[Ovmsdev] Random crash if enable notifications
Sat Jun 6 03:42:15 HKT 2020
See previous posts on this, you also need the fixed toolchain: https://github.com/espressif/esp-idf/issues/2892#issuecomment-501106283
Am 05.06.20 um 20:04 schrieb Tamás Kovács:
> i think i don't run spiram fix. How can i use it. I must check out branch "spiram-fix-test" to run spiram fix?
> Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2020. jún. 5., P, 6:58):
> Tamás,
> that doesn't need to be related to the pushover code. Do you run the spiram fix? I had this kind of heap corruption crashes frequently on builds without
> the spiram fix but not once with the fix.
> Am 05.06.20 um 05:29 schrieb Tamás Kovács:
>> Some day's ago i enabled Pushover notifications and i get some crash after that.
>> The crash backtrase is:
>> Backtrace: 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb 0x400f0db4 0x400f0db4 0x400f0db4
>> 0x400f0db4 0x40156109 0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
>> a2l output is:
>> kommykt at MacBook-Air OVMS.V3 % a2l 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb
>> 0x400f0db4 0x400f0db4 0x400f0db4 0x400f0db4 0x40156109 0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
>> Using elf file: /Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
>> 0x4008b75f is in invoke_abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:156).
>> 151#endif
>> 152 while (1) {
>> 153 if (esp_cpu_in_ocd_debug_mode()) {
>> 154 __asm__ ("break 0,0");
>> 155 }
>> 156 *((int *) 0) = 0;
>> 157 }
>> 158}
>> 159
>> 160void abort()
>> 0x4008b9f9 is in abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:171).
>> 166 * don't overwrite that.
>> 167 */
>> 168 if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
>> 169 esp_reset_reason_set_hint(ESP_RST_PANIC);
>> 170 }
>> 171 invoke_abort();
>> 172}
>> 173
>> 174
>> 175static const char *edesc[] = {
>> 0x4010b253 is in __assert_func (../../../.././newlib/libc/stdlib/assert.c:63).
>> 0x40098c5f is in multi_heap_free (/Users/kommykt/esp/esp-idf/components/heap/multi_heap_poisoning.c:214).
>> 209 return;
>> 210 }
>> 211 multi_heap_internal_lock(heap);
>> 212
>> 213 poison_head_t *head = verify_allocated_region(p, true);
>> 214 assert(head != NULL);
>> 215
>> 216 #ifdef SLOW
>> 217 /* replace everything with FREE_FILL_PATTERN, including the poison head/tail */
>> 218 memset(head, FREE_FILL_PATTERN,
>> 0x40084361 is in heap_caps_free (/Users/kommykt/esp/esp-idf/components/heap/heap_caps.c:268).
>> 263 ptr = (void *)dramAddrPtr[-1];
>> 264 }
>> 265
>> 266 heap_t *heap = find_containing_heap(ptr);
>> 267 assert(heap != NULL && "free() target pointer is outside heap areas");
>> 268 multi_heap_free(heap->heap, ptr);
>> 269}
>> 270
>> 271IRAM_ATTR void *heap_caps_realloc( void *ptr, size_t size, int caps)
>> 272{
>> 0x40084945 is in _free_r (/Users/kommykt/esp/esp-idf/components/newlib/syscalls.c:42).
>> 37 return heap_caps_malloc_default( size );
>> 38}
>> 39
>> 40void IRAM_ATTR _free_r(struct _reent *r, void* ptr)
>> 41{
>> 42 heap_caps_free( ptr );
>> 43}
>> 44
>> 45void* IRAM_ATTR _realloc_r(struct _reent *r, void* ptr, size_t size)
>> 46{
>> 0x401c1181 is in operator delete(void*) (/Volumes/build/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/del_op.cc:46).
>> 0x400f01e1 is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>> std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>,
>> std::allocator<char> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const,
>> std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>,
>> std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const,
>> >::_M_drop_node(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const,
>> std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*)
>> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h:110).
>> 105 }
>> 106
>> 107 // __p is not permitted to be a null pointer.
