[Ovmsdev] Double updates - Normal?
Fri Jan 31 14:54:51 HKT 2020
Edge (3.2.008-275-g77e652af) on dexters-web now also has OVMS_HW_EVENT_QUEUE_SIZE 40.
Am 31.01.20 um 01:15 schrieb Mark Webb-Johnson:
> I put some telemetry on this and see (for the first ten seconds of boot):
> I (43) events: Initialising EVENTS (1200)
> I (612) events: SignalEvent: event 'config.mounted' queued (0 waiting, 20 free)
> I (682) ovms_main: Starting HOUSEKEEPING...
> I (682) housekeeping: Initialising HOUSEKEEPING Framework...
> I (842) events: SignalEvent: event 'housekeeping.init' queued (1 waiting, 19 free)
> I (1022) housekeeping: Executing on CPU core 1
> I (1022) housekeeping: reset_reason: cpu0=12, cpu1=12
> I (1022) housekeeping: Initialising WATCHDOG...
> I (1022) housekeeping: Starting PERIPHERALS...
> I (1262) events: SignalEvent: event 'egpio.output.1.low' queued (1 waiting, 19 free)
> I (1262) housekeeping: Auto init max7317 (free: 193092 bytes)
> I (1272) housekeeping: Auto init ext12v (free: 193092 bytes)
> I (1282) housekeeping: Auto init dbc (free: 193092 bytes)
> I (1282) housekeeping: Auto init wifi (free: 193092 bytes)
> I (1462) housekeeping: Auto init modem (free: 149952 bytes)
> I (1472) housekeeping: Auto init vehicle (free: 149656 bytes)
> I (1482) events: SignalEvent: event 'power.can1.on' queued (4 waiting, 16 free)
> I (1492) events: SignalEvent: event 'egpio.output.2.low' queued (5 waiting, 15 free)
> I (1502) housekeeping: Auto init obd2ecu (free: 141484 bytes)
> I (1502) housekeeping: Auto init server v2 (free: 141484 bytes)
> I (1512) housekeeping: Auto init server v3 (free: 141484 bytes)
> I (1522) housekeeping: Auto init javascript (free: 141484 bytes)
> I (1522) housekeeping: Auto init done (free: 141484 bytes)
> I (1532) housekeeping: Starting USB console...
> Firmware: 3.2.008-125-g1fca0362-dirty/factoents:
> SignalEvent: event 'system.start' queued (7 waiting, 13 free)
> I (2022) events: SignalEvent: event 'ticker.1' queued (8 waiting, 12 free)
> I (2202) simcom: State: Enter CheckPowerOff state
> I (2202) events: SignalEvent: event 'egpio.output.3.low' queued (1 waiting, 19 free)
> I (2202) events: SignalEvent: event 'egpio.output.0.low' queued (2 waiting, 18 free)
> I (3022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (4022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (5022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (6022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (6022) sdcard: SD CARD has been inserted
> I (6022) events: SignalEvent: event 'sd.insert' queued (1 waiting, 19 free)
> I (7022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (8022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (8022) events: SignalEvent: event 'sd.mounted' queued (1 waiting, 19 free)
> I (9022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (10022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (11022) events: SignalEvent: event 'ticker.1' queued (1 waiting, 19 free)
> I (11022) events: SignalEvent: event 'ticker.10' queued (1 waiting, 19 free)
> (that doesn’t include scheduled events, only the ones from OvmsEvents::SignalEvent)
> I think the issue was most likely triggered by the egpio events introduced a while back. Agree with Thomas that this is most likely just a simple queue
> overflow. Perhaps EGPIO is flapping at startup, causing a flurry of these egpio events? I am guessing that this is aggravated in Greg’s case as he is doing
> some egpio and power work for HUD control.
> I’ve increased the OVMS_HW_EVENT_QUEUE_SIZE to 40 on my test build, and just released that to the production server (for edge). As this sdkconfig file is not
> included in github, I recommend all developers do the same for their local builds.
