[Ovmsdev] Wifi setup
Fri Jul 10 19:42:08 HKT 2020
Everyone,
the wifi rework is pushed:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/5d1f124060326b92f35887878b4d49c8012542dc
…and the new edge build is on my server.
This now allows to scan for networks in all modes without disruption of
a running wifi network.
I've used this to also add a network selection dialog to the setup
wizard & wifi config.
The apclient mode can now be started without a client SSID to let the
module automatically connect to any network configured. The autostart
config page now allows this setup. The special "scanning client" mode
has been removed.
The wifi manager will still stick to an established connection, even if
a new network with higher signal strength becomes available. I thought
about automatically switching networks if the signal gets poor, but for
now decided against it to avoid frequent network reconfigurations in
edge cases. If you want the module to explicitly scan for a better
network, issue "wifi reconnect".
Of course this has involved some changes to the wifi manager, so please
test & report.
Am 10.07.20 um 08:57 schrieb Michael Balzer:
> TL;DR: yes, I'm currently also going towards not letting
> esp_wifi_connect() decide which AP to connect to.
> More precisely, exactly the first (!) call to esp_wifi_connect() after
> a reboot/power up seems to do a round robin scheme among all reachable
> access points of a network regardless of their signal strength. This
> even applies to the first connect() immediately after a scan.
> Example:
> D (5034) events: Signal(system.wifi.scan.done)
> V (5034) esp32wifi: ScanDone: #01 ssid='WLAN-214677'
> bssid='7c:ff:4d:15:2f:86' chan=11 rssi=-64
> V (5034) esp32wifi: ScanDone: #02 ssid='WLAN-214677'
> bssid='94:4a:0c:c3:9e:63' chan=11 rssi=-77
> I (5044) esp32wifi: Found SSID WLAN-214677 - trying to connect
> I (7564) esp32wifi: STA connected with SSID: WLAN-214677, BSSID:
> 94:4a:0c:c3:9e:63, Channel: 11, Auth: WPA2
> The next reboot will connect to 7c:ff (despite unchanged signal
> strengths), the next again to 94:4a and so on. I've only got two
> access points, so I can't test if it's really round-robin, but it's
> wrong anyway.
> On all following reconnects on the running system it will correctly
> pick the 7c:ff AP, also if wifi is stopped & restarted.
> This AP switching behaviour also persists powering off the module, so
> the wifi blob seems to do this on purpose and even use some persistent
> storage to implement it. Totally undocumented and I've found no way to
> disable this and no workaround so far.
> There may be a fix for this in the current esp-idf wifi blob, but I've
> found no issues on this, and esp-idf commit comments are mostly not
> useful.
> Am 10.07.20 um 02:55 schrieb Mark Webb-Johnson:
>> FYI:
>> I’ve recently done some work with the esphome system (based on
>> platformio on top of esp idf), for home automation. They don’t seem
>> to trust the ESP libraries identifying the strongest signal (in the
>> case of two APs broadcasting the same SSID). They don’t blindly
>> connect to a SSID, but instead first do a scan to produce an ordered
>> list and then connect to the SSID+AP-MAC-Address of the AP with the
>> strongest signal.
>> That approach might help with your other issue (recently raised in
>> mantis).
>>> On 10 Jul 2020, at 5:43 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Welcome Derek,
>>> I've got a rework of the wifi component near done that allows to use
>>> scanning mode in apclient configuration. I think I can push the
>>> changes tomorrow & suggest you'll be my beta tester ;-)
>>> Am 09.07.20 um 20:50 schrieb Derek Caudwell:
>>>> Hi devs,
>>>> I recently received the ovms hardware and have been trying to
>>>> setup the unit so I can solely use the wifi AP+client. In NZ 3G is
>>>> soon to be sunset and for my needs I don't really need a connection
>>>> when I'm driving (and want to make sure everything is behaving
>>>> nicely on the can bus before I do).
>>>> I realise AP+client brings it limitations however hopefully some of
>>>> these can be worked around as I want to be able to use
>>>> the dashboard/plugins as well as the mobile app. I am new to
>>>> C/ESP32 programming and the code base so I thought it best to ask a
>>>> few questions before I begin tinkering with it.
>>>> Ideally I want the unit on loss of connection to an AP to try and
>>>> find another AP that has been set in the wifi config and connect.
>>>> The parts I am not too sure are as follows:
>>>> - on boot the code uses the default wifi ssid, if the default is
>>>> not available how does the code try and switch to one of the other
>>>> saved APs?
>>>> - can multiple APs be saved to the wifi config memory and
>>>> handled by ESP32? or do they need to be retrieved from ovms config,
>>>> wifi client details set, try connect and enumerated through?
>>>> - I assume EventTimer10 is the logical place to add extra code if
>>>> required to enumerate through APs and try to connect? similar to
>>>> EventScanWifiDone when in SClient mode
>>>> - What is the reason scanning mode is unavailable for AP+client
>>>> mode in auto init, from the ESP32 documentation it appeared to be
>>>> usable still but with limitations?
>>>> Thanks in advance for any pointers and background.
>>>> Cheers Derek
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200710/e973b3be/attachment.html>