>> 108 void
>> 109 deallocate(pointer __p, size_type)
>> 110 { ::operator delete(__p); }
>> 111
>> 112 size_type
>> 113 max_size() const _GLIBCXX_USE_NOEXCEPT
>> 114 { return size_t(-1) / sizeof(_Tp); }
>> 0x400f0dbb is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>> >::_M_erase(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const,
>> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1614).
>> 1609 // Erase without rebalancing.
>> 1610 while (__x != 0)
>> 1611{
>> 1612 _M_erase(_S_right(__x));
>> 1613 _Link_type __y = _S_left(__x);
>> 1614 _M_drop_node(__x);
>> 1615 __x = __y;
>> 1616}
>> 1617 }
>> 1618
>> 0x400f0db4 is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1612).
>> 1607 _M_erase(_Link_type __x)
>> 1608 {
>> 1611{
>> 1615 __x = __y;
>> 1616}
>> 1608 {
>> 1611{
>> 1615 __x = __y;
>> 1616}
>> 1608 {
>> 1611{
>> 1615 __x = __y;
>> 1616}
>> 1608 {
>> 1611{
>> 1615 __x = __y;
>> 1616}
>> 0x40156109 is in Pushover::EventListener(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)
>> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:858).
>> 853
>> 854 _Rb_tree(_Rb_tree&& __x, _Node_allocator&& __a);
>> 855#endif
>> 856
>> 857 ~_Rb_tree() _GLIBCXX_NOEXCEPT
>> 858 { _M_erase(_M_begin()); }
>> 859
>> 860 _Rb_tree&
>> 861 operator=(const _Rb_tree& __x);
>> 862
>> 0x401550da is in std::_Function_handler<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*),
>> std::_Bind<std::_Mem_fn<void (Pushover::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (Pushover*,
>> std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string<char, std::char_traits<char>,
>> std::allocator<char> >&&, void*&&) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
>> 595 template<typename... _Args, typename _Req
>> 596 = _Require<typename _Traits::__lvalue,
>> 597 _CheckArgs<_Pack<_Args...>>>>
>> 598result_type
>> 599operator()(_Class* __object, _Args&&... __args) const
>> 600{ return (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
>> 601
>> 602 // Handle smart pointers, references and pointers to derived
>> 603 template<typename _Tp, typename... _Args, typename _Req
>> 604 = _Require<_NotSame<_Class, _Tp>, _NotSame<_Class*, _Tp>,
>> 0x400f3545 is in std::function<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
>> void*)>::operator()(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) const
>> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
>> 2266 function<_Res(_ArgTypes...)>::
>> 2267 operator()(_ArgTypes... __args) const
>> 2268 {
>> 2269 if (_M_empty())
>> 2270__throw_bad_function_call();
>> 2271 return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
>> 2272 }
>> 2273
>> 2274#if __cpp_rtti
>> 2275 template<typename _Res, typename... _ArgTypes>
>> 0x400f375e is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
>> (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:234).
>> 229 {
>> 230 for (EventCallbackList::iterator itc=el->begin(); itc!=el->end(); ++itc)
>> 231 {
>> 232 m_current_started = monotonictime;
>> 233 m_current_callback = *itc;
>> 234 m_current_callback->m_callback(m_current_event, msg->body.signal.data);
>> 235 m_current_callback = NULL;
>> 236 }
>> 237 }
>> 238 }
>> 0x400f37d5 is in OvmsEvents::EventTask() (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:185).
>> 180 switch(msg.type)
>> 181 {
>> 182 case EVENT_none:
>> 183 break;
>> 184 case EVENT_signal:
>> 185 HandleQueueSignalEvent(&msg);
>> 186 break;
>> 187 default:
>> 188 break;
>> 189 }
>> 0x400f37e5 is in EventLaunchTask(void*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:56).
>> 51
>> 52void EventLaunchTask(void *pvParameters)
>> 53 {
>> 54 OvmsEvents* me = (OvmsEvents*)pvParameters;
>> 55
>> 56 me->EventTask();
>> 57 }
>> 58
>> 59void event_trace(int verbosity, OvmsWriter* writer, OvmsCommand* cmd, int argc, const char* const* argv)
>> 60 {
>> Üdvözlettel:
>> Kovács Tamás
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200605/775b2b78/attachment-0001.html>
