[Ovmsdev] Double updates - Normal?
    Wed Jan 29 09:51:35 HKT 2020
Not normal. Can you send us the logs. Also the output of ‘ota status’ would be helpful.
Are you sure this isn't just a notification of the update, and is the update itself? Perhaps a screenshot of the double notifications you receive?
> On 25 Jan 2020, at 11:35 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi folks,
> I moved my car's OVMSv3 to the Edge firmware a bit ago, and notice that
> every update seems to be doubled.  Besides being a bit annoying, it ends
> up without a previous version to fall back to since both partitions end
> up being the same.
> Is this behavior normal?  Can it be prevented?
> I'm only on Edge because of the bug in obd2ecu, and will probably move
> to EAP after we get an EAP build with the fix in it.  Is the behavior
> the same there?
> I used to be on Main, and all seemed fine there.
> Thanks,
> Greg
