[Ovmsdev] Netmanager priority issue solved
Fri Jul 24 22:02:25 HKT 2020
It seems we've got another mutex issue in duktape:
OVMS# mo ta
Number of Tasks = 22 Stack: Now Max Total Heap 32-bit
SPIRAM C# PRI CPU% BPR/MH
3FFAFB88 1 Blk esp_timer 436 708 4096 40288 644
31232 0 22 0% 22/ 0
3FFC0E90 2 Blk eventTask 476 1884 4608 104 0
0 0 20 0% 20/ 0
3FFC3314 3 Blk OVMS Events 704 3360 8192 92364 0
35464 1 8 1% 8/ 0
3FFC6764 4 Rdy OVMS DukTape 496 10864 12288 580 0
189492 1 3 10% 3/_*42*_
…increasing once per minute. I'll have a look.
Am 24.07.20 um 15:27 schrieb Michael Balzer:
> TL;DR: you need to pull my latest esp-idf changes.
> I've finally found & solved the strange priority changes for our
> netmanager task (i.e. being raised suddenly from origin 5 to 18/22): the
> bug was in the esp-idf posix threads mutex implementation.
> I had suspected the mutex priority inheritance for a while, so added a
> way to retrieve the internal mutex hold count for our task list. Using
> this I noticed the hold count would always & only raise by 2 whenever
> any kind of mongoose connection was closed.
> That lead me to checking the thread concurrency protection for mongoose
> mbufs, because every mongoose connection has two mbufs associated (rx &
> tx), each having a posix mutex.
> The bug was: posix mutexes were deleted after locking (taking) them.
> FreeRTOS mutexes must not be deleted while being taken, that breaks the
> priority inheritance (more precisely the disinheritance), with the
> visible effect being the mutex hold count not returning to zero.
> As a side effect, this may also solve the strange event task starvations
> (hope so…). I was investigating this as I suspected some busy loop in
> the netmanager context. With the netman running at prio 22, that would
> effectively block almost all other processing including the timer
> service. I've found & fixed one potential busy loop trigger in the
> netman that would have been caused by the netman task still running
> while all interfaces had been lost -- not sure if that could happen, but
> it would explain the effects.
> So please watch your crash debug info & report if the issue still turns up.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200724/7fd83c4c/attachment.html>
