[Ovmsdev] VW e-Up read/poll via OBD is working
Soko
ovms at soko.cc
Thu Jul 30 22:43:59 HKT 2020
Ahhh OK, I've found OvmsVehicle::virtual void TickerXXX(uint32_t ticker);
Got it! This was exactly my issue as I didn't know about any function
which gets called regularly so I could check something like this...
It's not an ideal situation though: I just can slow down the poll after
my fail-counter gets too high as I need to check when the car gets
powered again. So all I can do is polling, lets say every 60 secs when
the car is off, and increase it once its on. But there is now way around
this 60-sec polling if the only thing I can do is poll :(
Afaik there is only the sharkcow's list below, reverse engineered by him
from ODBeleven.
(dev)marxx exlpained to me: There is a gateway between the CAN-Buses and
the OBD Connector in all VW-AG vehicles which only replies to polls and
also acts as security gateway if you want to write to the buses.
So I think I cannot really do a can log or use re tool as the OBD
interface stays quiet if I'm not polling it...
And as there is no other vehicle from VW,Seat,Skoda,Audi,etc. in OVMS.
So I have no cheat-sheet :(
Anyhow... I would need to poll one ECU (is this the correct therm?)
which doesn't shuts down... or maybe the issue is the OBD-gateway
shutting down.
What do you think?
Soko
On 30.07.2020 16:17, Michael Balzer wrote:
> Soko,
> nice progress :-)
> If you can't detect vehicle state by listening to regular status CAN
> frames, you can check the time since the last poll reply in the per
> second ticker.
> As poll replies normally come in fast, you should be able to detect a
> switch-off by a small timeout, say 3 seconds… probably need to add a
> counter, as a single poll may get lost / ignored.
> CAN tx errors can be caused by other issues as well, so should
> generally not be interpreted that way.
> But… are you sure there are no status frames on the bus? Have you done
> a can log or tried the re tool?
> Am 30.07.20 um 14:43 schrieb Soko:
>> Hi guys,
>> Want to report success on connecting and reading my VW e-Up via OBD
>> cable using the Poller. As you can see in the screenshot of the log
>> attached I get an IncomingPollReply(..) call and an SoC value of 33.333%
>> Once I turn of the ignition and lock the car though I don't get any
>> replies no more (line D 793813) and then I get can1 errors... I'm
>> polling with 10 seconds intervall.
>> I know that this is as it should be... but my issue is: I don't have
>> any way to know if the ignition is on, the key is in, the car is
>> running, the car is charging as the PIDs are not known for such
>> values (afaik by the lists of sharkcow
>> https://www.goingelectric.de/wiki/Liste-der-OBD2-Codes/).
>> So what would be the best approach to change the different polling
>> states? Can I somehow get called (in my vehicle-class) if an
>> can-error is thrown? Then I would increase the poll frequency.
>> Any suggestions?
>> thanks
>> Soko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200730/3b2e277f/attachment.html>