> @Michael can you set the same on your production build server?
> @Greg can you check your existing firmware boot (via usb) and check for 'queue overflow, event '%s’ dropped’ style messages on startup (probably around the
> time is says ’Starting USB console…’.
> @Greg please try the edge 3.2.008-126-g0291d03 firmware. Update to it, reboot, and see if ‘metric list version’ shows the version correctly. Hopefully this
> resolves (or works around) the issue.
>> On 30 Jan 2020, at 8:07 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Maybe OVMS_HW_EVENT_QUEUE_SIZE is just too small now, with the added events during boot and async event processing?
>> Am 30.01.20 um 13:00 schrieb Tamás Kovács:
>>> Some time the m.version not set on Mitsubishi i-Miev .
>>> 2020. január 30., csütörtök dátummal Thomas Heuer <egon at heuer-humfeld.de <mailto:egon at heuer-humfeld.de>> ezt írta:
>>> The issue was on boot, the events: SignalEvent: queue overflow, event 'system.start' dropped in some case.
>>> the problem was the egpio settings in OvmsVehicleSmartED::ConfigChanged(OvmsConfigParam* param)
>>> https://github.com/Dimitrie78/Open-Vehicle-Monitoring-System-3/commit/21e1a0339c029adf5c746dfd6fecddbc9455a947#diff-9106f33dff1f6160884b2e78d145607fL155-L160
>>> <https://github.com/Dimitrie78/Open-Vehicle-Monitoring-System-3/commit/21e1a0339c029adf5c746dfd6fecddbc9455a947#diff-9106f33dff1f6160884b2e78d145607fL155-L160>
>>> line 155 – 160
>>> *Von:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com <mailto:ovmsdev-bounces at lists.openvehicles.com>> *Im Auftrag von *Mark Webb-Johnson
>>> *Gesendet:* Donnerstag, 30. Januar 2020 11:35
>>> *An:* OVMS Developers <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
>>> *Betreff:* Re: [Ovmsdev] Double updates - Normal?
>>> Just had a thought.
>>> Events used to be synchronous, but we switched to deliver in a different task. Maybe the startup sequence relies on that in some way.
>>> On 30 Jan 2020, at 6:32 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>> Seems identical. The changes don’t seem to affect the dispatch of the system.start event.
>>> I think it must be a race condition.
>>> Mark
>>> On 30 Jan 2020, at 5:56 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> a similar issue was happening on some Smart ED and fixed by Dimitrie later on:
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/293
>>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/293>
>>> I thought that was a Smart specific issue, maybe I was wrong.
>>> Am 30.01.20 um 06:17 schrieb Mark Webb-Johnson:
>>> Still stumped…
>>> The OTA code doesn’t call GetOVMSVersion(), but instead just looks at StandardMetrics.ms_m_version (which we know is blank). That is why
>>> this is happening.
>>> But why is StandardMetrics.ms_m_version empty (as is the hardware value as well).
>>> The ovms_version code hooks into ’system.start’ event, and sets the version and hardware metrics. So, obviously that is not being called.
>>> That event is raised just after ’Starting USB console…”. The event is also listened to be ovms_time, ovms_mdns, and swcan.
>>> MDNS outputs “Starting MDNS” when it sees that. The ovms_time sets the environment variable TZ. Your car is showing:
>>> ovms> time status
>>> Vehicle Response:
>>> Time Zone: Not defined
>>> UTC Time: 2020-01-30 05:00:53 UTC
>>> Local Time: 2020-01-30 05:00:53 GMT
>>> Provider: None
>>> So looks like TZ is not being set. Presumably that means the call is not happening. I had a look at the ovms_events code, but can’t find
>>> anything obvious.
