is
> > > > now on release 3.2.013. When I perform a pull request on my
> > > > fork and do a "make" on my local machine, I'm still on release
> > > > 3.2.010. Even though the code is absolutely up to date.
> > > > Could someone give me a hint on how to get the release numbers
> > > > synced between the ovms master and my fork?
> > > > Thanx in advance.
> > > > Greetinx
> > > > Chris
> > > > Am Mittwoch, den 10.06.2020, 07:40 +0200 schrieb Michael
> > > > Balzer:
> > > > > Followed.
> > > > > Regards,
> > > > > Michael
> > > > > Am 10.06.20 um 03:28 schrieb Mark
> > > > > Webb-Johnson:
> > > > > > No issues reported, so just released this to MAIN.
> > > > > > Regards, Mark.
> > > > > > > On 5 Jun 2020, at 1:15 PM, Michael Balzer <de
> > > > > > > xter at expeedo.de> wrote:
> > > > > > > Followed.
> > > > > > > Regards,
> > > > > > > Michael
> > > > > > > Am 05.06.20 um 07:06
> > > > > > > > I have release this 3.2.013 to EAP.
> > > > > > > > Regards, Mark.
> > > > > > > > > On 31 May 2020, at 5:34 PM,
> > > > > > > > > Mark
> > > > > > > > > Webb-Johnson <mark at webb-joh
> > > > > > > > > nson.net>
> > > > > > > > > wrote:
> > > > > > > > > Getting ready to release
> > > > > > > > > 3.2.013. I’ve tagged
> > > > > > > > > it, and built for api.openvehicles.com edge.
> > > > > > > > > The main changes here
> > > > > > > > > are:
> > > > > > > > > TPMS subsystem
> > > > > > > > > (including
> > > > > > > > > Tesla Roadster
> > > > > > > > > support with new
> > > > > > > > > optional K-line
> > > > > > > > > expansion board)
> > > > > > > > > Change to config for
> > > > > > > > > server.v2
> > > > > > > > > For #2, I moved the
> > > > > > > > > server
> > > > > > > > > password from
> > > > > > > > > server.v2/password to
> > > > > > > > > password/server.v2, and
> > > > > > > > > made the server.v2
> > > > > > > > > config parameter read-
> > > > > > > > > write. That better
> > > > > > > > > matches how server.v3
> > > > > > > > > does it. The change
> > > > > > > > > is done via a config
> > > > > > > > > migration, so should
> > > > > > > > > be transparent.
> > > > > > > > > Absent any issues, I plan
> > > > > > > > > to
> > > > > > > > > move to EAP early in
> > > > > > > > > the coming week.
> > > > > > > > > Regards, Mark
> > > > > > > > > _______________________________________________
> > > > > > > > > OvmsDev mailing list
> > > > > > > > > OvmsDev at lists.openvehicles.
> > > > > > > > > com
> > > > > > > > > http://lists.openvehicles.c
> > > > > > > > > om/mailman/listinfo/ovmsdev
> > > > > > > > __________
> > > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > > ____
> > > > > > > nfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200610/69623960/attachment.html>
