[Ovmsdev] PSRAM fix in esp-idf release v3.3
Thu Jul 16 20:07:18 HKT 2020
Mark,
try:
https://dl.espressif.com/dl/xtensa-esp32-elf-macos-1.22.0-96-g2852398-5.2.0.tar.gz
…got that from here:
https://github.com/espressif/esp-idf/commit/f4333c8e3a554e8bb4210d825cbdf4bcaa1fc1b8#diff-0633a6582c888c6fc5bc6a3c00dba496R56
But the link needs to be fixed anyway.
Am 16.07.20 um 13:48 schrieb Mark Webb-Johnson:
> OK. I’ve done this on the api.openvehicles.com
> <http://api.openvehicles.com> build system (Linux based). My edge
> build gives:
>     3.2.013-298-g025f838/ota_0/edge (build idf v3.3.2-879-g0137aef Jul
>     16 2020 19:25:08)
> But, the Mac osx download link gives:
>     curl
>     https://dl.espressif.com/dl/xtensa-esp32-elf-osx-1.22.0-96-g2852398-5.2.0.tar.gz
>     <html>
>     <head><title>404 Not Found</title></head>
>     <body bgcolor="white">
>     <center><h1>404 Not Found</h1></center>
>     <hr><center>nginx/1.14.0 (Ubuntu)</center>
>     </body>
>     </html>
> Oh, good grief. I’ll try to take it up with espressif…
>> On 16 Jul 2020, at 5:27 PM, Michael Balzer <dexter at expeedo.de
>> Everyone,
>> I've merged the latest release/v3.3 esp-idf into our idf fork and
>> merged the PSRAM fix test branch into our OVMS master.
>> To build now, you need to:
>> 1. Update your toolchain to release 1.22.0-96-g2852398-5.2.0:
>> download the toolchain for your OS from
>> https://docs.espressif.com/projects/esp-idf/en/release-v3.3/get-started/index.html#setup-toolchain,
>> simply replace your existing toolchain installation by unpacking the
>> archive. Test your toolchain installation by checking
>> xtensa-esp32-elf-gcc --version.
>> 2. Pull our latest esp-idf master and -important- update the submodules
>> 3. Pull/checkout our latest OVMS master
>> 4. Update your sdkconfig from support/sdkconfig.default.hw31
>> The build should then result in version
>> 3.2.013-298-g025f838b/factory/edge (build idf v3.3.2-879-g0137aef47
>> Jul 16 2020 10:53:38) or higher.
>> Am 15.07.20 um 08:07 schrieb Michael Balzer:
>>> Yes, differences on the test branches are minor, also in esp-idf.
>>> But we probably also need to pull in the latest changes on the
>>> esp-idf 3.3 branch, which may be some more work.
>>> I'll fetch the current toolchain version and check what is needed.
>>> Am 15.07.20 um 04:13 schrieb Mark Webb-Johnson:
>>>> Finally… Crazy that this took so long.
>>>> We have a GetOVMSHardware() in ovms_version.cpp that picks up
>>>> the esp_chip_info_t structure and has chip.revision (documented as
>>>> "chip revision number”). That is stored in metric m.hardware. My
>>>> bench unit is showing rev=ESP32/1. I checked a bunch of recent cars
>>>> connected to api.openvehicles.com <http://api.openvehicles.com/>,
>>>> but all showed the same. So not sure if the v3 silicon is not
>>>> reported in that chip.revision, if we are just using existing
>>>> stocks, or an IDF update is required to pickup the new silicon
>>>> version number. The v3 seems fairly recent (March 2020?) and I
>>>> don’t see a v2 listed. Anyway, I’ve just yesterday received a new
>>>> batch of modules so will check those to see if it shows up.
>>>> What do we need to do to switch to this? Presumably I turn off
>>>> auto-build of the firmware on api.openvehicles.com
>>>> <http://api.openvehicles.com/>, you merge your SPIRAM branch to
>>>> master, we tell everyone to download the new toolchain, then we
>>>> switch both our edge builds back to master branch with new toolchain?
>>>> Apart from the CONFIG_SPIRAM_SUPPORT 2MB workaround, I can’t see
>>>> any significant differences between remotes/origin/spiram-fix-test
>>>> and master? Is the only difference the ovms_websockethandler.cpp
>>>> change to std::string (vs extram::string)?
>>>> Regards, Mark.
>>>>> On 15 Jul 2020, at 2:11 AM, Michael Balzer <dexter at expeedo.de
>>>>> Mark,
>>>>> it seems the fix has finally arrived in the official release 3.3
>>>>> branch:
>>>>> https://github.com/espressif/esp-idf/issues/2892#issuecomment-658327913
>>>>> Btw:
>>>>>> In the v3 silicon, the issue has been fixed, and the workaround
>>>>>> is no longer required.
>>>>> I guess that means from some manufacturing point on we should
>>>>> provide two builds, one for the older hardware and one for the
>>>>> modules with v3 chips, as the fix definitely has a performance impact.
>>>>> Regards,
>>>>> Michael
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200716/f0f6b920/attachment.htm>
