[Ovmsdev] 3.2.013
Chris van der Meijden
chris at arachnon.de
Wed Jun 10 21:39:23 HKT 2020
Thanx for your quick response.
--tags did the trick for the local version when compiling. Nevertheless
the tags are not pushed back with "git push origin master" into my fork
on github. There the "releases" and "tags" are still on 3.2.010 ...
I will google that ...
Am Mittwoch, den 10.06.2020, 21:17 +0800 schrieb Mark Webb-Johnson:
> You probably need to include —tags as an option on your git fetch.
> The version is in the tag.
> Regards, Mark
> > On 10 Jun 2020, at 8:59 PM, Chris van der Meijden <chris at arachnon.d
> > e> wrote:
> > Hi all,
> > sorry for a perhaps silly question, but I don't understand the
> > version numbering between master and fork.
> > I regulary merge the changes from the ovms repository to my fork.
> > So far so good and I am up to date at the moment. OVMS is now on
> > release 3.2.013. When I perform a pull request on my fork and do a
> > "make" on my local machine, I'm still on release 3.2.010. Even
> > though the code is absolutely up to date.
> > Could someone give me a hint on how to get the release numbers
> > synced between the ovms master and my fork?
> > Thanx in advance.
> > Greetinx
> > Chris
> > Am Mittwoch, den 10.06.2020, 07:40 +0200 schrieb Michael Balzer:
> > > Followed.
> > > Regards,
> > > Michael
> > > Am 10.06.20 um 03:28 schrieb Mark
> > > Webb-Johnson:
> > > > No issues reported, so just released this to MAIN.
> > > > Regards, Mark.
> > > > > On 5 Jun 2020, at 1:15 PM, Michael Balzer <dexter
> > > > > @expeedo.de> wrote:
> > > > > Followed.
> > > > > Regards,
> > > > > Michael
> > > > > Am 05.06.20 um 07:06
> > > > > > I have release this 3.2.013 to EAP.
> > > > > > Regards, Mark.
> > > > > > > On 31 May 2020, at 5:34 PM, Mark
> > > > > > > Webb-Johnson <mark at webb-johnson
> > > > > > > .net>
> > > > > > > wrote:
> > > > > > > Getting ready to release
> > > > > > > 3.2.013. I’ve tagged it,
> > > > > > > and built for api.openvehicles.com edge.
> > > > > > > The main changes here are:
> > > > > > > TPMS subsystem (including
> > > > > > > Tesla Roadster support
> > > > > > > with new
> > > > > > > optional K-line
> > > > > > > expansion board)
> > > > > > > Change to config for
> > > > > > > server.v2
> > > > > > > For #2, I moved the server
> > > > > > > password from
> > > > > > > server.v2/password to
> > > > > > > password/server.v2, and
> > > > > > > made the server.v2
> > > > > > > config parameter read-
> > > > > > > write. That better
> > > > > > > matches how server.v3 does
> > > > > > > it. The change
> > > > > > > is done via a config
> > > > > > > migration, so should
> > > > > > > be transparent.
> > > > > > > Absent any issues, I plan to
> > > > > > > move to EAP early in the
> > > > > > > coming week.
> > > > > > > Regards, Mark
> > > > > > > _______________________________________________
> > > > > > > OvmsDev mailing list
> > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > http://lists.openvehicles.com/m
> > > > > > > ailman/listinfo/ovmsdev
> > > > > > ______
> > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200610/6ce9e242/attachment-0001.html>
