[Ovmsdev] Random crash if enable notifications
Fri Jun 5 12:57:10 HKT 2020
Tamás,
that doesn't need to be related to the pushover code. Do you run the spiram fix? I had this kind of heap corruption crashes frequently on builds without the
spiram fix but not once with the fix.
Am 05.06.20 um 05:29 schrieb Tamás Kovács:
> Some day's ago i enabled Pushover notifications and i get some crash after that.
> The crash backtrase is:
> Backtrace: 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb 0x400f0db4 0x400f0db4 0x400f0db4
> 0x400f0db4 0x40156109 0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
> a2l output is:
> kommykt at MacBook-Air OVMS.V3 % a2l 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb 0x400f0db4
> 0x400f0db4 0x400f0db4 0x400f0db4 0x40156109 0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
> Using elf file: /Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
> 0x4008b75f is in invoke_abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:156).
> 151#endif
> 152 while (1) {
> 153 if (esp_cpu_in_ocd_debug_mode()) {
> 154 __asm__ ("break 0,0");
> 155 }
> 156 *((int *) 0) = 0;
> 157 }
> 158}
> 159
> 160void abort()
> 0x4008b9f9 is in abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:171).
> 166 * don't overwrite that.
> 167 */
> 168 if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
> 169 esp_reset_reason_set_hint(ESP_RST_PANIC);
> 170 }
> 171 invoke_abort();
> 172}
> 173
> 174
> 175static const char *edesc[] = {
> 0x4010b253 is in __assert_func (../../../.././newlib/libc/stdlib/assert.c:63).
> 0x40098c5f is in multi_heap_free (/Users/kommykt/esp/esp-idf/components/heap/multi_heap_poisoning.c:214).
> 209 return;
> 210 }
> 211 multi_heap_internal_lock(heap);
> 212
> 213 poison_head_t *head = verify_allocated_region(p, true);
> 214 assert(head != NULL);
> 215
> 216 #ifdef SLOW
> 217 /* replace everything with FREE_FILL_PATTERN, including the poison head/tail */
> 218 memset(head, FREE_FILL_PATTERN,
> 0x40084361 is in heap_caps_free (/Users/kommykt/esp/esp-idf/components/heap/heap_caps.c:268).
> 263 ptr = (void *)dramAddrPtr[-1];
> 264 }
> 265
> 266 heap_t *heap = find_containing_heap(ptr);
> 267 assert(heap != NULL && "free() target pointer is outside heap areas");
> 268 multi_heap_free(heap->heap, ptr);
> 269}
> 270
> 271IRAM_ATTR void *heap_caps_realloc( void *ptr, size_t size, int caps)
> 272{
> 0x40084945 is in _free_r (/Users/kommykt/esp/esp-idf/components/newlib/syscalls.c:42).
> 37 return heap_caps_malloc_default( size );
> 38}
> 39
> 40void IRAM_ATTR _free_r(struct _reent *r, void* ptr)
> 41{
> 42 heap_caps_free( ptr );
> 43}
> 44
> 45void* IRAM_ATTR _realloc_r(struct _reent *r, void* ptr, size_t size)
> 46{
> 0x401c1181 is in operator delete(void*) (/Volumes/build/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/del_op.cc:46).
> 0x400f01e1 is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >,
> std::_Select1st<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > > >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >,
> std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > > > >::_M_drop_node(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>,
> std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*)
> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h:110).
> 105 }
> 106
> 107 // __p is not permitted to be a null pointer.
> 108 void
> 109 deallocate(pointer __p, size_type)
> 110 { ::operator delete(__p); }
> 111
> 112 size_type
> 113 max_size() const _GLIBCXX_USE_NOEXCEPT
> 114 { return size_t(-1) / sizeof(_Tp); }
> 0x400f0dbb is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > > > >::_M_erase(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>,
> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1614).
> 1609 // Erase without rebalancing.
> 1610 while (__x != 0)
> 1611{
> 1612 _M_erase(_S_right(__x));
> 1613 _Link_type __y = _S_left(__x);
> 1614 _M_drop_node(__x);
> 1615 __x = __y;
> 1616}
> 1617 }
> 1618
> 0x400f0db4 is in std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::__cxx11::basic_string<char,
> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1612).
> 1607 _M_erase(_Link_type __x)
> 1608 {
> 1611{
> 1615 __x = __y;
> 1616}
> 1608 {
> 1611{
> 1615 __x = __y;
> 1616}
> 1608 {
> 1611{
> 1615 __x = __y;
> 1616}
> 1608 {
> 1611{
> 1615 __x = __y;
> 1616}
> 0x40156109 is in Pushover::EventListener(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)
> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:858).
> 853
> 854 _Rb_tree(_Rb_tree&& __x, _Node_allocator&& __a);
> 855#endif
> 856
> 857 ~_Rb_tree() _GLIBCXX_NOEXCEPT
> 858 { _M_erase(_M_begin()); }
> 859
> 860 _Rb_tree&
> 861 operator=(const _Rb_tree& __x);
> 862
> 0x401550da is in std::_Function_handler<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*),
> std::_Bind<std::_Mem_fn<void (Pushover::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (Pushover*,
> std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char>
> >&&, void*&&) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
> 595 template<typename... _Args, typename _Req
> 596 = _Require<typename _Traits::__lvalue,
> 597 _CheckArgs<_Pack<_Args...>>>>
> 598result_type
> 599operator()(_Class* __object, _Args&&... __args) const
> 600{ return (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
> 601
> 602 // Handle smart pointers, references and pointers to derived
> 603 template<typename _Tp, typename... _Args, typename _Req
> 604 = _Require<_NotSame<_Class, _Tp>, _NotSame<_Class*, _Tp>,
> 0x400f3545 is in std::function<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >,
> void*)>::operator()(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) const
> (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
> 2266 function<_Res(_ArgTypes...)>::
> 2267 operator()(_ArgTypes... __args) const
> 2268 {
> 2269 if (_M_empty())
> 2270__throw_bad_function_call();
> 2271 return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
> 2272 }
> 2273
> 2274#if __cpp_rtti
> 2275 template<typename _Res, typename... _ArgTypes>
> 0x400f375e is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
> (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:234).
> 229 {
> 230 for (EventCallbackList::iterator itc=el->begin(); itc!=el->end(); ++itc)
> 231 {
> 232 m_current_started = monotonictime;
> 233 m_current_callback = *itc;
> 234 m_current_callback->m_callback(m_current_event, msg->body.signal.data);
> 235 m_current_callback = NULL;
> 236 }
> 237 }
> 238 }
> 0x400f37d5 is in OvmsEvents::EventTask() (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:185).
> 180 switch(msg.type)
> 181 {
> 182 case EVENT_none:
> 183 break;
> 184 case EVENT_signal:
> 185 HandleQueueSignalEvent(&msg);
> 186 break;
> 187 default:
> 188 break;
> 189 }
> 0x400f37e5 is in EventLaunchTask(void*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:56).
> 51
> 52void EventLaunchTask(void *pvParameters)
> 53 {
> 54 OvmsEvents* me = (OvmsEvents*)pvParameters;
> 55
> 56 me->EventTask();
> 57 }
> 58
> 59void event_trace(int verbosity, OvmsWriter* writer, OvmsCommand* cmd, int argc, const char* const* argv)
> 60 {
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200605/345c162e/attachment-0001.html>