>>> So, tried a hacky test:
>>> ovms> metric list version
>>> Vehicle Response:
>>> m.version
>>> ovms> event raise system.start
>>> Vehicle Response:
>>> Raising event: system.start
>>> Vehicle Response:
>>> m.version 3.2.008-121-g4c6c9fe/ota_0/edge (build idf v3.3-beta3-775-gdc1ca69 Jan 29 2020 00:00:52)
>>> ovms> ota status
>>> Vehicle Response:
>>> Firmware: 3.2.008-121-g4c6c9fe/ota_0/edge (build idf v3.3-beta3-775-gdc1ca69 Jan 29 2020 00:00:52)
>>> Running partition: ota_0
>>> Boot partition: ota_0
>>> Factory image: 3.1.001
>>> OTA_O image: 3.2.008-121-g4c6c9fe
>>> OTA_1 image: 3.2.008-121-g4c6c9fe
>>> Server Available: 3.2.008-121-g4c6c9fe (no update required)
>>> Can you try to boot from USB (module reset) and provide the serial boot log? Particularly around the lines ’Starting USB console’.
>>> Maybe a race condition at startup, or some other issue delivering events early on?
>>> Only other thing I see are some scripts on /store/events regarding vehicle on/off - perhaps you can try disabling those to see if they
>>> trigger the issue? I tried recreating them on my box, but couldn’t repeat your problem.
>>> On 30 Jan 2020, at 11:55 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>> Greg,
>>> It seems your car can’t pickup currently running firmware version:
>>> ovms> open ROADSTER834B
>>> Connected and logged in to ROADSTER834B
>>> Vehicle Response:
>>> m.version
>>> By comparison, here’s mine:
>>> Vehicle Response:
>>> m.version 3.2.008-121-g4c6c9fe/ota_1/edge (build idf v3.3-beta3-775-gdc1ca69 Jan 29 2020 00:00:52)
>>> ovms> ota status
>>> Vehicle Response:
>>> Firmware: 3.2.008-121-g4c6c9fe/ota_1/edge (build idf v3.3-beta3-775-gdc1ca69 Jan 29 2020 00:00:52)
>>> Running partition: ota_1
>>> Boot partition: ota_1
>>> Factory image: 3.2.002
>>> OTA_O image: 3.2.008-120-gcfb7864
>>> Your m.hardware metric is also blank.
>>> I’ll keep looking, but at the moment this seems bizarre.
>>> On 30 Jan 2020, at 11:21 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Hi Mark, Michael,
>>> Seems like what is happening is that the module keeps thinking a new
>>> update is available. Today was especially active for some reason.
>>> Screenshot of the Android application's log screen, attached. All
>>> versions appear to be the same. The car has simply been sitting in the
>>> garage on WiFi; no transitions of network access.
>>> Output of 'ota status' attached as well.
>>> Sorry, but I don't appear to have logging enabled. What specifically
>>> would you like logged?
>>> Greg
>>> Mark Webb-Johnson wrote:
>>> Not normal. Can you send us the logs. Also the output of ‘ota status’ would be helpful.
>>> Are you sure this isn't just a notification of the update, and is the update itself? Perhaps a screenshot of the double
>>> notifications you receive?
>>> On 25 Jan 2020, at 11:35 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Hi folks,
>>> I moved my car's OVMSv3 to the Edge firmware a bit ago, and notice that
>>> every update seems to be doubled. Besides being a bit annoying, it ends
>>> up without a previous version to fall back to since both partitions end
>>> up being the same.
>>> Is this behavior normal? Can it be prevented?
>>> I'm only on Edge because of the bug in obd2ecu, and will probably move
>>> to EAP after we get an EAP build with the fix in it. Is the behavior
>>> the same there?
>>> I used to be on Main, and all seemed fine there.
>>> Thanks,
>>> Greg
>>> <Repeated updates.png><Repeated updates ota status output.txt>_______________________________________________
>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal <https://www.google.com/maps/search/Helkenberger+Weg+9+*+D-58256+Ennepetal?entry=gmail&source=g>
>>> Üdvözlettel:
>>> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200131/9c1e41e3/attachment-0001.html>
