[Ovmsdev] Save Status
Tamás Kovács
kommykt at gmail.com
Fri Jun 5 11:25:15 HKT 2020
Thanks ! SmartED code works very well.
Thomas Heuer <egon at heuer-humfeld.de> ezt írta (időpont: 2020. jún. 1., H,
18:55):
> Look at the Smarted code vor save and restore status.
> The problem is, that the SD is mounted to late.
> Von meinem Huawei-Telefon gesendet
> -------- Ursprüngliche Nachricht --------
> Von: Tamás Kovács <kommykt at gmail.com>
> Datum: Mo., 1. Juni 2020, 17:30
> An: OVMS Developers <ovmsdev at lists.openvehicles.com>
> Betreff: [Ovmsdev] Save Status
> I would like to implement Save status to save / load value when module
> crash. I copy kia_common.h/cpp and remove all code not relevant, added code
> to vehicle_mitsubishi.h/cpp same as kia, but not restore the soc value.
> If i check the saved file at web interface / editor has size 4, and if i
> open it is empty.
> Last time i saw the Trip power plugin do the same at my module, if
> module restart no data in web interface. I think Trip power chart plugin
> overwrite the datafile after reboot. Save data to SD card.
> Any idea?
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200605/6d857948/attachment.html>
