[Ovmsdev] Random crash if enable notifications
    Tamás Kovács
    kommykt at gmail.com
    Fri Jun  5 11:29:35 HKT 2020
Some day's ago i enabled Pushover notifications and i get some crash after
that.
The crash backtrase is:
Backtrace: 0x4008b75f 0x4008b9f9 0x4010b253 0x40098c5f 0x40084361
0x40084945 0x4000bec7 0x401c1181 0x400f01e1 0x400f0dbb 0x400f0db4
0x400f0db4 0x400f0db4 0x400f0db4 0x40156109 0x401550da 0x400f3545
0x400f375e 0x400f37d5 0x400f37e5
a2l output is:
kommykt at MacBook-Air OVMS.V3 % a2l 0x4008b75f 0x4008b9f9 0x4010b253
0x40098c5f 0x40084361 0x40084945 0x4000bec7 0x401c1181 0x400f01e1
0x400f0dbb 0x400f0db4 0x400f0db4 0x400f0db4 0x400f0db4 0x40156109
0x401550da 0x400f3545 0x400f375e 0x400f37d5 0x400f37e5
Using elf file:
/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
0x4008b75f is in invoke_abort
(/Users/kommykt/esp/esp-idf/components/esp32/panic.c:156).
151 #endif
152     while (1) {
153         if (esp_cpu_in_ocd_debug_mode()) {
154             __asm__ ("break 0,0");
155         }
156         *((int *) 0) = 0;
157     }
158 }
159
160 void abort()
0x4008b9f9 is in abort
(/Users/kommykt/esp/esp-idf/components/esp32/panic.c:171).
166     * don't overwrite that.
167     */
168     if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
169         esp_reset_reason_set_hint(ESP_RST_PANIC);
170     }
171     invoke_abort();
172 }
173
174
175 static const char *edesc[] = {
0x4010b253 is in __assert_func
(../../../.././newlib/libc/stdlib/assert.c:63).
0x40098c5f is in multi_heap_free
(/Users/kommykt/esp/esp-idf/components/heap/multi_heap_poisoning.c:214).
209         return;
210     }
211     multi_heap_internal_lock(heap);
212
213     poison_head_t *head = verify_allocated_region(p, true);
214     assert(head != NULL);
215
216     #ifdef SLOW
217     /* replace everything with FREE_FILL_PATTERN, including the poison
head/tail */
218     memset(head, FREE_FILL_PATTERN,
0x40084361 is in heap_caps_free
(/Users/kommykt/esp/esp-idf/components/heap/heap_caps.c:268).
263         ptr = (void *)dramAddrPtr[-1];
264     }
265
266     heap_t *heap = find_containing_heap(ptr);
267     assert(heap != NULL && "free() target pointer is outside heap
areas");
268     multi_heap_free(heap->heap, ptr);
269 }
270
271 IRAM_ATTR void *heap_caps_realloc( void *ptr, size_t size, int caps)
272 {
0x40084945 is in _free_r
(/Users/kommykt/esp/esp-idf/components/newlib/syscalls.c:42).
37     return heap_caps_malloc_default( size );
38 }
39
40 void IRAM_ATTR _free_r(struct _reent *r, void* ptr)
41 {
42     heap_caps_free( ptr );
43 }
44
45 void* IRAM_ATTR _realloc_r(struct _reent *r, void* ptr, size_t size)
46 {
0x401c1181 is in operator delete(void*)
(/Volumes/build/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/del_op.cc:46).
0x400f01e1 is in std::_Rb_tree<std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >,
std::pair<std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> > const, std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> > >,
std::_Select1st<std::pair<std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> > const,
std::allocator<char> > > >, std::less<std::__cxx11::basic_string<char,
std::allocator<std::pair<std::__cxx11::basic_string<char,
>::_M_drop_node(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char,
std::allocator<char> > > >*)
(/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h:110).
105       }
106
107       // __p is not permitted to be a null pointer.
108       void
109       deallocate(pointer __p, size_type)
110       { ::operator delete(__p); }
111
112       size_type
113       max_size() const _GLIBCXX_USE_NOEXCEPT
114       { return size_t(-1) / sizeof(_Tp); }
0x400f0dbb is in std::_Rb_tree<std::__cxx11::basic_string<char,
>::_M_erase(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char,
(/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1614).
1609       // Erase without rebalancing.
1610       while (__x != 0)
1611 {
1612   _M_erase(_S_right(__x));
1613   _Link_type __y = _S_left(__x);
1614   _M_drop_node(__x);
1615   __x = __y;
1616 }
1617     }
1618
0x400f0db4 is in std::_Rb_tree<std::__cxx11::basic_string<char,
(/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1612).
1607     _M_erase(_Link_type __x)
1608     {
1611 {
1615   __x = __y;
1616 }
1608     {
1611 {
1615   __x = __y;
1616 }
1608     {
1611 {
1615   __x = __y;
1616 }
1608     {
1611 {
1615   __x = __y;
1616 }
0x40156109 is in Pushover::EventListener(std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >, void*)
(/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:858).
853
854       _Rb_tree(_Rb_tree&& __x, _Node_allocator&& __a);
855 #endif
856
857       ~_Rb_tree() _GLIBCXX_NOEXCEPT
858       { _M_erase(_M_begin()); }
859
860       _Rb_tree&
861       operator=(const _Rb_tree& __x);
862
0x401550da is in std::_Function_handler<void
(std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void
(Pushover::*)(std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >, void*)> (Pushover*, std::_Placeholder<1>,
std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&,
std::allocator<char> >&&, void*&&)
(/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
595       template<typename... _Args, typename _Req
596               = _Require<typename _Traits::__lvalue,
597                           _CheckArgs<_Pack<_Args...>>>>
598 result_type
599 operator()(_Class* __object, _Args&&... __args) const
600 { return (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
601
602       // Handle smart pointers, references and pointers to derived
603       template<typename _Tp, typename... _Args, typename _Req
604               = _Require<_NotSame<_Class, _Tp>, _NotSame<_Class*, _Tp>,
0x400f3545 is in std::function<void (std::__cxx11::basic_string<char,
void*)>::operator()(std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >, void*) const
(/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
2266     function<_Res(_ArgTypes...)>::
2267     operator()(_ArgTypes... __args) const
2268     {
2269       if (_M_empty())
2270 __throw_bad_function_call();
2271       return _M_invoker(_M_functor,
std::forward<_ArgTypes>(__args)...);
2272     }
2273
2274 #if __cpp_rtti
2275   template<typename _Res, typename... _ArgTypes>
0x400f375e is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
(/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:234).
229       {
230       for (EventCallbackList::iterator itc=el->begin(); itc!=el->end();
++itc)
231         {
232         m_current_started = monotonictime;
233         m_current_callback = *itc;
234         m_current_callback->m_callback(m_current_event,
msg->body.signal.data);
235         m_current_callback = NULL;
236         }
237       }
238     }
0x400f37d5 is in OvmsEvents::EventTask()
(/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:185).
180       switch(msg.type)
181         {
182         case EVENT_none:
183           break;
184         case EVENT_signal:
185           HandleQueueSignalEvent(&msg);
186           break;
187         default:
188           break;
189         }
0x400f37e5 is in EventLaunchTask(void*)
(/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:56).
51
52 void EventLaunchTask(void *pvParameters)
53   {
54   OvmsEvents* me = (OvmsEvents*)pvParameters;
55
56   me->EventTask();
57   }
58
59 void event_trace(int verbosity, OvmsWriter* writer, OvmsCommand* cmd,
int argc, const char* const* argv)
60   {
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200605/3d5ead2b/attachment-0001.html>
