[Ovmsdev] Vehicle Idle Notification
Derek Caudwell d.caudwell at gmail.com
Fri Jul 31 19:11:42 HKT 2020
Hi all,
In Vehicle.cpp the NotifyVehicleIdling() routine is essentially called when
StdMetrics.ms_v_env_awake is true and the idle ticker has expired. My
understanding from the standard metrics documentation is that the awake
metric is to indicate activity on the can bus eg when charging or prior to
the vehicle being turned on. Hence I was only expecting an idle
notification if the vehicle has been accidentally left in the on state
indicated by StandardMetrics.ms_v_env_on. Or have I misunderstood how
the two metrics and idle function are intended to work or mean?
Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200731/38f6bb4d/attachment.html>
